Hello friends!
I'm working to a design with registered outputs and I want to map (pack) the flip-flops in IOB flip-flops.
Please tell me how to set up Xilinx fot this!
Thank you!
There are several ways to define such registers.
In ISE, inside the project setings in "Implement Design" properties : "Map properties" set proper type in "Pack I/O registers/Latches into IOB's". This is a global definition and you need to check if the result is proper.
But there are possibility to place individual registers into IOB:
In VHDL design file, if registers instancies are known you can place:
# Place register into an IOB/ILOGIC/OLOGIC
INST "<register_name>" IOB=TRUE;
It is possible to use atributes:
attribute IOB : string
attribute IOB of <port_name>: signal is "TRUE";
Te same you can have using UCF constraints inside ucf file.
The style of codig depends from project requirements.
It is always preferable to apply global constraints for these type.
# -pr i|o|b Pack internal flops/latches into input (i), output (o),
# or both (b) types of IOBs.
