how to design a accurate constant current source?
liusupeng
how to design a constant current source which is invariant to temperature and process variantions?
There are methods to stabilise CC against temperature (and voltage) variations. Against process variations you need an external CC or CV comparison source.
There are many ways. There are plenty of common circuits available. You can use a current mirror circuit.
Design a voltage source, like a bandgap and derive the current from its output.
If you want process-invariant, you either need an
invariant process (good luck) or a trimming scheme.
And since "natural" tempco also carries some process
sensitivity, double down on that.
See chapters 5 and 11 of Razavi's Design of Analog CMOS ICs
Use a bandgap reference as a process independent voltage source. Then use a voltage to current converter. Use an external resistor, or use trimming with an internal resistor. When using internal resistor + trimming the addition of a NTAT current sink in parallel to the resistor may be necessary to get temperature independence.
you can combine n and p type resistors in series, which have different tempcos, to create a resistor that cancels the tempco of delta-Vbe. Make the resistors physically large to minimize the impact of process variation. delta-Vbe is not very process sensitive
Bandgap voltage/external resistor is a good choice.
