It depends on whether you have access to the stream's data clock. If so then you can get away with something simple such as the solution hinted at by maksya.bansalr said:I want to detect a second one '1' in a serial bit stream. Can some one suggest me optimal logic implementation.
library ieee;
use ieee.std_logic_1164.all;
entity parser is
port(clk : in std_logic;
rst : in std_logic;
din : in std_logic;
dout: out std_logic);
end parser;
architecture parser of parser is
begin
process(clk, rst)
variable count : integer range 0 to 2;
begin
if(rst = '1') then
dout <= '0';
count := 0;
elsif (clk'event and clk = '1') then
if(din = '1') then
if(count = 1) then
dout <= '1';
count := 0;
else
dout <= '0';
count := 1;
end if;
else
count := 0;
dout <= '0';
end if;
end if;
end process;
end parser;
Is it critical in your case to use only combinational logic?bansalr said:Actually i wanted to know if we have say 32 bit of data. what is combinational logic
to search for a second one.
