My superviser asked me to find out the relationship of Capcitors, transister on a voltage doubler. I dont know how to do a simulation with different value of capcitance and the ratio of W/L for finding a optimize the power efficiency on circuit pump circuit? Can anyone teach me the method of it? Thank you very much
if you are using Cadence, u can use parametric sweep in the tools menu in the analog environment after assigning a variable for your caps or aspect ratio as their values... you can also use the optimization analysis, also, in cadence..
