how to define a pins floating status?
Areky_qin
Full Member level 1
hi, guys, when u simulation your schematics, how to define a pins floating status?
you know, if a pins is floating, then hspice can report error information for there is no dc path from this pin to GND, then how to define this status? used a large resistors or cap?and what's the status of this pin? or an uncertain status? how do this status influence the circuit system?
Regards
Areky Qin
None DC path doesn't because of floating pins in most cases.
for DC path problem, i always put 1Gohm resistance to ground, however, in some cases, you should be careful with this connection, since it may lead to strange results.
i don't think it is a big problem for floating pins, because simulator can tolerate floating pins if it doesn't affect the circuit
