dedalus said:Hi LvW.
Thanks for explanation. If I understand correctly, for the case of integrator α = 1/(sC)/(1/(sC)+R), so Acl = -α/β = -1/(sCR).
Please, give some references to literature, where this feedback concept (with feedforward parameter) is described.
Thanks.
System that is described by the equation Acl= α*A/(1+β*A) is shown in the first attached figure. It can easily be shown that this system is equivalent to the system shown in the second figure. In both systems feedback network is present, but with different transfer functions. The key point here is in the definition of the feedback factor. It is defined as fraction of output signal that is fed back to the input. In the case of second system this is Sf2/So = β/α. And in the case of the first system this is (Sf1/So)/α (!), not Sf1/So (because input signal is signal applied to the input of prefilter α, not the signal at the input of summator, thus we must additionally divide by alpha). So in both cases feedback factor is equal as β/α (as expected, because systems are equivalent).
FvM said:...............
In contrast, the "feedback1" scheme describes a real system, it's parameters can be directly related to circuit elements, it's
actually instructive.
LvW said:*Is there anywhere a logical break?
I don't want to use the structure for a circuit, where it's not approriate. The output of the substractor in your feedback2 scheme isBut why don't you use them?
FvM said:The output of the substractor in your feedback2 scheme is not the signal at the amplifier input in case of the inverting amplifier.
FvM said:The description doesn't help me to analyze this type of circuits.
LvW said:What do you mean with "whole system"? Signal input? If yes, your "new" definition makes no sense, because nothing can be fed back to the input of the whole system, since the voltage source has zero input resistance and no feedback signal can be developped.
LvW said:No. Not their DEFINITION depends on the feedback topology. Instead, the RESULT (the expression) applying this general definition depends on the representation. According to your own words, the feedback factor in circuit No. 2 is ff=f. Thus, you have used the classical and single definition for the feedback factor.
But, it has no practical meaning and, more than that, cannot be used to identify the correct feedback factor for the circuit under discussion.
dedalus said:.............
Why do you think, that expression from the first representation is correct and from the second - is incorrect? If both expressions are derived from the same definition, using different, but equivalent, representations of the system, why one of them is correct and other incorrect? Isn't this a logical break?
I think that the term "correct feedback factor" has no sense. The question "What is correct expression for feedback factor?" without specifying representation of the system is similar to the question "What is the voltage at the node?", without specifying reference node. Actually feedback factor is intermediate parameter, used for defining loop gain, parameter of primary interest. To find loop gain we multiply feedback factor by open-loop gain, which also has no "correct expression". Expression for open-loop gain is also depends on representation of the system. But their product (loop gain) doesn't depend (similar to the subtracting of two voltages). So the term correct "correct loop gain" does make sense, but the terms "correct feedback factor" and "correct open-loop gain" don't.
LvW said:Insofar, I correct my self and replace the wording "correct feedback factor" by "commonly used feedback factor".
However, as far as your preferred definition is concerned, I refuse to call the term α/β "feedback factor" as you propose. Try to find any other name for it.
At first, otherwise it would lead to misunderstandings and at second, it is simply not true that this is a factor which determines the part of the output signal which is fed back to the input.
Example 1: inverting amplifier: α/β=R1/R2
Example 2: integrator: α/β=1/sRC
In both cases, this ratio of two impedances can be larger than 1 (as you have claimed already at the beginning of this thread). But in this case, it cannot be a portion of the output signal and does not meet the common definition of "feedback factor".
In summary, you may define this ratio as you want - and use it - but do not call it "feedback factor". OK?
LvW said:OK, if it is so, I have the following question:
How is this factor (beta/alpha) defined in words? (Like beta, which results simply from the superposition theorem as the portion which is fed back to the forward amplifier for Vin=0).
Sedra/Smith said:The output xo is fed to the load as well as to a feedback network, which produces a sample of the output. This sample xf is related to xo by the feedback factor β,
xf = β*xo.
Razavi said:... where H(s) and G(s) are called the feedforward and the feedback networks, respectively. ... we replace G(s) by a frequency-independent quanity β and call it the "feedback factor".
Johns/Martin said:The feedback term, β, represents the feedback factor, ...
Baker/Li/Boyce said:The feedback factor, β, is defined as
β = xf/xo
I assume, you refer to paragraph 8.1 Ideal Feedback Equation. It discusses the feedback network transfer function, designated(I must admit that in Gray/Meyer/Hurst/Lewis "Analysis and Design of Analog Integrated Circuits", which I prefer from all, the term f = β/α isn't called "feedback factor", but "network transfer function". Though this name cannot avoid misunderstandings, because β can be called "network transfer function" too)
LvW said:thank you for the excerpts from the 4 textbooks as contained in your last posting.
When I compare the corresponding equations and the associated figure (Feedback.jpg) with the two feedback representations as given by you as Feedback1.jpg (april 14th and 15th) I am really happy to see that general rules, equations and the terminology of electronics and control theory apply also to the domain of "Analog IC design" (surprise, surprise,..).
FvM said:I assume, you refer to paragraph 8.1 Ideal Feedback Equation. It discusses the feedback network transfer function, designated
with the letter f, obviously identical to feedback factor β in the above presented schemes. But there isn't anything like β/α, neither at
this place nor anywhere in chapter 8 Feedback or 9 Frequency Response and Stability of Feedback Amplifiers.
dedalus said:Yes, it's incorrect to say that the terminology of control theory cannot be applied to the "analog ic design" domain, because actually the term ("feedback factor") is the same, BUT the things that this term represents are different. By the way, I have not said, that general rules and equations cannot be applied in the "analog ic design" domain.
I wanted to say, that there is no "commonly used feedback factor" as well as "correct definition of feedback factor". Every domain can have it's own "commonly used" parameters.
