how to check overflow of float number
userx51
Junior Member level 2
in C code, Microcontroller, how to find out if a x overflown?.
float x,y;
x=(y)*someval+z;
You can not find a variable was over flown but you can avoid it, if that was your series problem then do like this
Code C - [expand]
double temp;
if(temp = ((y)*someval+z) > MAX_FLOAT_VALUE)
of = 1;
else
x=(y)*someval+z;
better if you have doubt that its going to ovrflow then you shd use a double type....
