How to determine the range of the Transmitter of following
I guess the data is transmitted around 50-100m in a wide area..
Actual range depends on many things, Some things:
-reguired reliability of the link
-Receiver sensitivity
-transmitter and receiver antenna
-height above ground and orientation of receiver and transmitter
-RF environment (obstacles in between?, indoor/outdoor?, etc)
-fixed (point to point) versus mobile use
-local interference
-data rate and coding (think of error correcting or detecting coding).
-supply voltage (large influence on RF output power).
Depending on your situation, you select a certain propagation model to assess the range.
