how to convert degree minutes seconds into decimal value
engineer khan
Member level 3
Member level 3
Hello All dears,
I m working to design a device that take location lat long, i successfully obtained lat-long but the problem is that lat-long value is in degree/minutes/seconds i need it in decimal number, let suposed i get lat=2450.1234 which in decimaol is "24.83336761111111" how can i go from first value to the latter one.....i sought on net where i found a formula degree/+minutes/60+second/3600 ,the question is that how to covert 2450.1234 to 24.83336761111111 in c coding i m using pic18f mikroc compiler
void LongToTime (long Ticks, char * h, char * m, char * s)
 while (Ticks--)
s++;
if (*s == 60) {*s = 0; *m++;}
if (*m == 60) {*m = 0; *h++;}
This is untested. Wrote in 10 seconds after lunch (intelligent descreased greatly).
Few minutes later...
Ticks = 60*60*h + 60*m + s;
