how to cutoff charger when the battery is fully charge
mprower
mn13811-g
I've spent the better part of this morning looking for the Panasonic transistor mentioned in the title for this project, and I found that it was discontinued in 2005. Unfortunately, I've already orded all the other parts. Does anyone know where I can this part or a suitable replacement?
mn13811
I can offer this part in China. How many do you want? Kindly let me know.
Ken(sales@flypcb.com)
panasonic mn13811-g
''The MN1380 series are elements that monitor the power
supply voltage supplied to microcomputers and other LSI
systems and issue reset signals for initializing the system
after the power is first applied or for preventing runaway
operation when the supply voltage fluctuates.''
And so depending on the application needed it’s possible to replace it with other circuits, some examples: LTC1440/LTC1442, or LMP7300
http://www.ortodoxism.ro/datasheets/lineartechnology/144012fa.pdf
See also here
http://www.analog.com/UploadedFiles/Application_Notes/783694550AN139.pdf
http://www.icbase.com/pdf/MRP/MRP02680501.pdf
panasonic mn13811 g
Ken(sales(at)flypcb.com)
I only need one.
As for the substitutes, I don't know enough to make them work. Any suggestions in that area?
mn13811-2
To choose a substitute you need to know the application for...:D
Re: Panasonic MN13811-G
In the schematics, MN13811 compare the supply voltage to an internal reference. The output low level signal will trigger the flash circuit.
There are some solutions to replace the circuit, see for example a possible replacement using LTC1440 or even some bipolar transistors... :D
    mprower
thanks. I think I'll be going with the LTC1440 option.
If you want to consider to change the under voltage level, actually it’s 2.4V, you need to recalculate resistors Ra and Rb.
That really helps. Now I could use 1.2v rechargeable batteries. What would be a good cutoff point if the system is normally at 2.4v, then? 1.8?
As you can see, for a single NiMH cell
The charging voltage is in the range of 1.4-1.6 V/cell. A fully charged cell measures 1.35-1.4 V (unloaded), and supplies a nominal average 1.2 V/cell during discharge, down to about 1.0-1.1 V/cell (further discharge may cause permanent damage).
That's why for two cells you may consider cuttoff point at 2-2.1V.
Right. So if I leave Rb as a 4.7M, I can make Ra a 3.3M and it will work?
For a 2V cutoff voltage yes, this is the right value. Anyway in my opinion a 2.1-2.2V it’s more suitable in the case you want to have enough power in the batteries to make this circuit work. So maybe a 3.9M resistor for Ra will do the trick…
Ok. Thanks for all the help.
Panasonic MN13811-G
so mprower, have you tried the circuit and does it works? does the led blink when the voltage is below 2.1v?
Panasonic MN13811-G
ltc1440 only works when 2v input is there. so what if the preset voltage is 1.2v. are there any better subtitute?
