I have a problem with CST ascii export using VBA script. I have used CST Eigenmode solver to simulate a periodic structure for 20 number of modes. A parameter phaseY is used in parameter sweep with 80 number of iterations.
The results are OK but the problem arises with exporting the whole data set. I used both of the following methods
Method 1:
SelectTreeItem "1D Results\Mode Frequencies"
ExportPlotData "Output.txt"
Method2:
With ASCIIExport
.Reset
.FileName ("Output.txt")
.Mode ("FixedNumber")
.Step(80)
.Execute
End With
The Problem:
In parameter view I have a data set of 21 columns, which are including the folowing parameters
1. phaseY
2.Mode1
21. Mode20.
There are 80 number of rows correspond to the number of iteration. When I execute the above VBA macro, the Output.txt file contains only a few rows (25) out of all 80 rows.
I can't understand what is happening wrong.
Please help me
