How to create an IP core based on a project in ISE?
Cesar0182
Member level 5
Greetings ... a couple of days ago I have been doing a project in ISE 14.5 and for this I need to create an IP that is based on a small project (programmable clock) that I have also implemented in ISE 14.5. I would like to know if it is possible to package the small project in an IP?
I leave attached the source code of the top file.
`timescale 1ps/1ps
module top_mmcme2
      // SSTEP is the input to start a reconfiguration.  It should only be
      // pulsed for one clock cycle.
      input    SSTEP,
      // STATE determines which state the MMCM_ADV will be reconfigured to.  A
      // value of 0 correlates to state 1, and a value of 1 correlates to state
      // 2.
      input    STATE,
      // RST will reset the entire reference design including the MMCM_ADV
      input    RST,
      // CLKIN is the input clock that feeds the MMCM_ADV CLKIN as well as the
      // clock for the MMCM_DRP module
      input    CLKIN,
      // SRDY pulses for one clock cycle after the MMCM_ADV is locked and the
      // MMCM_DRP module is ready to start another re-configuration
      output   SRDY,
      output   LOCKED,
      // These are the clock outputs from the MMCM_ADV.
      output   CLK0OUT,
      output   CLK1OUT,
      output   CLK2OUT,
      output   CLK3OUT,
      output   CLK4OUT,
      output   CLK5OUT,
      output   CLK6OUT,
      input [15:0] i_mmcm_ctrl
   // These signals are used as direct connections between the MMCM_ADV and the
   // MMCM_DRP.
   (* mark_debug = "true" *) wire [15:0]    di;
   (* mark_debug = "true" *) wire [6:0]     daddr;
   (* mark_debug = "true" *) wire [15:0]    dout;
   (* mark_debug = "true" *) wire           den;
   (* mark_debug = "true" *) wire           dwe;
   wire           dclk;
   wire           rst_mmcm;
   wire           drdy;
	reg				current_state;
	reg [7:0]		sstep_int ;
	reg				init_drp_state = 1;
   // These signals are used for the BUFG's necessary for the design.
   wire           clkin_bufgout;
   wire           clkfb_bufgout;
   wire           clkfb_bufgin;
   wire           clk0_bufgin;
   wire           clk1_bufgin;
   wire           clk2_bufgin;
   wire           clk3_bufgin;
   wire           clk4_bufgin;
   wire           clk5_bufgin;
   wire           clk6_bufgin;
   assign CLKIN_ibuf = CLKIN;
   BUFG BUFG_IN (
      .O(clkin_bufgout),
      .I(CLKIN_ibuf)
   BUFG BUFG_FB (
      .O(clkfb_bufgout),
      .I(clkfb_bufgin)
   BUFG BUFG_CLK0 (
      .O(CLK0OUT),
      .I(clk0_bufgin)
   BUFG BUFG_CLK1 (
      .O(CLK1OUT),
      .I(clk1_bufgin)
   BUFG BUFG_CLK2 (
      .O(CLK2OUT),
      .I(clk2_bufgin)
   BUFG BUFG_CLK3 (
      .O(CLK3OUT),
      .I(clk3_bufgin)
   BUFG BUFG_CLK4 (
      .O(CLK4OUT),
      .I(clk4_bufgin)
   BUFG BUFG_CLK5 (
      .O(CLK5OUT),
      .I(clk5_bufgin)
   BUFG BUFG_CLK6 (
      .O(CLK6OUT),
      .I(clk6_bufgin)
   // MMCM_ADV that reconfiguration will take place on
   MMCME2_ADV #(
      // "HIGH", "LOW" or "OPTIMIZED"
      .BANDWIDTH("OPTIMIZED"),
      .DIVCLK_DIVIDE(1), // (1 to 106)
      .CLKFBOUT_MULT_F(6), // (2 to 64)
      .CLKFBOUT_PHASE(0.0),
      .CLKFBOUT_USE_FINE_PS("FALSE"),
      // Set the clock period (ns) of input clocks
      .CLKIN1_PERIOD(10.000),
      .REF_JITTER1(0.010),
      .CLKIN2_PERIOD(10.000),
      .REF_JITTER2(0.010),
      // CLKOUT parameters:
      // DIVIDE: (1 to 128)
      // DUTY_CYCLE: (0.01 to 0.99) - This is dependent on the divide value.
      // PHASE: (0.0 to 360.0) - This is dependent on the divide value.
      // USE_FINE_PS: (TRUE or FALSE)
      .CLKOUT0_DIVIDE_F(6),
      .CLKOUT0_DUTY_CYCLE(0.5),
      .CLKOUT0_PHASE(0.0),
      .CLKOUT0_USE_FINE_PS("FALSE"),
      .CLKOUT1_DIVIDE(3),
      .CLKOUT1_DUTY_CYCLE(0.5),
      .CLKOUT1_PHASE(0.0),
      .CLKOUT1_USE_FINE_PS("FALSE"),
      .CLKOUT2_DIVIDE(24),
      .CLKOUT2_DUTY_CYCLE(0.5),
      .CLKOUT2_PHASE(0.0),
      .CLKOUT2_USE_FINE_PS("FALSE"),
      .CLKOUT3_DIVIDE(24),
      .CLKOUT3_DUTY_CYCLE(0.5),
      .CLKOUT3_PHASE(0.0),
      .CLKOUT3_USE_FINE_PS("FALSE"),
      .CLKOUT4_DIVIDE(24),
      .CLKOUT4_DUTY_CYCLE(0.5),
      .CLKOUT4_PHASE(0.0),
      .CLKOUT4_USE_FINE_PS("FALSE"),
      .CLKOUT4_CASCADE("FALSE"),
      .CLKOUT5_DIVIDE(24),
      .CLKOUT5_DUTY_CYCLE(0.5),
      .CLKOUT5_PHASE(0.0),
      .CLKOUT5_USE_FINE_PS("FALSE"),
      .CLKOUT6_DIVIDE(36),
      .CLKOUT6_DUTY_CYCLE(0.5),
      .CLKOUT6_PHASE(0.0),
      .CLKOUT6_USE_FINE_PS("FALSE"),
      // Misc parameters
      .COMPENSATION("ZHOLD"),
      .STARTUP_WAIT("FALSE")
   ) mmcme2_test_inst (
      .CLKFBOUT(clkfb_bufgin),
      .CLKFBOUTB(),
      .CLKFBSTOPPED(),
      .CLKINSTOPPED(),
      // Clock outputs
      .CLKOUT0(clk0_bufgin),
      .CLKOUT0B(),
      .CLKOUT1(clk1_bufgin),
      .CLKOUT1B(),
      .CLKOUT2(clk2_bufgin),
      .CLKOUT2B(),
      .CLKOUT3(clk3_bufgin),
      .CLKOUT3B(),
      .CLKOUT4(clk4_bufgin),
      .CLKOUT5(clk5_bufgin),
      .CLKOUT6(clk6_bufgin),
      // DRP Ports
      .DO(dout), // (16-bits)
      .DRDY(drdy),
      .DADDR(daddr), // 5 bits
      .DCLK(dclk),
      .DEN(den),
      .DI(di), // 16 bits
      .DWE(dwe),
      .LOCKED(LOCKED),
      .CLKFBIN(clkfb_bufgout),
      // Clock inputs
      .CLKIN1(CLKIN_ibuf),
      .CLKIN2(),
      .CLKINSEL(1'b1),
      // Fine phase shifting
      .PSDONE(),
      .PSCLK(1'b0),
      .PSEN(1'b0),
      .PSINCDEC(1'b0),
      .PWRDWN(1'b0),
      .RST(rst_mmcm)
   // MMCM_DRP instance that will perform the reconfiguration operations
   mmcme2_drp #(
      // State 1 Parameters - These are for the first reconfiguration state.
      // Set the multiply to 6.0 with 0 deg phase offset, optimized bandwidth, input divide of 1
      .S1_CLKFBOUT_MULT(6),
      .S1_CLKFBOUT_PHASE(000_000),
      .S1_CLKFBOUT_FRAC(000),
      .S1_CLKFBOUT_FRAC_EN(0),
      .S1_BANDWIDTH("OPTIMIZED"),
      .S1_DIVCLK_DIVIDE(1),
      // Set clockout0 to a divide of 6.0 (unity gain), 0 deg phase offset, 50/50 duty cycle
      .S1_CLKOUT0_DIVIDE(6),
      .S1_CLKOUT0_PHASE(000_000),
      .S1_CLKOUT0_DUTY(50000),
      .S1_CLKOUT0_FRAC(000),
      .S1_CLKOUT0_FRAC_EN(0),
      // Set clockout 1 to a divide of 1, 0 deg phase offset, 50/50 duty cycle
      .S1_CLKOUT1_DIVIDE(1),
      .S1_CLKOUT1_PHASE(000_000),
      .S1_CLKOUT1_DUTY(50000),
      // Set clockout 2 to a divide of 2, 0 deg phase offset, 50/50 duty cycle
      .S1_CLKOUT2_DIVIDE(2),
      .S1_CLKOUT2_PHASE(000_000),
      .S1_CLKOUT2_DUTY(50000),
      // Set clockout 3 to a divide of 3, 0 deg phase offset, 50/50 duty cycle
      .S1_CLKOUT3_DIVIDE(3),
      .S1_CLKOUT3_PHASE(000_000),
      .S1_CLKOUT3_DUTY(50000),
      // Set clockout 4 to a divide of 4, 0 deg phase offset, 50/50 duty cycle
      .S1_CLKOUT4_DIVIDE(4),
      .S1_CLKOUT4_PHASE(000_000),
      .S1_CLKOUT4_DUTY(50000),
      // Set clockout 5 to a divide of 5, 0 deg phase offset, 50/50 duty cycle
      .S1_CLKOUT5_DIVIDE(5),
      .S1_CLKOUT5_PHASE(000_000),
      .S1_CLKOUT5_DUTY(50000),
      // Set clockout 6 to a divide of 10, 0 deg phase offset, 50/50 duty cycle
      .S1_CLKOUT6_DIVIDE(10),
      .S1_CLKOUT6_PHASE(000_000),
      .S1_CLKOUT6_DUTY(50000),
      // State 2 Parameters - These are for the second reconfiguration state.
      .S2_CLKFBOUT_MULT(7),
      .S2_CLKFBOUT_PHASE(000_000),
      .S2_CLKFBOUT_FRAC(000),
      .S2_CLKFBOUT_FRAC_EN(0),
      .S2_BANDWIDTH("OPTIMIZED"),
      .S2_DIVCLK_DIVIDE(1),
      // Set clockout 0 to a divide of 4.750, 0 deg phase offset, 50/50 duty cycle
      .S2_CLKOUT0_DIVIDE(7),
      .S2_CLKOUT0_PHASE(000_000),
      .S2_CLKOUT0_DUTY(50000),
      .S2_CLKOUT0_FRAC(000),
      .S2_CLKOUT0_FRAC_EN(0),
      // Set clockout 1 to a divide of 1, 45.0 deg phase offset, 50/50 duty cycle
      .S2_CLKOUT1_DIVIDE(1),
      .S2_CLKOUT1_PHASE(045_000),
      .S2_CLKOUT1_DUTY(50000),
      // Set clock out 0 to a divide of 1, 90.0 deg phase offset, 50/50 duty cycle
      .S2_CLKOUT2_DIVIDE(1),
      .S2_CLKOUT2_PHASE(090_000),
      .S2_CLKOUT2_DUTY(90000),
      // Set clockout3 to a divide of 1, 135.0 deg phase offset, 50/50 duty cycle
      .S2_CLKOUT3_DIVIDE(1),
      .S2_CLKOUT3_PHASE(135_000),
      .S2_CLKOUT3_DUTY(50000),
      // Set clockout4 to a divide of 1, 180.0 deg phase offset, 50/50 duty cycle
      .S2_CLKOUT4_DIVIDE(1),
      .S2_CLKOUT4_PHASE(180_000),
      .S2_CLKOUT4_DUTY(50000),
      // Set clockout5 to a divide of 1, 225.0 deg phase offset, 50/50 duty cycle
      .S2_CLKOUT5_DIVIDE(1),
      .S2_CLKOUT5_PHASE(225_000),
      .S2_CLKOUT5_DUTY(50000),
      // Set clockout6 to a divide of 1, 270.0 deg phase offset, 50/50 duty cycle
      .S2_CLKOUT6_DIVIDE(1),
      .S2_CLKOUT6_PHASE(270_000),
      .S2_CLKOUT6_DUTY(50000)
   ) mmcme2_drp_inst (
      // Top port connections
      .SADDR(STATE),
      .SEN(sstep_int[0]),
      .RST(RST),
      .SRDY(SRDY),
      // Input from IBUFG
      .SCLK(clkin_bufgout),
      // Direct connections to the MMCM_ADV
      .DO(dout),
      .DRDY(drdy),
      .LOCKED(LOCKED),
      .DWE(dwe),
      .DEN(den),
      .DADDR(daddr),
      .DI(di),
      .DCLK(dclk),
      .RST_MMCM(rst_mmcm)
		always @ (posedge clkin_bufgout or posedge SSTEP)
			if (SSTEP) sstep_int <=  8'h80;
			else  			sstep_int <= {1'b0, sstep_int[7:1]};
endmodule
Any help is welcome.
thanks dpaul ... excuse me how can you create the .ngc file in ISE? I do not find specific information.
You run the design through XST synthesis.
