How to determine the radius for probe, coax, coax pin and the height for coax in HFSS
abhaykotnala
Junior Member level 1
my problem is how to determine the radius for probe,coax,coax pin and the height for coax
Re: probe in hfss
link makes sense for calculating dimensions of coax
good luck
Re: probe in hfss
thanx man that was gud.....
hey can u guide me on a problem i have...
see i am making an H shaped microstrip antenna in hfss......
i made a substrate of given dimensions using box option......which material is prefferable for the substrate
1. rt duroid
2 vacumm?
for making the ground plane i made a rectangle at bottom and assignes perfectly dielectric to it.....similarly i made the patch using rectangle at the top using rectangle giving it perfectly electric boundary conditions to it
should i make these things of box type with some height for better results or its ok?
how much the coaxial dimensions affect the results of this structure?
i want to short the patch and ground....how should i do it/?
Re: probe in hfss
First ; you have to decide about bandwidth and resonance frequency. dielectric permittivity effect on bandwidth and frequency. (air small banwidth etc.)
second you have to draw H shaped patch over dielectric and also assign it perfect E,
Ground plane should be assigned perfect E with infinite or finite ground plane option, (Also you need a cut on it for coax probe)
Dielectric box doesnt need assignment of perfect etc.
third; dielectric box height effects banwidth and also resonance frequency. Similiar condition exist on coax measures too. Cos impedance changes with dimensions.
good luck[/b]
