macgradywk
Junior Member level 2
At the output we get 1-bit data stream, how can it be 8-bit?
thx
thx
Note: This feature currently requires accessing the site using the built-in Safari browser.
yView attachment 83785
From the figure, xis the 1-bit stream. After the digital filter and decimator, what will be y
be?
No. Typically a sigma-delta converter uses a much higher oversampling ratio than that. An 8:1 ratio would normally not be sufficient to give an 8-bit accurate output, it would be more like 80:1 or greater. The higher the oversample ratio, the better the signal-noise ratio of the filtered output and the easier the filtering becomes.does this mean 8-bit sigma delta ADC will have "8 times oversampling (8*Fs)" -> after the SDM will produce "8-one bit stream (1011 0111)" and will need a decimation filter with 8:1 decimation factor" ???
