How to convert Single Cycle Processor to Pipelined Processor (no hazard unit)
comp_engineer
Newbie level 5
Newbie level 5
Hi everyone
I'm working on converting a Single Cycle MIPS Processor I wrote in Verilog HDL into a Pipelined MIPS Processor.
I'd just like some detailed guidance, programmatically speaking, about how I should go about this.
I understand the main difference between the Single Cycle and the Pipelined Processors is the addition of the "Stage Registers" for the 5 stages of the Pipeline (Fetch, Decode, Execute, Memory, Writeback), otherwise the rest of the Processor is very similar, it even has the same control unit. Please don't use advanced lingo, I'm only a student and the use of such words would only confuse me further.
I've included design schematics of my Single Cycle and Pipelined Processors as attachments.
Here are some specific questions I have:
How should I insert a register in my top level, like for example for the fetch stage, in order to insert an intermediary stage registerIF_ID between the Fetch and Decode stages, do I just feed the outputs of Register File, SignExtend, and PCPlus4 into an instantiated register and output are the new signals InstructionD, SignImmD, and PCPlus4D, etc.
Do I need to run the control signals (such as RegWrite, MemWrite, ALUControl, etc...as shown in the diagram) through a register also? If so, do I feed each individual signal through a register (like a 1 input 1 output register)or shall I just make one big 7 input, 7 output register for the control unit for the decode stage, since the control signals come into play at the decode stage.
Here is the way I have currently done so, please tell me if this way is correct or wrong or what other method do you believe is better or more straightforward:
This is the Register Module, I am instantiating for the Stage Registers
module Register#(parameter DATA_IN=32, DATA_OUT=32)
					 (clk, reset, in1, in2, out1, out2);
input clk, reset;
input [DATA_IN-1:0] in1;
input [DATA_IN-1:0] in2;
output reg [DATA_OUT-1:0] out1;
output reg [DATA_OUT-1:0] out2;
wire clk, reset, in1, in2; //these are wires to connect
							//the register to control
always@(posedge clk or posedge reset) begin
	if(reset) begin
		out1 <= 32'b0;
		out2 <= 32'b0;
	end
	else begin
		out1 <= in1;
		out2 <= in2;
	end
end
endmodule
This is my top level where I call all the module and essentially layout my processor
				Fetch Stage
	Processor Reads the instruction from instruction memory
InstructionMemory iMem(PC, Instr);
ProgramCounter ProgCounter(clk, reset, PCnext, PC);
PCPlus4 PCP4(PC, PCPlus4);
//pipelined register
Register regIFID(clk, reset, Instr, PCPlus4, InstrD, PCPlus4D);
assign PCBranch = PCSrc ? (SignImm + PCPlus4) : PCPlus4;
//assign PCnext = Jump ? ({6'b0, Instr[25:0]} + PCPlus4) : PCBranch;
assign PCnext = Jump ? ({SE, Instr[25:0]} + PCPlus4) : PCBranch;
This code is modeled exactly as how the design schematic is layed out so Please tell me what am I doing right or wrong?
I know this is kind of a vague question, so please ask me if I need to clearify anything or add more information.
Any help or assistance would be much appreciated.
