How to create folder at a specified path by using c++ ?
ehsanelahimirza
Full Member level 6
foldering in c++
hi
plz tell me how to create folder by using c++ at a specified path
Re: foldering in c++
U can use system() function to create folder.
System function is used to execute dos commands from a program in Turbo C
e.g.
system("md MyFolder");
it will create a folder is the current working directory
hi
which libraries r to b included for this system function
i mean header files
thanks
foldering in c++
hi
in windows platform use CreateDirectory
nothing is working
plz tell me how to do this foldering
Hi All,
This is a working code. The library tobe included is dos.h. Please use turboC compiler. The operation system used is windows only.
#include<stdio.h>
#include<dos.h>
int main()
system("mkdir Myfolder");
foldering in c++
hi
where r u programming?
dos, linux, windows??????
operating systern is windows XP.
That will surely work in DOS also.
Added after 8 minutes:
It will work in linux also. Here the library to be included in stdlib.h
#include<stdlib.h>
int main()
#include<stdlib.h>
int main()
thanks
its working
a good thing that when u give space between some name it will create another folder with the name after space i.e. it takes space as end of folder name and start of new one.
also it is generating folder at any specified path
like
system("mkdir c:\\newfolder")
Check it in cpluplus.org . it is goog site
#include <stdlib.h>
int main()
int i;
for(i=0;i<10;i++)
system ("mkdir %d",i);
1.i need to create many folder each name depending on variable is it possible to create with the above code
2.can u suggest me some metod to create many folders
the above code i used in visual c++ compiler in win xp
Here is the example which works indpendent of platform
mkdir : Creates a directory.
Syntax:
int mkdir(const char *path);
Prototype in:
dir.h
Remarks:
mkdir creates a new directory from the given
path name path.
Return Value:
mkdir returns the value 0 if the new directory
was created.
On error, a value of -1 is returned, and the
global variable errno is set to one of the
following values:
Setting Description
EACCES Permission denied
ENOENT No such file or directory
Portability:
mkdir is available on UNIX System V, though it
takes an additional file-mode parameter.
Example:
#include <stdio.h>
#include <conio.h>
#include <process.h>
#include <dir.h>
int main(void)
int status;
clrscr();
status = mkdir("asdfjklm");
(!status) ? (printf("Directory created\n")) :
(printf("Unable to create directory\n"));
getch();
return 0;
the compiler for windows is visual and turbo c
which r used for linux
