HOW to compare two phase width in same signal wire?
xworld2008
Full Member level 4
Full Member level 4
HOW to compare two phase width in same signal wire?(difference is ps level)?
_____________|—--|___________________|--------|_____________
--45ps-- ----50ps--------
any one have idea??
Thanks,
Sorry .. Should be pulse width. I want to measure the different of to pulse for a signal.
Measuring such short pulse widths is not easy. It typically requires some very high speed digital circuits. Not something for a novice.
A TDC chip would only get you down to around 20ps resolution so I suspect you need a custom device or custom circuitry. The TDC principles can possibly be used but you need even higher resolution. I have used Guide Technology boards in the past - they get down to 8ps. although the continuous ones get down to 2ps with averaging. This is fairly serious design to do that from scratch.
Keith
Keith
Hi Keith,
Thanks.. now i need a circuit to do it.
Search IEEE papers for TDCs (Time to Digital Converters) - it should give you some ideas about the techniques to use. Also, it is worthwhile searching for theses at the University of Oulu. They have done a lot of research for Noptel on laser rangefinders and as they were PhD or MSc theses the information is freely available. https://www.oulu.fi/english/
Keith
