I extract hsim netlist using CIW=>EXPORT=>CDL.
I have some model view which name is "hsimmodel" for some big analog circuits.
I want to replace the "schematic" view with "hsimmodel" view when extract netlist.
I create .simrc & si.ini file in my run directory, and add the "simViewList" in these files.
But it doesn't work.
Does anybody can tell me how to implement the view replacement?
I do not really understand your intention. Can you provide a portion of the netlist you wanted? Basically when dealing with netlist export, you should modify the CDF of the component to meet your requirement.
Re: How to define my own simViewList when extract cdl netlis
Thanks for your reply.
From your ID, I'm thinking we graduated from the same universaty
The problem has already solved after I changed the parameter simviewlist to cdlsimviewlist.
Thanks again~
