How to connect a radio mixer for up-conversion
neazoi
Advanced Member level 6
Greece
Hello, a really basic question that confuses some of us.
An RF mixer has 3 ports:
LOSC
RF
IF
In DOWN-CONVERSION:
RF is the input
IF is the output
What about in UP-CONVERSION?
Which port should be the input of the low frequency signal and which one the output of the high frequency (produced) signal?
It might depend on the mixer - what are you using? If it is an active mixer then the RF input may be designed for lower signals so you would use the lowest level signal on the RF input. You have no choice of output - you only have one anyway.
Keith.
See this document
It connects the IF port as input and the RF as output for the up-conversion. I think it assumes passive diode mixers. Is it correct?
I am basically refer to double balanced diode mixers for microwaves
That paper seems to suggest it for a triple balanced mixer, but not double balanced, unless I have missed it. With a double balanced mixer I would always expect the output to be the IF pins, even if the output is higher than the RF/LO. You need to be careful of the frequencies that the mixer is designed for. Some can be a bit narrow and generally the IF frequency specification is lower than the RF/IF in the specifications.
Maybe ask on the RF forum there will be some experts on such things there.
Keith.
    neazoi
