how to design the interface circuit
electronic_satya
Hi all,
I will briefly explain my setup and shown as an attachment
1. The hardware board 1 on its output pin gives 24V and depending on the resistance value it gives out X amps current.
2. I have another hardware board-2 which is capable of reading up to 24V but the current capability is limited to some 100mAmps.
3. Now my requirement is to interface the hardware board -1 and hardware board -2 through some interface board so that only 24v appears on the input of Hardware board -1 and very little current comes in.
could somebody suggest me the design of the interface board i hope some opamp circuit will work?
Thanks in advance,
Regards,
satya
I do not understand your problem. You have a resistor with +24V across it (from hardware board 1) and you want to feed the 24V to another board - whats wrong with a piece of wire, the current hardware board 2 depends on its input impedance. If the input impedance is too low (so diverting too much current), then you need a buffer amp that reduces the current and increases its input impedance.
Frank
Hi Frank,
Thank you for the reply. Yes exactly I need a buffer amp circuit, could you please suggest me some circuits I never designed any hardware circuit.
Thanks and regards,
Satya
Thank you for the reference circuit. But i have a single 24V supply from which i have to acheive the buffer circuit, is it possible to do it? The design in link requires a -5V source.
Thanks and regards,
satya
You can simply make -5V using 7805 3 terminal voltage regulator IC. Hope you are familiar with that. You can refer 78xx series datasheet here.
