Attached is a simple handrawn power supply schematic. You will be able to get 9 to 15Vdc depending on the type of voltage regulator IC used (IC1).Please select primary voltage of transformer T1 according to the mains supply voltage in your country. Let me know if you have any other questions.Hope the schematic helps.
it is better if you use the bridge circuit and rectify, if you want it to be rectified without the diode drops then use the op-amp rectifier in which the feedback is given using a diode.
