How to design the tunnel diode in PSPICE
vinaiece
Newbie level 6
hi every one,
i need help for my project i need know how to design the tunnel diode in pspice.
where can i get the information about it.
Re: pspice
Hi try this:
h**p://www.intusoft.com/nlhtm/nl51.htm
by the way you may also find info in this forum about this topic
the attached file may help for the research (not simulation).
Try this link I think it is helpful:
h**p://cobweb.ecn.purdue.edu/~ee201c/pspice/pspice_info.html
Don't forget to tell if they were helpful.
here it is if you were not able to download:
*version 9.1 733570842
@index
symloc Tdiode 0 776
*symbol Tdiode
d Tunnel Diode
@type p 9.1
@attributes
a 0 sp 9 0 0 0 hln 100 REFDES=G?
a 0 sp 0:11 0 0 30 hln 100 PART=GVALUE
a 0 sp 13 0 2 28 hln 100 MODEL=1N3018
a 0 sp 0 0 0 0 hln 100 TEMPLATE=G^@REFDES %pin1 %pin2 VALUE { @EXPR }
a 0 up 0:13 0 0 10 hln 100 EXPR=17.2n*(EXP(V(%pin1, %pin2)/27m)-1)+62.5m*V(%pin1, %pin2)*EXP(-V(%pin1, %pin2)/65m)
a 0 sp 0:13 0 0 10 hln 100 SIMULATIONONLY=
@pins
p 0 12 12 hln 100 pin1 n 0 10 h
a 0 s 1 0 9 8 hrn 100 PIN=1
a 0 s 0:13 0 0 10 hln 100 ERC=i
a 0 s 0:13 0 0 10 hln 100 FLOAT=n
p 0 19 12 hrn 100 pin2 n 30 10 u
a 0 s 1 0 20 10 hlb 100 PIN=2
a 0 s 0:13 0 30 10 hln 100 ERC=o
a 0 s 0:13 0 30 10 hln 100 FLOAT=n
@graphics 30 20 0 10 10
v 0 12 5
12 15
20 10
12 5
v 0 20 15
17 17
v 0 17 3
20 5
v 0 10 10
12 10
v 0 20 5
20 15
Re: pspice
Did you check it's library?
