basha009
Newbie level 5
My antenna dimensions are 9cm X 8.93cm with ground plane dimensions 120 cm X 120 cm( operate at 150 MHz). To analyze it, My RAM memory is not sufficient. So I want to change the mesh settings so that the no. of triangles would be reduced and RAM would be sufficient. But I know nothing about mesh settings. I request you to please help me to get the information(what options need to be changed).
I used cylinders to create copper wires.
