rohini.embsystem
if i m using a temp sensor which will gimme the output in degree centigrade (accuracy is 0.1 D.C). i m using ADC to convert the o/p of sensor. 4 multiplexed 7 segments are used for display of o/p. if variable unsigned char TEMP_OUT is used to get the sensor o/p. so it's range will be 0-255. if sensor is giving o/p 100.0 so how this can store & convert the 1000 value if it's max range is 255. If i m declaring the variable as unsigned int TEMP_OUT then can it convert the value 100.0(rather 1000)
