How to control motor with sensor ?
bianchi77
California
Guys,
I'm using AT89LV55 and Keil
with this code the motor always "ON" even the sensor is OFF
sensor active H and Motor active L
Thanks
#define TRUE 1          //some defines
#define FALSE 0
// Define the keypad start
sbit sensor1=P0^0;  // Sensor 1
sbit motor1=P0^1;  // Motor 1
void main()
motor1=TRUE;
sensor1=FALSE;
 while(1)
   if (sensor1=FALSE) // if there's nothing at the sensor
	   motor1=TRUE;  // deactivated the relay to turn off motor
   else
	   motor1=FALSE; // activated the relay to turn on motor
   }//end of while
hi what a pblm occured in your coding?
what type of sensor you r using?
and cgheck ur coding
if (sensor1=FALSE) is an assignment statement
write if (sensor1==FALSE) and compile.
with regards
with regards
I'm using PIR sensor..
use adc channel.
