How to construct a high gain antenna for 160MHz?
deepak007
Member level 5
hello
i have purchased a WOUXUN transceiver134 to 174 MHz. but, the seller gave me a 400 to 470 MHz high gain antenna. will there be any change in performance? can i make my own antenna using a coat hanger cut to the correct 1/4 length? then how can i connect to the SMA FEMALE CONNECTOR.i mean how can i connect a whip to SMA CONNECTOR. please give me some tips.
corner reflector
Everyone knows that a coat hanger is an excellent antenna. Make sure that it is not made from wood.
Your high gain antenna is for a different band. I would not expect it to work well in a band different from the intended band. Do you think differently?
It sounds like you want to make a monopole. That implies a groundplane, the bigger the better. The flange on the sma connects to the groundplane and the center contact connects to the coat hanger.
    deepak007
Re: ANTENNA HELP
My best results have been with plastic coathangers drilled out 1/4 wave and a metal rod glued to the interior, the base of the coathanger can be done like-wise to use as a tuning stub. coax may be soldered to the the first rod and the shield can be glued to the outside, be sure to use epoxy, wood glue as a well as a wood coathanger won't work.
SiGiNT
Re: ANTENNA HELP
Seriously, just in case you are serious, get a ham 2 metre rubber-ducky antenna and a right angle BNC to SMA adaptor.
SiGiNT
Re: ANTENNA HELP
The really important feature is the color of the coat hanger. I have one survey that says that pink is the only color to use.
Re: ANTENNA HELP
thank you very much gentlemen for your suggestions! i want to use the transceiver on 160MHz. i have purchased a brass brazing rod from a welding supply store.i have cut it to 18 inches. and i am using a rolled up copper sheet as a ground plane. can anybody give any idea to construct a high gain antenna for 160MHz? for ex. coil loaded or any other type.
thanku once again.
Re: ANTENNA HELP
You might consider a corner reflector as an easy way to increase the gain. Kraus is a good source for guidance.
You do not say what you consider to be "high" gain.
Re: ANTENNA HELP
thanku once again.
You will not get "high gain" by using this 18 inch rod! This might be put into work as a 1/4 wave radiator, and if you mount it on a metal surface you end up with roughly 0 dB gain!
The coil will only add losses to the antenna so that is no good!
A 5/8 lambda radiator will offer some gain, but to get "high-gain" you really need something bigger, and probably a rotator as the antenna will be directive.
