how to do mismatch analysis on spectre
chinito
Full Member level 2
I want to do mismatch analysis between two transistor using spectre, how do I do this?
ccw27
Full Member level 5
Do monte-carlo analysis. Foundry like TSMC includes monte-carlo analysis in their model files. If your foundry does not provide then you will have to write it yourself. An easy way is to add a voltage source for each MOS, which will emulate the Vth mismatch. Then you should write a script where you will include the value of standard deviation. The standard deviation can be calculated using mismatch characterization provided by the foundry.
xinyin
Junior Member level 1
Hello ccw27,
Can you tell me how to make monte-carlo model files if the foundry does not provide them?
nxing
Advanced Member level 1
China
Check Cadence's help document, you will find a model.
