[51] How to create a pulse in Keil C51 debugger
hithesh123
Full Member level 6
Full Member level 6
lax
I need to pulse a port low for 100usecs. Can I do it in Keil C51?
I was able to create a button using the toolbox. But don't know how to make it toggle.
Definitely you can do it in keil.
Use two functions for on time and off time. implement a timer for on and off period.
Example:
void PORT_on(void){
PORT |= 1;
void PORT_Off(void){
PORT &= 0;
int main(void){
PORT_Init();
while(1){
PORT_On();
timer(50u);
PORT_Off();
timer(50u);
Example:
void PORT_on(void){
PORT |= 1;
PORT &= 0;
int main(void){
PORT_Init();
while(1){
PORT_On();
timer(50u);
PORT_Off();
timer(50u);
I am talking about debugger.
While debugging, I need to make a port pin low. Instead of clicking on/off, i want to make it low for 100us.
