Register Log in
How to check LED Blinking then write data 6 Bits ? [mikro C]
boyguitar1
Member level 1
Hi Everybody
Can anyone help this case ? Now I have LED Blinking freq 1.2 Hz and
I need to check status during LED Blinking…. Is it blink or not ?
then let mikroC send data 6 bits to my VB.
Now I have wrote some code below by use PIC16F877.
But still not work....:sad:
void  Check_Blinking_LED()
      for(i=0;i<6;i++)
  analog_val = Adc_Read(1);      // Read analog from CH1
  Delay_ms(10);
  analog_val = ((analog_val *2000)/ 2046);
      Delay_ms (417);
    // 417 come from Time 830/2 ms = 415 ms
    // But use more 415 ms to check High and Low pulse.
      if (analog_val_LED_GREEN > 500)
      Usart_Write('H');
      else
      {Usart_Write('L');}
Form my code it will write H to VB ,write L to VB , …… (until 6 Bits)
So this my problem VB cannot detect.
My target:
If LED Blinking : mikro C must send HLHLHL or LHLHLH to my VB.
If LED Light : mikro C must send HHHHHH to my VB.
If LED Off : mikro C must send LLLLLL to my VB.
Or do u have other good idea ? please help..
Please help...
Thank in advance
BGT.
pmar_kpj
Member level 3
Romania
hi !
you read the analog value but procesing this signal after ~500ms.
try this:
for(i=0;i<6;i++)
Delay_ms(10);
Usart_Write('H');
else
{Usart_Write('L');}
Delay_ms (417);
boyguitar1
Member level 1
hi pmar_kpj
Thanks 4 ur suggestion.
but after testing Yeah!...it already can sent data 6 bits LLLLLL or HHHHHH /1 time.
it seem that cannot detect pulse signal high and low .....which what I want is HLHLHL or LHLHLH .
Can anyone help me please...or advice me to other idea you have.
Thanks..
BGT
pmar_kpj
Member level 3
Romania
hi!
try this:
for(i=0;i<6;i++)
Delay_ms(200);
if (analog_val_LED_GREEN > 750) //>~3.7V
Usart_Write('H');
if (analog_val_LED_GREEN < 250) //>~1.2V
Usart_Write('L');
if your led blink with 1.2 hz function writed up send to rs232 : LLL HHH LLL HHH ....
or to test if your function work connect the ch1 to 5V and receve HHHH....
connect ch1 to GND and receve LLLL.. (5 char per second)!
but for this you need to replace the 'for' instruction with infinite loop like: do { ...} while (1);
hanukaran
Junior Member level 2
hi boyguitar....can you teach me how to use this visual basic to show this led..currently im working on traffic light project....im using ATmega32.....can you teach me how to programme it
Toggle Sidebar
