Mutad0r
Junior Member level 3
- Joined
- Feb 13, 2013
- Messages
- 28
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,608
So, first off, why do I need it. My brother has taken up fencing. Not the sale of illegal goods, but the sword-fighting kind. Turns out that wired systems are sill widely used. There is wireless fencing equipment, but apparently they are hella expensive. SO, I thought I'd make a wireless fencing system.
What do I need the worst RF transmitter ever for? Some time ago I got an RC car for fixing. It simply didn't work. Well, the only way the signal wen't through is when the controller and cars antenna touched. Apparently the car was set to work on 27 MHz and the remote was transmitting on 40 MHz, the signal only got through when the antenna touched without much degradation from the filters on the cars end. From this I got the idea of using radio mismatched/bad radio transmitters and receivers to register a touch between the sword and the suit, both acting as an antenna. The sword would be the transmitter and the suit would be the receiver.
The only way to make wireless fencing work ( I think ) is to use radio signals, because direct current doesn't travel from one battery to another and a wireless system cannot have a common ground.
Anyway, for the worst transmitter/receiver I have following ideas:
Would it be better to use a square wave instead of a sine wave as the radio signal? I need the exact opposite of range, so if square waves transmit worse that sine waves, it could be a great idea.
Would it be better to use some sort of a simple binary data on the radio signal or for starters try and use an IC designed for RC usage?
There has to be some sort of data on the signal, so that different objects can be identified ( your and enemy sword would have a different signal, so stabbing yourself can be registered too... Not that it's a real problem in the fencing world)
