sabrahermassi
Hello, i'm going to sesign a 3ph H-bridge to control a brushless motor and i'm wondering how can i choose the right mosfets in order to control my motor.
The moter that i'm using is a Turnigy L5055C-700 Brushless Outrunner 700kv having the following caracteristics:
Kv: 700rpm/V
Voltage: 11.1v~29.6v (3s~8s)
Max Power: 1600w
Max Current: 60A
Max Efficiency: 80% @ 35A
No load Current: 3.0A
Internal Resistance: 0.18
I'm using a Lipo batterie Turnigy 5000mAh 6S 30C Lipo Pack having the following specifications:
Minimum Capacity: 5000mAh
Configuration: 6S1P / 22.2v / 6Cell
Constant Discharge: 30C
Peak Discharge (10sec): 40C
and i'm going to use the IR2101 mosfet driver.
Can someone please explain to me the procedure to follow in order to choose the right mosfets ??? :-?
Kv: 700rpm/V
Max Power: 1600w
Max Current: 60A
