Personally, I would expect measurable non-linearities (if any) only at the lower end of transformer frequency band. But as Mini-Circuits doesn't specify it, you have to measure by yourself. The linearity impact of load impedance changes due to the transformer, as seen at the amplifier output, is most likely larger.
From Mazz,
It is just in the break point. SO I suggest find the alternative.
One point is though it is passive circuit there could be chance of PIM.
BTW what is he frequency of operation?
be aware: if "12channel +2dBm/channel" means that he has 12 times +2dBm (it seems strange but if it like this...), the total max power is less than +13 dbm.
Main source of possible nonlinearities is the magnetic core, also affected by DC bias current, BTW. The influence of the non-linear permeability is mainly present at low frequencies.
The frequency is 54~860MHz.My understanding is main source of possible nonlinearities is the magnetic core as FvM said.
For I have read a patent about it which can increase the transformer linearity.
And the specs of MINi only indicate the maximum power. I think it is the limited power that will not damage the core.
I think you can measure the nonlinearity by the classic two tone test or triple beat method. First I start with pure tone and superposed DC Bias for magnetization curve and extracting the tranformer parameters.
Because two or more tone test is difficult if not high isolation (the sum of two tones allways produces intermodulation distortion in both signal generators/amplifiers) you must use moderate power amplifiers in very low levels and/or circulators/isolators.
Briefly, to use the known techniques for RF power amplifiers.
I think, it's easier in this case, cause the PA already exists and is part of the application. So the test would be for additional IM caused by the transformer. It should be carried out at minimal operation frequency. As I mentioned previously, you may want to check for PA IM caused by load impedance variation rather than the transformer itself.
Alternatively, you can use a different PA to measure transformer nonlinearity at a considerable higher power level and/or lower operation frequency to have a guaranteed margin.
