How to check the empty memory of HEX file for 89c51?
syrax
Full Member level 3
Full Member level 3
Memory problem
How can i see the empty memory of HEX file for 89c51
Re: Memory problem
sorry i meen how i can see when my RAM memory is full before upload it to chip , the chip is at89c51. Somethink like hex analizator :)) may be. Becouse the compiller make the HEX file without problems, but when upload it. It give a error.
Memory problem
for this purpose, you can set programmer to 89C52 and load hex file to its buffer.
and open [edit] buffer and check to see that code not beyond 4Kbyte.
(maximum alowable address is 0xFFF)
