Hi
I want to know if it is possiple to connect a microcontroller with MAX2830 and if this operation is achivable how to programme it using SPI and to transmitte data from microcontroller to and from the MAX2830 channels (please read the MAX2830 datasheet ) using MicroC languge. and thank you in advanced.
wow that is a quick responce !!!!!!!!!!!do you have other sulotions????? because i a need a way to connect a microcontroller with a IC like MAX2830 then connect it with my labtop using WIFI and thank you very much
great !!!
can i ask you something??????????? how did you know that MAX2830 is not designed for microcontrollers even it has SPI which is present in some microcontrollers ????
MAX2830 SPI interface is used for configuration (Gain, Filters...). Data path (Tx and RX) has different interface and require more complex analog signals on that interfaces. A microcontroller is not able to process such data.
do you have some ideas or website of connecting microcontroller with WIFI and then interface it with the computer because I am willing to do a project like WSN(wireless sensore networks) thank you . you have been a big help
