cadence + skill + help
Hi everybody,
Recently, I have been learning Cadence SKILL. I experience the followiing problem. If you happen to know this, would you please give me a hint. Thank you.
1.How to delete thoes varaibles created by the procedure from last run?
During debug period, the same but modified procedure will be reloaded because of the modification. Before I call the modified procedure, those variables used in the last run are still there, which creates troouble some time. Is there any way, after each run, those variables will be emptied. I tried "clear" "quit". Right now, I have to exit Cadence and re-enter it to kill all the previous variable. Too time-consuming. Is there any better way? Thank you.
2. Is there any good SKILL debug tutorial?
Thank you.
