How to detect a magnetic field
Arutan1453
Junior Member level 1
Turkiye
Hello,
I want to know how I can detect a magnetic field.
I know there are some devices like tesla meter or electronic compass module etc...
But I would to learn how I can detect the field with a coil and its appropriate electronic... A more physical solution..
Thanks!
The solution is different for DC (static) and AC fields. Only the latter can be detected with a coil (or the coil has to be moved). Hall sensors and flux gate magnetometers are usual solutions to measure static fields.
I want to detect a static field (magnetic objects)...
So, with hall sensors or flux gate magnetometer, will a low magnetic field be detected ?
I want to detect the magneticity of a screw for exemple..
Thanks
u can detect a magnetic field by using a coil and ammeter. connect the meter in series with the ammeter then move the coil and note if the indicator have been moved, then this means that there is a magnetic field
