How to Create a folder on SD card in FAT32 system using Microcontroller
ravi1488
Member level 3
Member level 3
India
Hi ,
How to create a folder on SD card using Microcontroller ? I have implemented a FAT32 system on my SD card. I can do normal read/write operations. Also I am able to create normal .txt, .xls files etc. But how I can create a folder?
I am using ATmega32 at 16 MHz speed
Post your code. Which compiler are you using? Are you using any libraries for SC card code. If yes, there will be functions for directory creation like f_mkdir(), etc...
I dont have any function to make directory. Yes but I have a function to write a file which creates file if required.
Two options:
- use a FAT32 library that includes subdirectory managment
- make your own library functions, referring to the FAT32 specification downloadable from Microssoft
