[SOLVED] how to delete simulation files in cadence 55nm to free space
Ahmad24A
Newbie level 6
Hi everyone,
I have a problem that when i run my schematic diagram of circuit i faced a memory warning during the simulations going on. I want to ask that how to delete old simulations files to free up space. If anyone know this kindly help.
Thanks
you have to go to your home directory and delete .tran files if you are doing transient.
--- Updated ---
Also, you can go to options and select selected nodes instead of publishing all the node voltages and currents.
In the past I used to make / reuse little shell scripts that would "ream out" all simulations under the project_home.
You just need to know where the default (or explicit) run data piles end up
