How to convert from gerber to postscript?
jgorsk
Member level 3
Member level 3
gerber magic post
I am looking for a method of converting
gerber files into postscript.
Can anybody help me with this?
convert gerber to ps
try this link:
hxxp://www.lavenir.com/Download/download.html
there is a Gerber to postscript Converter that works olso on network printer.
hi,
here you can find an evaluation copy of Gerber Magic
"From Gerber to PDF/PostScript"
hxxp://www.bronzware.com/GerbMagic/index.htm
you also can install Adobe Acrobat, then you can have a PDFwriter printer. use this printer, you can have your own pdf files.
The simplest way is to install a HP Postscript printer driver, eg HP Laserjet 5si PS. Set it up to print to file. When you print your gerber, the print driver will prompt you for a file name and generate a postscript output.
Yeah, I do that like drwho78 said too.
Printout 1:1 from CAM software to PS printer driver.
The problem with generating postscript by printing
on PS printer is that you cannot get
1:1 ratio. PS printer drivers decrease size
of the printout. Decrease is about 0,5 - 1%.
Please check it.
For me Gerber Magic is O.K.
thanx for all the info guys
runner100
