how to code ADC voltage to LCD display?
caramelz
Junior Member level 2
hi i'm using mcc18 compiler. I need to display the voltage on my lcd (tc1602A) using microcontroller (PIC18f4520). I'm stuck after while(ADCON0bits.DONE), and i dunno how to display the value on LCD.
Please help!
#include <p18f4520.h>
#include <delays.h>
#include <stdlib.h>
	ADCON0=0b00000001;
	ADCON1=0b00000111;
	ADCON2=0b10000010;
Delay10TCYx(5);
ADCON0bits.GO = 1;		// Start ADC
while(ADCON0bits.DONE);	// ADC completed?
Where is LCD Code? You have to get the values in ADRESH and ADRESL into a float or int variable and convert that float ot int value to string and display the sting on LCD.
Post full code in syntax tags.
I need a range from 0 to 5V in 2decimals place on the LCD
I dont get
#include <delays.h>
#include <stdlib.h>
void Init_LCD(void);
void W_ctr_8bit(char);
void W_data_8bit(char);
#define LCD_DATA PORTD
#define LCD_RS PORTBbits.RB1
#define LCD_E PORTBbits.RB2
void main()
{       int result;
        char MESS[i]="Voltage:"
	ADCON0=0b00000001;
	ADCON1=0b00000111;
	ADCON2=0b10000110;
Delay10TCYx(5);
result = ADRESH;;
result>>=4;
PORTB=result;
for(i=0;i<8;i++)
W_data_8bit(Mess[i]);  // is to print text to LCD
Check this link. I have written a code there. My previous account was internetuser2k11 and 12.
https://www.edaboard.com/threads/254723/
https://www.edaboard.com/threads/253183/
Use that code. There is a small mistake in floattosting() function. I have fixed it here.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
//Function Prototypes
void floattostring(double FP_NUM);
//Sub Function
void floattostring(double FP_NUM) {
        double fpnumber;
        long int befdec, aftdec;
        fpnumber = FP_NUM;
        befdec = fpnumber;                      // Fractional part is truncated
                                                // 12.163456 becomes 12
        aftdec = fpnumber * 100;            // 12.163456 becomes 1216
        aftdec = aftdec - (befdec * 100);   // 1216 - 1200 = 16
        if (fpnumber < 1) {
                string[0] = '0';
                string[1] = '.';
                string[2] = (aftdec/10) + 48;
                string[3] = (aftdec/1)%10 + 48;
                string[4] = '\0';
        else if ((fpnumber >= 1) && (fpnumber < 10)) {
                string[0] = (befdec/1)%10 + 48;
                string[1] = '.';
                string[4] = '\0';
        else if ((fpnumber >= 10) && (fpnumber < 100)) {
                string[0] = (befdec/10) + 48;
                string[1] = (befdec/1)%10 + 48;
                string[2] = '.';
                string[3] = (aftdec/10) + 48;
                string[4] = (aftdec/1)%10 + 48;
                string[5] = '\0';
        else if ((fpnumber >= 100) && (fpnumber < 1000)) {
                string[0] = (befdec/100) + 48;
                string[1] = (befdec/10)%10 + 48;
                string[2] = (befdec/1)%10 + 48;
                string[3] = '.';
                string[4] = (aftdec/10) + 48;
                string[5] = '\0';
        else if ((fpnumber >= 1000) && (fpnumber < 10000)) {
                string[0] = (befdec/1000) + 48;
                string[1] = (befdec/100)%10 + 48;
                string[2] = (befdec/10)%10 + 48;
                string[3] = (befdec/1)%10 + 48;
                string[4] = '.';
                string[5] = (aftdec/10) + 48;
                string[6] = '\0';
        else if ((fpnumber >= 10000) && (fpnumber < 100000)) {
                string[0] = (befdec/10000) + 48;
                string[1] = (befdec/1000)%10 + 48;
                string[2] = (befdec/100)%10 + 48;
                string[3] = (befdec/10)%10 + 48;
                string[4] = (befdec/1)%10 + 48;
                string[5] = '.';
                string[6] = (aftdec/10) + 48;
                string[7] = '\0';
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
//Sub Function
        double fpnumber;
        fpnumber = FP_NUM;
        if (fpnumber < 1) {
                string[0] = '0';
                string[1] = '.';
                string[4] = '\0';
                string[1] = '.';
                string[4] = '\0';
                string[2] = '.';
                string[5] = '\0';
                string[3] = '.';
                string[5] = '\0';
                string[4] = '.';
                string[6] = '\0';
                string[5] = '.';
                string[7] = '\0';
Thanks i will try it asap. but how do i display in the LCD? or string is the one that display?
