how to design this FIR filter in MATLAB?
revooridinesh
Member level 1
Member level 1
Canada
Hi
I have specifications for a FIR filter as :
Filter should remove the noise of frequency 60 Hz. Windowing technique has to be used(any window method). Oscillation in the passband should not exceed 1 dB and attenuation in stop band should be atleast -20 dB. How to design this filter ? I have seen some tools in Matlab but it also needs pass band frequency, stop band frequency and sampling frequency information. How to design this filter and plot its frequency response ?
Thank You
Do you want a notch(bandreject) or lowpass or highpass filter? They will all be able to reject 60 Hz. Regardless, you've already said that your stopband frequency is 60 Hz, right?
It is up to the designer, or whoever gave you the specs, to determine the passband frequency; you can't just pull that out the air, it's a design constraint. The same is true of the sampling frequency. It looks like you are missing some specs.
Once you've got the rest of the design specs, run (type) "fdatool" from the MATLAB command line - this provides a nice graphical means of entering your design parameters and viewing/plotting the resultant filter, frequency response, coefficients etc.
can we use 'sptool' instead of 'fdatool' ?
