I am exporting BRD file in allegro to dxf but the problem I am facing is that I am unable to see pads in top and bottom also shapes are showing as just unfilled areas in DXF.
Somebody please guide through the process of exporting to DXF in allegro.
In allegrow, At the DXF convertion window, one option is there. PADs and ETches in Black colur or not like that. If it is enabled means disable those things, and select the option which give different colors for different map layers.
