nanosim spi
caterpede said:
I still can't really figure out how to use the testbench directly. How should I do that? Should I use the verilog libraries?
regards
there are two scnearions here
1. if your design is complete spice and tb is verilog use the following way, here i pasted all the spi and other files
example.spi file:
* | include sch & library |
.inc '../model_spice/*.sch'
.inc '../libs/globals.prm'
.protect
.lib '../libs/fets.lib' BI
.lib '../libs/res.lib' L
.unprotect
.temp 125
.option scale = 1.0u
.global vdd vddio vss vssa vtt vdda vddaux vddiobrd vddpx
Vvdd vdd 0 DC vddburn
Vvddio vddio 0 DC vddioburn
Vvss vss 0 DC 0
Vvdda vdda 0 DC vddaburn
Vvssa vssa 0 DC 0
Vvtt vtt 0 DC vttburn
Vvddaux vddaux 0 DC vddauxburn
Vvddiobrd vddiobrd 0 DC vddiobrdburn
Vvddpx vddpx 0 DC vddburn
example.init
choose nanosim -nspice ../model_spice/example.spi -nhspf ../model_spice/example.spf -C ../nano_ctrl/example.cfg -o ./sim.scan.bi_temp/nanosim_example;
set rmap ../nano_ctrl/rmap.map;
run command:
bsub vcs -n 2 -q long -I -m lnx64_ib -toolvers Y-2006.06-6 -feat nanosim2006.06 -feat debussy -- -R verilog_testbench.v +ad=../nano_ctrl/example.init +error+100000 -Mdir=./VCS_bin_bi/ -o ./VCS_bin_bi/simv -l ../logs/example.log -full64
incase if you have any doubt, send me ur mail id i will get back to you.
