How to Design a 2.4GHz balun filter
cyai
Member level 2
balun filter
I wanna use 1.6mm FR4 PCB board to design a baluan filter operated at 2.4 GHz band, who can tell me how to design it ?
Thanks.
2.4 ghz balun
Hi
Look a this link it could help to start
rayan
2.4ghz balun
In this article can find how to design a microstrip balun on FR4 for 2.4GHz.
2.4g balun
CMFB is important in such circuit,should be taken great care
balun 2.4ghz
in 2.4G,fr4 could be used?
in my kownledge the fr4 usally used lower 2G
balun 2.4 ghz
I have used FR4 even for C band (3.4GHz). Is not a problem from the moment that you are taken into account the loss.
2.4ghz balun design
I use FR4 for 2.4GHz in long time. I believe the majority of 2.4GHz consumer product are using FR4 due to cost. Of course you can't expect too much.
What considerations should I bear if I want to have required response from the filter at higer frequencies say 6,8,12GHz how will FR4 behave there
basically I need specific rejection from the filter at these frequencies and it should have min. insertion loss in the pass band around 2.4Ghz
