Dec 1, 2008 #1 P pianomania Member level 5 Joined Jun 15, 2006 Messages 83 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 1,906 if i wanna add two dc signal , like 1.23v with 2.4v , which are generated from different block ? How to implement ? It seems that OP only amplify ac signal.
Dec 1, 2008 #2 LvW Advanced Member level 6 Joined May 7, 2008 Messages 5,912 Helped 1,753 Reputation 3,512 Reaction score 1,364 Trophy points 1,393 Location Germany Activity points 40,432 pianomania said: ............... It seems that OP only amplify ac signal. Click to expand... Opamps work from 0 Hz to an upper limit which depends on the type.
Dec 1, 2008 #3 xulfee Advanced Member level 1 Joined May 27, 2008 Messages 401 Helped 45 Reputation 100 Reaction score 14 Trophy points 1,298 Location Pakistan Activity points 2,904 simple summing amplifier using opamap
Dec 1, 2008 #4 P pianomania Member level 5 Joined Jun 15, 2006 Messages 83 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 1,906 xulfee said: simple summing amplifier using opamap Click to expand... but if we need to add 2 positive voltage , we need 3 OP amp to achieve! Do we have simple solution?
Dec 1, 2008 #5 Awarapunshee Advanced Member level 1 Joined Jul 11, 2007 Messages 409 Helped 93 Reputation 186 Reaction score 31 Trophy points 1,308 Location Some Where In Heaven Activity points 3,184 pianomania said: xulfee said: simple summing amplifier using opamap Click to expand... but if we need to add 2 positive voltage , we need 3 OP amp to achieve! Do we have simple solution? Click to expand... A single OP-Amp can do the job. Look at https://www.allaboutcircuits.com/vol_3/chpt_8/8.html ENJOY!
