How to change array index value according to each clock?
vasireddyrajesh3
Newbie level 6
i declared an ARRAY, i will get different outputs in each clock, so that out put i have to store in each index of an ARRAY,
for example for 1st clock if i get "10101010" that should be stored in first INDEX, for next clock if i get output as '00001101' this should be stored in second index value of ARRAY......... like that.
here is the sample code i written.....
type array_encoded_data is array ( 0 to 31 ) of std_logic_vector( 0 to 7);
signal array_encoded_sig : array_encoded_data ;
encoded_data is the output of 1 bit .like this i will get 8 bits from 0 to 7 loop,temp is 8 bit vector.
dout is 8 bit which changes in every clock, pi is 32 bit. so for each clock dout will change ,then encoded_data will also change..
for the 1st clock i am xor ing pi(0) with dout(i)
then for 2nd clock i am xor ing pi(1) with dout(i) ((dout is different in 2nd clock))
like that i want to store each 8 bit encoded_data in each index of ARRAY
if count= 0 then
for i in 0 to 7 loop
encoded_data := ((dout(i)) xor (pi(0)));
temp(i):=encoded_data;
end loop;end if;
array_encoded_sig(0)<=temp;
if count= 1 then
encoded_data := ((dout(i)) xor (pi(1)));
end loop;end if;
array_encoded_sig(1)<=temp;
any one help me regarding this.. thanks in advance.
You've got legal code there, but wouldnt it be easier to just to write:
  encoded_data := (dout(i)) xor (pi(count)));
end loop;
array_encoded_sig(count) <= encoded_data;
end loop;
Dear sir, Thanks for your help.
