How to create a program in PIC16F877A to save password for Combination Lock using EMF
josh_world90
Newbie level 1
Hello, I'm a newbie here... I'm doing a project, "password door security". I need to program my pic to be able to change the password. I don't know how to continue... What's programmed on the password section seems to be wrong.
I've programmed till here... Some1 please help me..\ How to disable the "*" button.. I only want it to work as a button to enter the settings to change password.
//	Author				:Josh
/	Project				:Keypad door security
//	Project description	:PIC18F877A + 4x4 keypad + LCD are used to build a keypad door
//						 security system which will activate the relay and buzzer after
//						 a preset 4-digit password is entered.
//						 LCD will display **** when keypad is pressed.
//						 preset password for this program is 1234
//	include
#include <pic.h>
//	configuration
__CONFIG ( 0x3F32 );
//	define
#define	rs			RC0
#define	e			RC1
#define	led_red		RC2
#define led_yellow	RC3
#define	lcd_data	PORTD
#define relay		RB1
#define buzzer		RB2
//	function prototype
void delay(unsigned long data);
void send_config(unsigned char data);
void send_char(unsigned char data);
void e_pulse(void);
void lcd_goto(unsigned char data);
void lcd_clr(void);
void send_string(const char *s);
void clearrow1(void);
void clearrow2(void);
void clearrow3(void);
void clearrow4(void);
void scancolumn1(void);
void scancolumn2(void);
void scancolumn3(void);
void scancolumn4(void);
void beep_once(void);
void beep_twice(void);
void beep_ten(void);
void password_change(void);
//	global variable
unsigned char password_count=0;
unsigned char keyin_char[5];				// Declare an array to stall the 4-digit key in password
unsigned char stalled_char[5]="1234";		// Declare an array to stall the 4-digit desired password
//	main function
void main(void)
	ADCON1=0b00000110;	//set all portA pins as digital I/O
	TRISA=0b11001111;	//clear bit 4&5 portA as output and set the rest as input
	TRISB=0b00000000;	//set portB as output
	TRISD=0b00000000;	//set portD as output
	TRISC=0b11110000;	//set bit4-7 portC as input(connected to 4 row of keypad)
	TRISE=0b00000000;	//set portE as output
	PORTC=0;
	PORTD=0;
	relay=0;
	buzzer=0;
	led_yellow=0;
	led_red=0;
	here:
	send_config(0b00001001);	//clear display at lcd
	send_config(0b00000010);	//Lcd Return to home
	send_config(0b00000110);	//entry mode-cursor increase 1
	send_config(0b00001100);	//diplay on, cursor off and cursor blink off
	send_config(0b00111000);	//function
	lcd_clr();							//clear LCD
	delay(1000);						//delay
	lcd_goto(0);						//initial display
	send_string("PLEASE ENTER");		//Display "PLEASE ENTER" on lcd
	lcd_goto(20);						//Display on 2nd line
	send_string("4-DIGIT PASSWORD");	//Display "4-DIGIT PASSWORD" on lcd
	while(1)
	{											//keypad scanning algorithm
			clearrow1();						//Clear 1st output pin and set the others
			scancolumn1();						//scan column 1-4
			clearrow2();						//Clear 2nd output pin and set the others
			scancolumn2();						//scan column
			clearrow3();						//Clear 3rd output pin and set the others
			scancolumn3();						//scan column
			clearrow4();						//Clear 4th output pin and set the others
			scancolumn4();						//scan column
			if(password_count==4)
				password_count=0;
				if((keyin_char[0]==stalled_char[0])&&(keyin_char[1]==stalled_char[1])&&
					(keyin_char[2]==stalled_char[2])&&(keyin_char[3]==stalled_char[3]))	//compare the keyin value with stalled value to test whether password is correct
					lcd_clr();						//clear lcd
					lcd_goto(0);
					send_string("SUCCESS!");		//display SUCCESS
					led_yellow=1;					//yellow light on //RC3
					relay=1;						//relay on        //RB1
					beep_once();					//beep one time
					delay(1500000);						//delay
					relay=0;						//relay off (door closed)
					led_yellow=0;					//off led yellow
					beep_ten();						//beep ten time
					goto here;
					while(1);						//infinity loop
				else
					lcd_goto(0);
					send_string("ERROR!");			//display ERROR!
					led_red=1;						//red light on
					beep_twice();					//beep two time
 					delay(150000);					//delay
					led_red=0;						//red light off
					goto here;
//	scanning functions
void clearrow1(void)			//clear the 1st row and set the others
	RE1=0;						//RE1,RE0, RA5 and RA4 are the output pins from PIC which connect to 4 pins of keypad
	RE0=1;
	RA5=1;
	RA4=1;
void clearrow2(void)			//clear the 2nd row and set the others
	RE1=1;
	RE0=0;
	RA5=1;
	RA4=1;
void clearrow3(void)			//clear the 3rd row and set the others
	RE1=1;
	RE0=1;
	RA5=0;
	RA4=1;
void clearrow4(void)			//clear the 4th roe and set the others
	RE1=1;
	RE0=1;
	RA5=1;
	RA4=0;
	if(RA0==0)							//if key '1' is being pressed
		while(RA0==0)continue;			//waiting the key to be released
		if(password_count==0)lcd_clr();	//Clear the LCD if the key is the 1st password
		lcd_goto(password_count);		//The cursor of LCD points to the column equivalent to the value of password_count variable
		send_char('*');					//Display the symbol '*' at LCD
		keyin_char[password_count]='1';	//Stall the '1' value at the keyin_char array
		password_count+=1;				//increase the Password_count variable's value by 1 and the result stall back to the variable
		beep_once();
	else if(RA1==0)							//if key '2' is being pressed
		while(RA1==0)continue;			//waiting the key to be released
		keyin_char[password_count]='2';	//Stall the '2' value at the keyin_char array
		beep_once();
	else if(RA2==0)						//if key '3' is being pressed
		while(RA2==0)continue;			//waiting the key to be released
		keyin_char[password_count]='3';	//Stall the '3' value at the keyin_char array
		beep_once();
	else if(RA3==0)						//if key 'A' is being pressed
		while(RA3==0)continue;			//waiting the key to be released
		keyin_char[password_count]='A';	//Stall the 'A' value at the keyin_char array
		beep_once();
	if(RA0==0)							//if key '4' is being pressed
		keyin_char[password_count]='4';	//Stall the '4' value at the keyin_char array
		beep_once();
	else if(RA1==0)							//if key '5' is being pressed
		keyin_char[password_count]='5';	//Stall the '5' value at the keyin_char array
		beep_once();
	else if(RA2==0)						//if key '6' is being pressed
		keyin_char[password_count]='6';	//Stall the '6' value at the keyin_char array
		beep_once();
	else if(RA3==0)						//if key 'B' is being pressed
		keyin_char[password_count]='B';	//Stall the 'B' value at the keyin_char array
		beep_once();
	if(RA0==0)						//if key '7' is being pressed
		keyin_char[password_count]='7';	//Stall the '7' value at the keyin_char array
		beep_once();
	else if(RA1==0)						//if key '8' is being pressed
		keyin_char[password_count]='8';	//Stall the '8' value at the keyin_char array
		beep_once();
	else if(RA2==0)						//if key '9' is being pressed
		keyin_char[password_count]='9';	//Stall the '9' value at the keyin_char array
		beep_once();
	else if(RA3==0)						//if key 'C' is being pressed
		keyin_char[password_count]='C';	//Stall the 'C' value at the keyin_char array
		beep_once();
	if(RA0==0)						//if key '*' is being pressed
		keyin_char[password_count]='*';	//Stall the '*' value at the keyin_char array
		beep_once();
		password_change();
	else if(RA1==0)						//if key '0' is being pressed
		keyin_char[password_count]='0';	//Stall the '0' value at the keyin_char array
		beep_once();
	else if(RA2==0)						//if key '#' is being pressed
		keyin_char[password_count]='#';	//Stall the '#' value at the keyin_char array
		beep_once();
	else if(RA3==0)						//if key 'D' is being pressed
		keyin_char[password_count]='D';	//Stall the 'D' value at the keyin_char array
		beep_once();
//	General Purpose	functions
	for( ;data>0;data-=1);
	buzzer=1;						//buzzer on
	delay(8000);
	buzzer=0;						//buzzer off
	delay(8000);
	delay(13000);
	delay(8000);
void beep_ten(void)
	delay(8000);
	delay(8000);
	delay(8000);
	delay(8000);
	delay(8000);
	delay(8000);
	delay(8000);
	delay(8000);
	delay(8000);
	delay(8000);
	delay(8000);
	delay(8000);
	delay(8000);
	delay(8000);
	delay(8000);
	delay(8000);
	delay(8000);
	delay(8000);
	delay(8000);
//	LCD	functions
	rs=0;								//clear rs into config mode
	lcd_data=data;
	delay(50);
	e_pulse();
	rs=1;								//set rs into write mode
	lcd_data=data;
	delay(50);
	e_pulse();
void e_pulse(void)
	e=1;
	delay(50);
	e=0;
	delay(50);
 	if(data<16)
	 	send_config(0x80+data);
	else
	 	data=data-20;
		send_config(0xc0+data);
void lcd_clr(void)
 	send_config(0x01);
	delay(50);
	unsigned char i=0;
  	while (s && *s)send_char (*s++);
	lcd_goto(0);
	send_string("Please Enter");		//display SUCCESS
	send_string("U'r Old Password:");	//Display "6-DIGIT PASSWORD" on lcd
		while(password_count<5)
				password_count=0;
					lcd_goto(0);
					send_string("Now enter");		//display SUCCESS
					send_string("U'r New Password:");	//Display "6-DIGIT PASSWORD" on lcd
					while(password_count<4)
					 for (int n=0;n<4;n++)
					 stalled_char[n]=keyin_char[n];
				     lcd_goto(0);
				     send_string("Password Changed!");		//display SUCCESS
				else
					lcd_goto(0);
					send_string("Err, Please press");			//display ERROR!
					send_string("'*'to try again!");	//Display "6-DIGIT PASSWORD" on lcd
					delay(200);						//Delay for seconds
Hi josh_world90,
please dont put whole code here..
Rather you should explain the problem briefly.
thank you.
Actually, there is nothing wrong with posting your entire code listing, however I would suggest enclosing your code in CODE tags, using the CODE tag button (#) under "Go Advanced" or simply upload your code using the features under "Go Advanced".
Doing so would make examining, debugging and replying to your posting more convenient.
You mention the password code section seems to have issues. Can you elaborate on what exactly these issues are?
Concerning the "*" button, you can effectively disable the button by implementing a state or flag variable which is only set active in a particular section of code, the button's routine can then check to see if the state/flag variable is set before executing the button handler code.
BigDog
