To finish an antenna paper, it is necessary to draw geometry of the antenna in the paper. That means, I must insert an antenna's geometry figure in my article.
I use CST to simulate antenna, which can export DXF format to Autocad. However, it is not easy to translate CST model into Word Figure.
Anyone has other better method ?
If you have Microsoft Visio, then you can import the DXF geometry to Visio, then convert the imported vector CAD-object to standard Visio objects by right-clicking on the CAD-object...
Then you got your own geometry and you an add dimensioning lines and annotations using standard Visio stencils.
Finally, you can export to a wide variety of graphic formats.
The only disadvantage using Visio is that older versions had problems exporting to EPS format, and newer versions simply don't offer EPS exporting (due to unsolved problems)...
Why you just do not print screen from the CST on the clipboard with <CTRL>+<Alt Gr>+<Print Scr> and than cut the part you want in MS Paint and paste it in Word?
<Print Scr> is just beside the function tasters on almost all PC keyboards.
Dear Debeli, sometimes printing screen is a good idea , sometimes it is not .
I think it is not fit for writing antenna article which is to be published in journals.
You can print your work on Adobe Generic Postscript printer which generates .ps file, open it with Ghostwiev and convert as BMP. BMP can be imported in Word.
I have never used SmartDraw but i guess that (in theory) it surely can do the same... After all, SmartDraw as I heard has the full functionality of Visio (it even opens .vsd files)...
just go to File -> export -> BMP
you will get what ever you want from your screen in bmp format
and in power point or word import picture ->from file. point the bmp file OK
and thats all.
The bmp files very big so just open them with microsoft painter(in Stat -> Program ->accessories-> Paint) or ACDsee or Photoshop and save them in jpg format and do the above
