-------------this is the top module---------------------------------------------------------------
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity top is
Port (
rst : in STD_LOGIC;
clk : in STD_LOGIC;
--------------camera signals----------------------------
pclk : in STD_LOGIC;
href : in STD_LOGIC;
vsync : in STD_LOGIC;
scl : inout STD_LOGIC;
sda : inout STD_LOGIC;
yin : in STD_LOGIC_VECTOR (7 downto 0);
yout : out STD_LOGIC_VECTOR (7 downto 0); --- pixel output at leds
-------------2*16 lcd signals----------------------------
rs : out std_logic;
rw : out std_logic;
d : out std_logic_vector (7 downto 0); --- matched pixels output at lcd
e : out std_logic;
-----------------Stepper signals-------------------------
step: out std_logic_vector(3 downto 0);
-----------------TFT signals-----------------------------
TP_PENIRQ : in STD_LOGIC;
TFT_CLK : out STD_LOGIC;
TFT_DISP : out STD_LOGIC;
TFT_DE : out STD_LOGIC;
TFT_EN : out STD_LOGIC;
LED_EN : out STD_LOGIC; ------- 100 Hz to 50 KHz
TFT_R : out STD_LOGIC_VECTOR (7 downto 0);
TFT_G : out STD_LOGIC_VECTOR (7 downto 0);
TFT_B : out STD_LOGIC_VECTOR (7 downto 0)
end top;
architecture Behavioral of top is
component cam is
Port ( rst : in STD_LOGIC;
clk : in STD_LOGIC;
cam_scl : inout STD_LOGIC;
cam_sda : inout STD_LOGIC;
cam_pclk : in STD_LOGIC;
cam_href : in STD_LOGIC;
cam_vsync : in STD_LOGIC;
cam_y : in STD_LOGIC_VECTOR (7 downto 0);
cam_o,cam_led : out STD_LOGIC_VECTOR (7 downto 0));
end component;
component compare is
Port ( rst,clk : in STD_LOGIC;
pclk,href,vsync : in STD_LOGIC;
c_yi : in STD_LOGIC_VECTOR (7 downto 0);
lcd_en,step_en: out STD_LOGIC;
match : out STD_LOGIC_VECTOR (13 downto 0);
c_yo,s_yo : out STD_LOGIC_VECTOR (7 downto 0));
end component;
component lcd is
port( lcden,clk : in std_logic;
din : in std_logic_vector (13 downto 0);
rs : out std_logic;
rw: out std_logic;
e : out std_logic);
end component;
component tft is
Port ( RST,CLK : in std_logic;
TFT_CY,TFT_SY : in STD_LOGIC_VECTOR (7 downto 0); -------- captured(cy) and stored(sy) value
TFT_B : out STD_LOGIC_VECTOR (7 downto 0));
end component;
component stepper is
port (sen: in std_logic;
clk: in std_logic;
step: out std_logic_vector(3 downto 0));
end component;
signal rst_lcd,rst_step,pclk_d,href_d,vsync_d,p_clk,h_ref,v_sync: std_logic:='0';
signal y,syo,cyo : std_logic_vector (7 downto 0):="00000000";
signal matchedpixels : std_logic_vector (13 downto 0):="00000000000000";
begin
-----------edge detector--------------------------
--------------rising edge detect--
p:process(clk)
begin
if (clk'event and clk='1') then
pclk_d <= pclk;
end if;
end process p;
p_clk <= (not pclk_d) and pclk;
h:process(clk)
begin
href_d <= href;
end if;
end process h;
h_ref <= (not href_d) and href;
--------------falling edge detect--
v:process(clk)
begin
vsync_d <= vsync;
end if;
end process v;
v_sync <= (not vsync) and vsync_d;
x1: cam port map (rst,clk,scl,sda,p_clk,h_ref,v_sync,yin,y,yout);
x2: compare port map (rst,clk,p_clk,h_ref,v_sync,y,rst_lcd,rst_step,matchedpixels,cyo,syo);
x3: lcd port map (rst_lcd,clk,matchedpixels,rs,rw,d,e);
x4: tft port map (rst,clk,tp_penirq,tft_clk,tft_disp,tft_de,tft_en,led_en,cyo,syo,tft_r,tft_g,tft_b);
x5: stepper port map (rst_step,clk,step);
end Behavioral;
library IEEE;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity cam is
clk : in STD_LOGIC;
end cam;
architecture cam2 of cam is
type state_type is(idle,start,frame0,ack0,frame1,ack1,frame2,ack2,frame3,ack3,frame4,ack4,frame5,ack5,stop);
signal state: state_type;
signal clki,clks: std_logic:='0';
signal i,j,k,l,m,n: integer:=23;
signal count1,frame,lcnt,pcnt: integer:=0;
signal sda_frame: std_logic_vector(23 downto 0):=(others=>'0');
signal ack: std_logic;
signal cled: std_logic:='0';
begin
divider_i2c:process(clk,rst) ---- clock to reach center of clki
begin
if (rst='1') then
count1 <= 0;
elsif(clk'event and clk='1') then --100 Khz
if (count1 = 499) then
count1<= 0;
clki <= not clki;
else
count1<= count1 + 1;
end if;
end if;
end process divider_i2c;
clks<= clki after 2.5 us;
cam_scl <= '1' when state=idle else
'1' when state = start else
'1' when state = stop else
clki;
i2c:process(rst,clks,state)
begin
if (rst = '1') then
sda_frame <=(others=>'1');
cam_sda <= '1';
ack <= '0';
state <= idle;
elsif (clks'event and clks='0') then
if (state= idle) then
state <= start;
elsif (state = start) then
cam_sda <= '0' after 4.5 us; -- start cond = scl =1 and sda = 1 to 0
if (cam_sda='0') then
state<= frame0;
end if;
elsif (state = frame0) then
sda_frame <= X"C01280"; -- soft reset
if (i=0) then
state <= ack0;
else
cam_sda <=sda_frame(i);
i<= i-1;
end if;
elsif (state=ack0) then
ack<= cam_sda;
if (ack='0') then
state<= frame1;
end if;
elsif (state = frame1) then
sda_frame <= X"C01420"; -- QCIF frame size (176x144)
if (j=0) then
state <= ack1;
else
cam_sda <=sda_frame(j);
j <= j-1;
end if;
elsif (state=ack1) then
ack<= cam_sda;
if (ack='0') then
state<= frame2;
end if;
elsif (state = frame2) then
sda_frame <= X"C01224"; -- (default setting) AGC enable, YCrCb mode, no AWB
if (k=0) then
state <= ack2;
else
cam_sda <=sda_frame(k);
k <= k-1;
end if;
elsif (state=ack2) then
ack<= cam_sda;
if (ack='0') then
state<= frame3;
end if;
elsif (state = frame3) then
sda_frame <= X"C01301"; -- (default setting) 16 bit format
if (l=0) then
state <= ack3;
else
cam_sda <=sda_frame(l);
l <= l-1;
end if;
elsif (state=ack3) then
ack<= cam_sda;
if (ack='0') then
state<= frame4;
end if;
elsif (state = frame4) then
sda_frame <= X"C0111C"; -- reduce fps
if (m=0) then
state <= ack4;
else
cam_sda <=sda_frame(m);
m <= m-1;
end if;
elsif (state=ack4) then
ack<= cam_sda;
if (ack='0') then
state<= frame5;
end if;
elsif (state = frame5) then
sda_frame <= X"C02900"; -- set to camera master mode
if (n=0) then
state <= ack5;
else
cam_sda <=sda_frame(n);
n <= n-1;
end if;
elsif (state=ack5) then
ack<= cam_sda;
if (ack='0') then
state<= stop;
end if;
elsif (state= stop) then
cam_sda <= '1' after 2.5 us;
end if;
end if;
end process i2c;
----------------------------------------------------1 hz clock divider to check pixel clock from camera on led
clk1hz:process (rst,cam_pclk)
variable cnt: integer:=0;
begin
if (rst='1') then
cnt := 0;
cam_led(0) <= '0';
elsif (cam_pclk'event and cam_pclk='1') then
if (cnt = 8864999) then -- 17.73 Mhz --- 1 hz clk
cnt := 0;
cled<= not cled;
cam_led(0) <= cled;
else cnt := cnt + 1;
end if;
end if;
end process clk1hz;
-------------frame count---------------------------------------
framecount: process(rst,cam_vsync)
begin
if (rst='1') then
frame<=0;
elsif (cam_vsync'event and cam_vsync='1') then
if (frame = 7) then
frame <= 0;
else
frame <= frame + 1;
end if;
end if;
end process framecount;
----------------line count---------------------------------------
linecount: process(rst,cam_href)
begin
if (rst='1') then
lcnt<=0;
elsif (cam_href'event and cam_href='1') then
if (lcnt = 144) then
lcnt <= 0;
else
lcnt <= lcnt + 1;
end if;
end if;
end process linecount;
capture:process (rst,cam_pclk,cam_vsync,cam_href,cam_y)
begin
if (rst='1') then
cam_o <= (others => '0');
cam_led(7 downto 1) <= (others => '0');
pcnt<=0;
if (frame=1 and cam_href='1') then
if (pcnt= 176) then
pcnt<= 0;
else
pcnt <= pcnt + 1;
end if;
end if;
if (lcnt>8 and lcnt <= 136 and pcnt >24 and pcnt<=152) then
cam_o <= cam_y;
cam_led(7 downto 1) <= cam_y(7 downto 1);
end if;
end if;
end process capture;
end cam2;
library IEEE;
entity compare is
match: out STD_LOGIC_VECTOR (13 downto 0);
end compare;
architecture compare2 of compare is
type rom_type is array (16383 downto 0) of std_logic_vector (7 downto 0); -- prestored image pixel data
signal rom :rom_type:=(
--1
X"96", X"97", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"97", X"93", X"96", X"96", X"95", X"95", X"95", X"95", X"95", X"96", X"96",
X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"96", X"96", X"95", X"95", X"95", X"95", X"93", X"93", X"94", X"94", X"94", X"94", X"94", X"94", X"94",
X"92", X"93", X"93", X"94", X"94", X"93", X"93", X"93", X"93", X"93", X"93", X"94", X"94", X"93", X"93", X"92", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93",
X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"94", X"93", X"92", X"92", X"91", X"91", X"91", X"90", X"91", X"91", X"91", X"91", X"91", X"91", X"91", X"91", X"90", X"90", X"91",
--2
X"97", X"97", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"97", X"95", X"96", X"94", X"95", X"95", X"95", X"95", X"96", X"96", X"96",
X"96", X"96", X"97", X"96", X"96", X"96", X"96", X"96", X"94", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"94", X"95", X"96", X"95", X"95", X"95", X"95", X"93", X"92", X"93", X"93", X"93", X"93", X"93", X"93", X"93",
X"92", X"93", X"92", X"92", X"92", X"91", X"92", X"92", X"92", X"92", X"96", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"94", X"93", X"94", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"92",
X"93", X"93", X"93", X"93", X"93", X"93", X"92", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"92", X"92", X"92", X"92", X"92", X"91", X"91", X"91", X"91", X"91", X"91", X"91", X"90", X"90", X"8F", X"8F", X"90",
--3
X"96", X"97", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"98", X"96", X"96", X"96", X"96", X"95", X"94", X"95", X"96", X"96", X"96",
X"96", X"96", X"97", X"96", X"96", X"96", X"96", X"96", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"96", X"95", X"95", X"95", X"94", X"94", X"94", X"93", X"92", X"92", X"93", X"94", X"93", X"94",
X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"93", X"98", X"93", X"92", X"93", X"93", X"93", X"92", X"92", X"92", X"92", X"93", X"94", X"94", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93",
X"93", X"93", X"93", X"93", X"93", X"93", X"94", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"92", X"92", X"92", X"92", X"92", X"91", X"91", X"90", X"90", X"90", X"90", X"90", X"90", X"90", X"90", X"8F", X"8F",
--4
X"96", X"97", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"98", X"96", X"96", X"95", X"96", X"96", X"95", X"96", X"96", X"96", X"96",
X"96", X"96", X"97", X"96", X"96", X"96", X"96", X"96", X"95", X"96", X"96", X"96", X"95", X"95", X"95", X"96", X"95", X"95", X"96", X"95", X"95", X"95", X"94", X"94", X"93", X"93", X"91", X"90", X"90", X"90", X"8A", X"8C",
X"90", X"90", X"91", X"91", X"93", X"93", X"92", X"92", X"92", X"93", X"94", X"93", X"93", X"93", X"93", X"93", X"93", X"91", X"92", X"92", X"93", X"94", X"94", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93",
X"93", X"93", X"93", X"93", X"93", X"94", X"93", X"92", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"92", X"92", X"91", X"8F", X"90", X"90", X"90", X"90", X"90", X"91", X"91", X"90", X"90", X"8F",
--5
X"95", X"97", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"98", X"96", X"96", X"96", X"97", X"96", X"94", X"96", X"96", X"96", X"96",
X"96", X"96", X"97", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"97", X"97", X"97", X"96", X"96", X"96", X"96", X"95", X"95", X"95", X"95", X"8C", X"8B", X"88", X"87", X"87", X"88", X"8C", X"8A", X"8E",
X"8E", X"8E", X"8F", X"8F", X"90", X"92", X"92", X"92", X"92", X"94", X"91", X"93", X"93", X"93", X"93", X"93", X"92", X"91", X"91", X"92", X"93", X"94", X"95", X"94", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93",
X"93", X"93", X"93", X"93", X"93", X"8F", X"92", X"92", X"92", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"92", X"92", X"90", X"92", X"91", X"91", X"91", X"91", X"91", X"91", X"91", X"91", X"90", X"8F",
--6
X"95", X"95", X"95", X"96", X"97", X"96", X"96", X"96", X"96", X"96", X"96", X"95", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"95", X"95", X"95", X"97", X"97", X"95",
X"95", X"96", X"97", X"93", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"95", X"95", X"97", X"96", X"96", X"90", X"92", X"86", X"80", X"84", X"86", X"81", X"87", X"87", X"8A", X"8C", X"8E",
X"8E", X"8C", X"8E", X"8D", X"88", X"89", X"8D", X"90", X"91", X"90", X"90", X"92", X"92", X"8C", X"91", X"92", X"92", X"92", X"92", X"92", X"93", X"94", X"95", X"94", X"94", X"93", X"91", X"93", X"93", X"93", X"93", X"93",
X"92", X"93", X"92", X"92", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"92", X"92", X"92", X"92", X"91", X"91", X"91", X"91", X"91", X"92", X"92", X"91", X"91", X"91", X"90", X"90", X"8F",
--7
X"94", X"95", X"95", X"95", X"97", X"96", X"97", X"97", X"97", X"97", X"97", X"96", X"97", X"96", X"95", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"95", X"94", X"9E", X"94", X"96", X"96",
X"96", X"97", X"96", X"96", X"97", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"97", X"96", X"96", X"98", X"98", X"95", X"89", X"87", X"82", X"82", X"83", X"86", X"8C", X"8A", X"8D", X"8D", X"8D", X"8D", X"8C",
X"8D", X"8D", X"8D", X"8C", X"87", X"88", X"8A", X"8C", X"8C", X"89", X"8B", X"8D", X"8D", X"8C", X"90", X"92", X"92", X"93", X"93", X"92", X"93", X"94", X"95", X"94", X"94", X"92", X"92", X"93", X"93", X"93", X"93", X"93",
X"90", X"92", X"93", X"93", X"93", X"93", X"94", X"93", X"93", X"93", X"93", X"92", X"92", X"93", X"92", X"92", X"92", X"92", X"91", X"91", X"92", X"92", X"92", X"91", X"92", X"92", X"91", X"91", X"91", X"90", X"90", X"8F",
--8
X"95", X"96", X"95", X"95", X"95", X"96", X"98", X"98", X"97", X"97", X"97", X"97", X"97", X"96", X"95", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"95", X"94", X"9F", X"8F", X"95", X"96",
X"97", X"97", X"99", X"97", X"96", X"97", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"97", X"93", X"91", X"8A", X"87", X"86", X"7E", X"7E", X"7F", X"88", X"8E", X"91", X"91", X"91", X"92", X"90", X"8D", X"8F", X"8D",
X"87", X"86", X"89", X"8D", X"8D", X"8C", X"8A", X"8B", X"8B", X"8A", X"89", X"8C", X"8F", X"8A", X"84", X"8B", X"8C", X"90", X"92", X"92", X"93", X"94", X"95", X"94", X"93", X"92", X"93", X"93", X"93", X"93", X"93", X"93",
X"93", X"94", X"92", X"93", X"93", X"93", X"94", X"94", X"93", X"94", X"93", X"92", X"91", X"92", X"92", X"92", X"92", X"93", X"95", X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"91", X"91", X"91", X"90", X"90", X"8F",
--9
X"94", X"94", X"94", X"94", X"96", X"96", X"97", X"97", X"97", X"97", X"97", X"98", X"95", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"96", X"95", X"96", X"96", X"96", X"96", X"97", X"97", X"97", X"96", X"96", X"96",
X"97", X"97", X"98", X"97", X"96", X"96", X"96", X"96", X"96", X"97", X"96", X"96", X"96", X"95", X"94", X"8F", X"92", X"94", X"93", X"91", X"8C", X"8B", X"8F", X"92", X"95", X"96", X"95", X"96", X"94", X"8D", X"8D", X"8B",
X"85", X"81", X"7F", X"8D", X"91", X"91", X"91", X"91", X"8F", X"8D", X"8D", X"8D", X"91", X"91", X"8B", X"8E", X"8F", X"91", X"90", X"91", X"92", X"92", X"91", X"8C", X"8B", X"8A", X"91", X"93", X"93", X"93", X"93", X"93",
X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"92", X"92", X"92", X"92", X"92", X"92", X"94", X"95", X"93", X"93", X"93", X"93", X"93", X"93", X"92", X"91", X"91", X"91", X"90", X"8F", X"90",
--10
X"94", X"94", X"94", X"94", X"95", X"96", X"96", X"96", X"96", X"97", X"97", X"97", X"96", X"96", X"97", X"96", X"96", X"96", X"96", X"96", X"96", X"95", X"96", X"96", X"96", X"96", X"96", X"97", X"97", X"96", X"97", X"97",
X"97", X"97", X"97", X"96", X"96", X"95", X"96", X"96", X"96", X"96", X"95", X"90", X"96", X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"95", X"96", X"96", X"95", X"95", X"96", X"97", X"96", X"93", X"8E", X"8C", X"87",
X"86", X"86", X"8B", X"90", X"92", X"92", X"91", X"91", X"91", X"90", X"90", X"91", X"93", X"93", X"94", X"94", X"93", X"93", X"93", X"92", X"93", X"94", X"94", X"92", X"90", X"8E", X"8C", X"92", X"93", X"93", X"93", X"93",
X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"92", X"92", X"92", X"92", X"92", X"93", X"93", X"92", X"93", X"93", X"93", X"93", X"93", X"93", X"92", X"91", X"91", X"91", X"90", X"90", X"90",
--11
X"94", X"94", X"94", X"94", X"94", X"95", X"95", X"95", X"95", X"96", X"96", X"95", X"97", X"96", X"98", X"97", X"96", X"95", X"95", X"95", X"95", X"96", X"96", X"95", X"95", X"96", X"96", X"96", X"97", X"97", X"98", X"97",
X"97", X"97", X"96", X"95", X"95", X"95", X"95", X"95", X"93", X"91", X"98", X"9A", X"9A", X"9C", X"9C", X"9B", X"9A", X"9A", X"98", X"98", X"97", X"97", X"96", X"95", X"96", X"96", X"95", X"91", X"8F", X"85", X"87", X"89",
X"91", X"95", X"93", X"94", X"94", X"94", X"93", X"94", X"93", X"94", X"93", X"94", X"92", X"95", X"95", X"96", X"96", X"98", X"99", X"9A", X"9A", X"99", X"99", X"99", X"97", X"95", X"94", X"94", X"92", X"93", X"93", X"93",
X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"92", X"92", X"92", X"92", X"93", X"94", X"92", X"94", X"93", X"93", X"93", X"93", X"93", X"93", X"92", X"91", X"91", X"91", X"91", X"91", X"91",
--12
X"94", X"94", X"94", X"94", X"94", X"95", X"95", X"96", X"95", X"96", X"94", X"96", X"96", X"97", X"97", X"97", X"96", X"94", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"96", X"96", X"98", X"98", X"97",
X"97", X"97", X"96", X"95", X"96", X"95", X"96", X"94", X"93", X"96", X"9C", X"9E", X"9D", X"9E", X"9E", X"9D", X"9D", X"9C", X"9A", X"98", X"96", X"9A", X"94", X"95", X"96", X"92", X"92", X"85", X"8A", X"8B", X"8F", X"92",
X"97", X"96", X"98", X"98", X"96", X"95", X"95", X"95", X"95", X"94", X"94", X"94", X"95", X"95", X"95", X"96", X"96", X"9B", X"9C", X"9D", X"9E", X"9E", X"9E", X"9F", X"9F", X"9D", X"99", X"96", X"92", X"94", X"93", X"93",
X"93", X"94", X"92", X"92", X"93", X"93", X"93", X"93", X"93", X"93", X"94", X"91", X"91", X"92", X"92", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"92", X"93", X"90", X"91", X"91", X"91", X"91", X"90",
--13
X"94", X"94", X"95", X"95", X"94", X"94", X"94", X"94", X"95", X"96", X"94", X"96", X"96", X"97", X"97", X"96", X"96", X"94", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"96", X"96", X"97", X"97", X"97",
X"97", X"97", X"97", X"96", X"93", X"8F", X"94", X"98", X"9A", X"9A", X"9E", X"9E", X"9E", X"9E", X"9E", X"9D", X"9D", X"9C", X"9B", X"9A", X"99", X"9E", X"93", X"96", X"95", X"90", X"8B", X"85", X"8E", X"91", X"98", X"99",
X"99", X"99", X"9A", X"99", X"98", X"97", X"97", X"96", X"96", X"96", X"95", X"95", X"96", X"95", X"96", X"97", X"99", X"9C", X"9D", X"9E", X"9F", X"9F", X"9F", X"9F", X"9F", X"9E", X"9E", X"9B", X"93", X"8F", X"8D", X"87",
X"8A", X"91", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"94", X"92", X"92", X"92", X"93", X"93", X"94", X"93", X"93", X"93", X"93", X"93", X"93", X"92", X"93", X"93", X"8F", X"91", X"91", X"91", X"92", X"90",
--14
X"92", X"91", X"92", X"92", X"91", X"93", X"93", X"90", X"94", X"95", X"94", X"96", X"96", X"96", X"96", X"96", X"96", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"96", X"96", X"97", X"96", X"96",
X"96", X"96", X"95", X"95", X"90", X"8E", X"94", X"98", X"9A", X"9B", X"9D", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9D", X"9B", X"9A", X"98", X"97", X"95", X"93", X"90", X"89", X"8C", X"93", X"94", X"96", X"9A", X"9A",
X"99", X"99", X"98", X"99", X"99", X"98", X"98", X"97", X"97", X"97", X"97", X"96", X"96", X"95", X"97", X"99", X"9C", X"9D", X"9E", X"9E", X"A0", X"A0", X"A0", X"9F", X"A0", X"A1", X"A1", X"9F", X"97", X"8C", X"80", X"84",
X"8A", X"8E", X"91", X"93", X"94", X"93", X"94", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"94", X"94", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"92", X"92", X"91", X"92", X"92", X"92", X"92", X"91",
--15
X"92", X"92", X"92", X"93", X"92", X"93", X"94", X"8F", X"94", X"95", X"94", X"96", X"95", X"96", X"95", X"96", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"96", X"96", X"96", X"96", X"96",
X"96", X"96", X"96", X"93", X"8E", X"8F", X"93", X"98", X"9A", X"9C", X"9D", X"9E", X"9E", X"9E", X"9F", X"9F", X"9E", X"9D", X"9D", X"9A", X"97", X"97", X"97", X"96", X"8B", X"87", X"90", X"95", X"99", X"99", X"9B", X"9C",
X"9B", X"99", X"99", X"99", X"99", X"98", X"98", X"97", X"96", X"97", X"97", X"96", X"96", X"95", X"98", X"9A", X"9C", X"9D", X"9F", X"9E", X"9F", X"A0", X"A0", X"A0", X"A0", X"A2", X"A1", X"A0", X"9D", X"93", X"8A", X"88",
X"8D", X"8D", X"8E", X"91", X"92", X"93", X"94", X"93", X"93", X"93", X"94", X"93", X"94", X"93", X"93", X"93", X"94", X"93", X"93", X"93", X"93", X"93", X"93", X"94", X"92", X"92", X"93", X"92", X"92", X"92", X"93", X"92",
--16
X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"91", X"92", X"93", X"94", X"95", X"91", X"95", X"96", X"95", X"95", X"96", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"95", X"94", X"94", X"94", X"95",
X"94", X"94", X"8F", X"85", X"8A", X"91", X"93", X"97", X"9B", X"9B", X"9D", X"9E", X"9E", X"9E", X"9F", X"A5", X"9D", X"9F", X"9B", X"99", X"98", X"97", X"97", X"96", X"89", X"8B", X"8F", X"96", X"98", X"99", X"9A", X"9B",
X"9A", X"99", X"99", X"99", X"98", X"97", X"97", X"97", X"97", X"98", X"97", X"96", X"96", X"96", X"98", X"99", X"9C", X"9C", X"9D", X"9E", X"9F", X"A0", X"A0", X"A1", X"A0", X"A0", X"A1", X"A2", X"9F", X"9A", X"92", X"90",
X"92", X"93", X"92", X"91", X"93", X"92", X"91", X"92", X"93", X"92", X"94", X"93", X"94", X"93", X"93", X"94", X"95", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93",
--17
X"91", X"92", X"92", X"92", X"92", X"91", X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"93", X"92", X"93", X"94", X"95", X"95", X"95", X"95", X"96", X"95", X"95", X"95", X"95", X"95", X"95", X"94", X"93", X"94", X"94",
X"94", X"8D", X"85", X"86", X"8F", X"91", X"93", X"96", X"97", X"99", X"9D", X"9D", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9B", X"98", X"95", X"96", X"93", X"8D", X"88", X"8B", X"8C", X"92", X"95", X"93", X"96", X"99",
X"99", X"99", X"9B", X"98", X"98", X"97", X"97", X"97", X"97", X"98", X"97", X"96", X"96", X"96", X"98", X"99", X"9C", X"9D", X"9E", X"9E", X"9E", X"9F", X"A1", X"A1", X"A1", X"A2", X"A0", X"A3", X"A0", X"9E", X"9A", X"97",
X"96", X"98", X"9A", X"97", X"93", X"92", X"91", X"8F", X"92", X"92", X"93", X"93", X"93", X"94", X"94", X"95", X"95", X"94", X"94", X"94", X"94", X"94", X"94", X"94", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93",
--18
X"91", X"91", X"91", X"91", X"91", X"8E", X"8F", X"91", X"92", X"93", X"92", X"92", X"92", X"91", X"92", X"93", X"94", X"96", X"95", X"95", X"95", X"96", X"95", X"95", X"95", X"95", X"94", X"94", X"92", X"92", X"91", X"92",
X"8B", X"86", X"8C", X"8C", X"8F", X"92", X"92", X"94", X"97", X"98", X"9D", X"9D", X"9D", X"9D", X"9E", X"A0", X"9D", X"A0", X"9B", X"98", X"94", X"91", X"8E", X"8A", X"8A", X"8D", X"8E", X"8F", X"92", X"92", X"98", X"97",
X"9A", X"98", X"99", X"97", X"97", X"97", X"97", X"97", X"97", X"98", X"97", X"96", X"96", X"97", X"98", X"99", X"9C", X"9C", X"9D", X"9D", X"9E", X"9F", X"9F", X"9F", X"A0", X"A1", X"A2", X"A2", X"A0", X"9E", X"9B", X"97",
X"96", X"98", X"9C", X"9B", X"9C", X"9A", X"94", X"93", X"8F", X"8A", X"8D", X"8F", X"90", X"93", X"94", X"94", X"94", X"94", X"94", X"94", X"94", X"94", X"94", X"94", X"94", X"93", X"93", X"93", X"93", X"93", X"93", X"93",
--19
X"91", X"91", X"91", X"91", X"91", X"8E", X"8E", X"91", X"94", X"93", X"93", X"92", X"92", X"92", X"92", X"92", X"92", X"95", X"94", X"94", X"94", X"94", X"94", X"94", X"94", X"94", X"94", X"94", X"93", X"91", X"92", X"8E",
X"88", X"8B", X"8C", X"8C", X"8E", X"90", X"92", X"94", X"97", X"99", X"99", X"9C", X"9D", X"9D", X"9E", X"9F", X"9E", X"9F", X"9A", X"98", X"94", X"90", X"8F", X"8C", X"8B", X"8C", X"8E", X"90", X"91", X"93", X"97", X"97",
X"98", X"98", X"98", X"98", X"98", X"97", X"97", X"98", X"97", X"97", X"97", X"96", X"96", X"96", X"97", X"9A", X"9C", X"9C", X"9D", X"9D", X"9E", X"9F", X"9F", X"A0", X"A0", X"A1", X"A1", X"A1", X"A0", X"9E", X"9C", X"99",
X"94", X"98", X"9A", X"9B", X"9E", X"9D", X"97", X"96", X"95", X"91", X"90", X"8E", X"8D", X"91", X"92", X"95", X"94", X"94", X"95", X"94", X"94", X"94", X"94", X"94", X"93", X"93", X"92", X"93", X"93", X"93", X"93", X"93",
--20
X"90", X"90", X"90", X"90", X"90", X"8E", X"90", X"90", X"90", X"95", X"91", X"92", X"92", X"92", X"93", X"92", X"92", X"94", X"93", X"93", X"93", X"94", X"93", X"96", X"95", X"94", X"95", X"97", X"92", X"91", X"8F", X"89",
X"85", X"8A", X"8C", X"8C", X"8E", X"90", X"92", X"93", X"97", X"98", X"99", X"9C", X"9C", X"9C", X"9D", X"A0", X"9D", X"9E", X"9A", X"98", X"93", X"8F", X"8C", X"8C", X"8B", X"8D", X"8E", X"8F", X"90", X"93", X"96", X"95",
X"96", X"97", X"97", X"97", X"96", X"96", X"96", X"96", X"96", X"97", X"96", X"96", X"96", X"95", X"95", X"96", X"9B", X"9B", X"9C", X"9C", X"9D", X"9D", X"9E", X"9F", X"9E", X"A0", X"A0", X"A0", X"9F", X"9F", X"9E", X"9C",
X"97", X"95", X"99", X"99", X"9D", X"9E", X"9B", X"9B", X"9B", X"98", X"98", X"94", X"90", X"8E", X"8F", X"94", X"95", X"94", X"95", X"94", X"94", X"94", X"94", X"94", X"94", X"93", X"93", X"93", X"93", X"93", X"93", X"92",
--21
X"90", X"91", X"91", X"90", X"90", X"90", X"90", X"90", X"8F", X"94", X"92", X"90", X"90", X"91", X"92", X"91", X"91", X"93", X"93", X"93", X"93", X"93", X"93", X"92", X"93", X"93", X"94", X"94", X"92", X"8F", X"90", X"8A",
X"89", X"8B", X"8C", X"8C", X"8E", X"90", X"91", X"92", X"95", X"98", X"99", X"9C", X"9C", X"9B", X"9C", X"9D", X"9A", X"9A", X"98", X"95", X"90", X"8D", X"8A", X"8C", X"8C", X"8B", X"8C", X"8E", X"8F", X"8F", X"93", X"94",
X"94", X"95", X"95", X"94", X"94", X"94", X"95", X"95", X"95", X"94", X"94", X"94", X"94", X"94", X"93", X"94", X"9B", X"9A", X"9B", X"9C", X"9C", X"9D", X"9D", X"9E", X"9E", X"9F", X"9F", X"A0", X"9F", X"9F", X"9E", X"9D",
X"9D", X"92", X"90", X"99", X"9B", X"9C", X"9C", X"9C", X"9A", X"9A", X"9A", X"98", X"95", X"94", X"92", X"8E", X"95", X"94", X"95", X"94", X"94", X"94", X"94", X"94", X"94", X"94", X"93", X"93", X"93", X"93", X"94", X"93",
--22
X"91", X"91", X"90", X"90", X"90", X"90", X"90", X"90", X"90", X"90", X"90", X"90", X"90", X"90", X"90", X"90", X"91", X"92", X"92", X"92", X"93", X"93", X"93", X"93", X"93", X"92", X"94", X"93", X"91", X"91", X"8F", X"8B",
X"8A", X"8D", X"8C", X"8C", X"8D", X"8E", X"90", X"8F", X"93", X"94", X"97", X"9A", X"9A", X"9A", X"9A", X"9A", X"98", X"9A", X"93", X"90", X"8C", X"8B", X"8A", X"8B", X"8A", X"8A", X"8B", X"8C", X"8C", X"8C", X"8E", X"91",
X"95", X"91", X"94", X"94", X"94", X"94", X"93", X"94", X"93", X"93", X"93", X"93", X"93", X"91", X"92", X"91", X"97", X"98", X"9B", X"9B", X"9C", X"9B", X"9D", X"9D", X"9E", X"9E", X"9F", X"A0", X"9F", X"9F", X"9E", X"9D",
X"9D", X"8F", X"91", X"99", X"9B", X"9B", X"9C", X"9C", X"9B", X"9B", X"9A", X"9A", X"99", X"97", X"97", X"92", X"95", X"93", X"95", X"94", X"95", X"94", X"94", X"94", X"94", X"94", X"94", X"94", X"94", X"94", X"94", X"93",
--23
X"91", X"92", X"91", X"90", X"90", X"90", X"90", X"90", X"90", X"90", X"90", X"90", X"90", X"90", X"90", X"91", X"92", X"93", X"92", X"92", X"93", X"93", X"93", X"93", X"93", X"92", X"94", X"93", X"91", X"92", X"8E", X"87",
X"8D", X"8B", X"8B", X"8C", X"8B", X"8B", X"8B", X"82", X"85", X"8B", X"8D", X"93", X"92", X"93", X"97", X"95", X"96", X"97", X"90", X"8D", X"86", X"84", X"85", X"88", X"88", X"89", X"8A", X"89", X"88", X"89", X"89", X"89",
X"8F", X"8E", X"91", X"91", X"91", X"91", X"91", X"91", X"91", X"91", X"91", X"91", X"91", X"94", X"90", X"94", X"96", X"95", X"99", X"9B", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9E", X"9F", X"9F", X"9F", X"9E", X"9D",
X"9B", X"98", X"9A", X"9F", X"9E", X"9D", X"9C", X"9D", X"9C", X"9B", X"9B", X"9A", X"9A", X"99", X"99", X"98", X"91", X"93", X"93", X"94", X"93", X"93", X"93", X"94", X"94", X"94", X"94", X"94", X"94", X"94", X"94", X"93",
--24
X"92", X"92", X"91", X"90", X"90", X"8F", X"8F", X"90", X"90", X"90", X"90", X"90", X"90", X"90", X"8F", X"90", X"91", X"93", X"92", X"92", X"93", X"93", X"93", X"93", X"93", X"92", X"94", X"93", X"92", X"92", X"8A", X"86",
X"89", X"89", X"8A", X"8A", X"83", X"84", X"86", X"80", X"85", X"8C", X"8D", X"8E", X"8F", X"8D", X"8E", X"8E", X"89", X"89", X"8C", X"88", X"7D", X"7C", X"7F", X"86", X"87", X"86", X"87", X"87", X"88", X"87", X"87", X"89",
X"86", X"8B", X"90", X"90", X"90", X"90", X"90", X"90", X"90", X"90", X"90", X"8F", X"90", X"92", X"92", X"93", X"95", X"94", X"96", X"96", X"98", X"9B", X"9B", X"9C", X"9C", X"9C", X"9D", X"9F", X"9F", X"9F", X"9E", X"9E",
X"9E", X"9B", X"97", X"A0", X"9F", X"A1", X"A0", X"A1", X"9D", X"9B", X"9B", X"9B", X"9A", X"9B", X"99", X"9A", X"96", X"95", X"92", X"94", X"93", X"93", X"94", X"94", X"94", X"94", X"94", X"94", X"94", X"94", X"94", X"93",
--25
X"92", X"92", X"91", X"90", X"90", X"90", X"90", X"90", X"8F", X"90", X"91", X"91", X"91", X"91", X"90", X"91", X"92", X"92", X"92", X"93", X"94", X"93", X"93", X"93", X"92", X"93", X"93", X"93", X"92", X"90", X"89", X"83",
X"84", X"86", X"83", X"83", X"80", X"85", X"8C", X"90", X"92", X"95", X"96", X"95", X"93", X"8F", X"8B", X"8F", X"8F", X"8D", X"8A", X"8A", X"7D", X"7C", X"7D", X"86", X"84", X"84", X"85", X"85", X"85", X"85", X"85", X"84",
X"7F", X"85", X"8E", X"8D", X"8D", X"8D", X"8D", X"8D", X"8D", X"8D", X"8C", X"8E", X"8E", X"93", X"8B", X"8E", X"92", X"94", X"95", X"94", X"96", X"9A", X"9A", X"9A", X"99", X"9B", X"9D", X"9E", X"9E", X"9E", X"9E", X"9E",
X"9D", X"99", X"92", X"98", X"9F", X"A2", X"A2", X"A5", X"A3", X"9E", X"9F", X"9D", X"9C", X"9B", X"9B", X"9A", X"98", X"96", X"94", X"93", X"93", X"94", X"95", X"94", X"94", X"94", X"94", X"95", X"93", X"95", X"93", X"92",
--26
X"92", X"92", X"91", X"90", X"90", X"90", X"90", X"90", X"90", X"91", X"91", X"91", X"91", X"91", X"91", X"92", X"92", X"91", X"90", X"93", X"92", X"93", X"93", X"93", X"93", X"93", X"94", X"94", X"91", X"92", X"87", X"83",
X"84", X"81", X"7D", X"82", X"8E", X"94", X"95", X"95", X"97", X"9A", X"9C", X"99", X"9A", X"99", X"97", X"97", X"98", X"93", X"90", X"8D", X"85", X"81", X"7E", X"84", X"82", X"83", X"82", X"7F", X"7F", X"81", X"83", X"7D",
X"7C", X"81", X"8A", X"8B", X"8A", X"8D", X"8B", X"8B", X"8B", X"8B", X"8B", X"8D", X"8D", X"8E", X"8E", X"90", X"8F", X"90", X"91", X"92", X"94", X"98", X"97", X"98", X"9A", X"9C", X"9D", X"9D", X"9D", X"9D", X"9E", X"9E",
X"9D", X"97", X"91", X"94", X"9F", X"A3", X"A4", X"A5", X"A3", X"A0", X"A0", X"9F", X"9E", X"9D", X"9C", X"9B", X"9A", X"98", X"97", X"94", X"93", X"94", X"94", X"94", X"94", X"94", X"93", X"94", X"94", X"97", X"94", X"93",
--27
X"92", X"92", X"91", X"91", X"91", X"90", X"90", X"90", X"91", X"92", X"91", X"91", X"91", X"91", X"91", X"91", X"92", X"93", X"90", X"92", X"92", X"91", X"92", X"92", X"93", X"94", X"95", X"95", X"92", X"91", X"86", X"84",
X"84", X"84", X"83", X"8B", X"94", X"96", X"99", X"99", X"99", X"9A", X"9A", X"9A", X"9B", X"9B", X"98", X"98", X"97", X"96", X"93", X"8C", X"85", X"82", X"83", X"83", X"83", X"83", X"7F", X"7B", X"7A", X"7B", X"80", X"7F",
X"7C", X"7F", X"88", X"7E", X"89", X"89", X"8A", X"88", X"89", X"88", X"89", X"8B", X"8E", X"8D", X"8A", X"8E", X"8F", X"8F", X"8F", X"8F", X"91", X"92", X"93", X"95", X"97", X"9A", X"9A", X"9A", X"9C", X"9D", X"9D", X"9C",
X"9B", X"95", X"91", X"93", X"9E", X"A3", X"A6", X"A6", X"A3", X"A1", X"A2", X"A1", X"A1", X"A0", X"9B", X"9C", X"9A", X"9A", X"98", X"94", X"94", X"94", X"94", X"94", X"94", X"94", X"95", X"95", X"94", X"94", X"94", X"94",
--28
X"92", X"92", X"91", X"91", X"91", X"91", X"91", X"91", X"91", X"90", X"91", X"91", X"91", X"91", X"91", X"92", X"92", X"92", X"92", X"92", X"92", X"90", X"91", X"91", X"90", X"91", X"92", X"92", X"92", X"8F", X"7F", X"83",
X"85", X"8B", X"8F", X"94", X"96", X"98", X"99", X"98", X"99", X"9B", X"9C", X"9A", X"9A", X"9B", X"98", X"97", X"97", X"97", X"93", X"8A", X"86", X"82", X"84", X"83", X"84", X"84", X"81", X"7E", X"7E", X"82", X"84", X"84",
X"85", X"84", X"85", X"7F", X"8B", X"8C", X"86", X"83", X"85", X"7E", X"83", X"88", X"86", X"89", X"88", X"8B", X"8A", X"8B", X"8D", X"8E", X"8E", X"8F", X"92", X"94", X"95", X"97", X"97", X"99", X"9C", X"9E", X"9D", X"9B",
X"9B", X"97", X"96", X"96", X"9F", X"A2", X"A4", X"A6", X"A3", X"A2", X"A2", X"A2", X"A2", X"A1", X"99", X"9B", X"99", X"9A", X"99", X"94", X"94", X"94", X"94", X"94", X"94", X"94", X"94", X"95", X"96", X"94", X"95", X"94",
--29
X"90", X"92", X"91", X"91", X"91", X"91", X"92", X"91", X"91", X"91", X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"91", X"91", X"91", X"91", X"92", X"92", X"92", X"93", X"8B", X"7E", X"7B",
X"88", X"92", X"95", X"99", X"99", X"99", X"9A", X"9A", X"9A", X"99", X"99", X"9B", X"9C", X"9C", X"99", X"99", X"97", X"99", X"8F", X"8B", X"85", X"82", X"83", X"83", X"83", X"83", X"83", X"83", X"81", X"82", X"86", X"8A",
X"8A", X"88", X"86", X"84", X"84", X"84", X"83", X"81", X"82", X"81", X"82", X"82", X"81", X"83", X"86", X"86", X"83", X"83", X"89", X"8D", X"8C", X"8C", X"91", X"90", X"90", X"95", X"96", X"99", X"9B", X"9C", X"9B", X"9B",
X"9B", X"98", X"98", X"98", X"9E", X"A1", X"A2", X"A2", X"A2", X"A3", X"A2", X"A5", X"A6", X"A2", X"9E", X"9D", X"9B", X"9E", X"9E", X"97", X"96", X"95", X"95", X"95", X"94", X"95", X"95", X"95", X"95", X"95", X"94", X"94",
--30
X"92", X"92", X"92", X"91", X"92", X"91", X"92", X"92", X"91", X"92", X"92", X"92", X"92", X"92", X"93", X"92", X"92", X"92", X"92", X"92", X"92", X"91", X"91", X"91", X"91", X"92", X"92", X"92", X"91", X"8E", X"7E", X"82",
X"91", X"97", X"97", X"99", X"99", X"99", X"9A", X"9A", X"9A", X"9A", X"9A", X"9B", X"9D", X"9C", X"99", X"98", X"97", X"9A", X"8F", X"8B", X"85", X"83", X"83", X"84", X"84", X"83", X"84", X"81", X"7E", X"81", X"87", X"89",
X"88", X"86", X"85", X"84", X"81", X"82", X"83", X"82", X"82", X"82", X"83", X"83", X"83", X"83", X"83", X"86", X"85", X"82", X"83", X"85", X"8A", X"8B", X"8E", X"8E", X"8F", X"93", X"96", X"99", X"98", X"98", X"9A", X"9C",
X"9C", X"98", X"97", X"96", X"9D", X"A1", X"A1", X"A1", X"A2", X"A4", X"A3", X"A3", X"A6", X"A2", X"A1", X"9C", X"9B", X"9D", X"9E", X"9B", X"97", X"95", X"95", X"95", X"95", X"95", X"96", X"96", X"96", X"95", X"95", X"95",
--31
X"92", X"93", X"92", X"92", X"93", X"91", X"93", X"93", X"92", X"92", X"93", X"92", X"92", X"93", X"93", X"92", X"92", X"92", X"92", X"92", X"92", X"91", X"91", X"91", X"91", X"92", X"92", X"92", X"91", X"91", X"87", X"8D",
X"95", X"98", X"99", X"99", X"99", X"99", X"9A", X"9A", X"9A", X"9A", X"99", X"9B", X"99", X"99", X"98", X"96", X"95", X"92", X"8E", X"8A", X"85", X"83", X"82", X"85", X"87", X"85", X"83", X"82", X"7F", X"81", X"84", X"84",
X"84", X"83", X"83", X"84", X"82", X"82", X"81", X"82", X"82", X"82", X"82", X"83", X"83", X"83", X"85", X"89", X"86", X"80", X"82", X"81", X"87", X"8A", X"8D", X"8D", X"8F", X"92", X"94", X"97", X"97", X"97", X"99", X"9D",
X"99", X"96", X"96", X"97", X"9D", X"A1", X"A0", X"A0", X"A2", X"A5", X"A1", X"A3", X"A3", X"A4", X"A0", X"98", X"9A", X"9C", X"9C", X"9C", X"99", X"96", X"97", X"96", X"95", X"96", X"96", X"97", X"96", X"95", X"95", X"95",
--32
X"93", X"92", X"92", X"93", X"92", X"92", X"92", X"92", X"91", X"92", X"93", X"92", X"93", X"93", X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"91", X"91", X"91", X"91", X"93", X"91", X"93", X"91", X"8D", X"90", X"95",
X"98", X"99", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"99", X"9A", X"98", X"98", X"96", X"96", X"95", X"8F", X"8C", X"87", X"84", X"82", X"82", X"82", X"83", X"84", X"81", X"82", X"82", X"76", X"86", X"8A",
X"88", X"84", X"84", X"84", X"80", X"80", X"7E", X"80", X"7F", X"7C", X"7C", X"7B", X"7F", X"81", X"83", X"85", X"85", X"85", X"84", X"83", X"82", X"83", X"89", X"8D", X"8E", X"91", X"91", X"94", X"95", X"97", X"99", X"9B",
X"9A", X"96", X"96", X"97", X"9D", X"9F", X"A0", X"A0", X"A1", X"A3", X"A4", X"A3", X"A3", X"A3", X"A0", X"9A", X"9A", X"9A", X"9C", X"9E", X"98", X"97", X"97", X"95", X"95", X"96", X"96", X"96", X"96", X"94", X"95", X"95",
--33
X"93", X"91", X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"94", X"93", X"91", X"93", X"93", X"92", X"92", X"92", X"92", X"92", X"91", X"92", X"91", X"91", X"91", X"91", X"91", X"90", X"91", X"91", X"90", X"95", X"97",
X"98", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"99", X"98", X"98", X"98", X"99", X"98", X"94", X"94", X"91", X"8D", X"8A", X"86", X"82", X"81", X"81", X"81", X"81", X"82", X"81", X"82", X"87", X"6F", X"88", X"88",
X"86", X"84", X"81", X"7D", X"7C", X"7E", X"7B", X"79", X"7B", X"7B", X"78", X"79", X"7C", X"7E", X"83", X"85", X"85", X"88", X"88", X"84", X"7F", X"82", X"89", X"8B", X"8E", X"90", X"90", X"95", X"95", X"96", X"97", X"97",
X"97", X"94", X"93", X"96", X"9E", X"9F", X"9F", X"9F", X"A0", X"A2", X"A2", X"A3", X"A4", X"A2", X"9F", X"9C", X"9A", X"9C", X"9B", X"9A", X"99", X"97", X"97", X"95", X"95", X"96", X"96", X"96", X"96", X"95", X"95", X"95",
--34
X"92", X"91", X"91", X"92", X"92", X"92", X"92", X"92", X"92", X"8F", X"92", X"91", X"92", X"93", X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"91", X"92", X"8C", X"8C", X"92", X"98", X"9A",
X"9C", X"9B", X"9B", X"9B", X"9A", X"9A", X"9A", X"9A", X"98", X"98", X"97", X"95", X"94", X"94", X"90", X"90", X"8D", X"8C", X"89", X"84", X"80", X"80", X"80", X"81", X"81", X"81", X"81", X"82", X"81", X"84", X"88", X"85",
X"83", X"82", X"7F", X"7A", X"7A", X"7A", X"7A", X"78", X"79", X"79", X"74", X"76", X"79", X"7E", X"84", X"83", X"83", X"84", X"84", X"83", X"77", X"7C", X"84", X"86", X"89", X"8B", X"8B", X"91", X"91", X"93", X"96", X"97",
X"98", X"98", X"97", X"9A", X"9D", X"9E", X"9E", X"A0", X"A0", X"A2", X"A1", X"A3", X"A3", X"A2", X"A0", X"9E", X"98", X"97", X"9A", X"9B", X"99", X"97", X"97", X"95", X"95", X"96", X"96", X"96", X"96", X"96", X"96", X"96",
--35
X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"90", X"90", X"8F", X"91", X"92", X"92", X"93", X"92", X"92", X"92", X"92", X"94", X"91", X"93", X"92", X"93", X"93", X"93", X"90", X"8A", X"89", X"90", X"94", X"99", X"9B",
X"9C", X"9B", X"9B", X"9A", X"9A", X"99", X"9A", X"9A", X"98", X"97", X"97", X"94", X"94", X"8F", X"8D", X"89", X"89", X"88", X"86", X"83", X"7F", X"7C", X"7C", X"81", X"7F", X"7F", X"81", X"84", X"81", X"83", X"84", X"81",
X"7D", X"7E", X"7C", X"79", X"76", X"77", X"77", X"76", X"77", X"75", X"74", X"79", X"7C", X"81", X"86", X"85", X"84", X"84", X"85", X"83", X"77", X"76", X"7F", X"82", X"84", X"8A", X"8B", X"8E", X"90", X"90", X"92", X"90",
X"92", X"94", X"93", X"9C", X"9D", X"9F", X"9F", X"A0", X"A0", X"A1", X"A0", X"A2", X"A3", X"A3", X"A0", X"9D", X"9D", X"9C", X"9C", X"9B", X"9A", X"98", X"96", X"95", X"95", X"96", X"96", X"96", X"96", X"96", X"96", X"96",
--36
X"92", X"92", X"92", X"92", X"92", X"92", X"91", X"91", X"92", X"92", X"92", X"91", X"92", X"95", X"93", X"93", X"93", X"93", X"94", X"90", X"92", X"92", X"92", X"92", X"93", X"8A", X"84", X"8D", X"95", X"96", X"99", X"9B",
X"9C", X"9B", X"9B", X"9A", X"9A", X"9A", X"9A", X"9A", X"98", X"96", X"96", X"93", X"94", X"8F", X"8C", X"8A", X"89", X"84", X"80", X"7E", X"7C", X"79", X"73", X"7B", X"7F", X"7E", X"7D", X"85", X"83", X"84", X"81", X"7D",
X"7D", X"7C", X"77", X"76", X"73", X"73", X"75", X"76", X"73", X"75", X"76", X"7A", X"7D", X"83", X"8B", X"89", X"85", X"84", X"84", X"84", X"7C", X"7C", X"7F", X"7E", X"81", X"89", X"8C", X"90", X"94", X"95", X"96", X"95",
X"95", X"93", X"92", X"99", X"9B", X"9D", X"9E", X"9E", X"9F", X"A0", X"A1", X"A3", X"A4", X"A2", X"A0", X"9F", X"9F", X"9B", X"9B", X"9A", X"9B", X"9C", X"98", X"95", X"95", X"96", X"96", X"96", X"96", X"96", X"96", X"96",
--37
X"92", X"92", X"92", X"92", X"92", X"93", X"91", X"91", X"92", X"93", X"92", X"85", X"93", X"94", X"92", X"93", X"93", X"93", X"93", X"92", X"90", X"92", X"92", X"92", X"91", X"89", X"8B", X"94", X"95", X"96", X"99", X"9B",
X"9C", X"9B", X"9B", X"9A", X"9A", X"9B", X"99", X"9A", X"96", X"94", X"94", X"91", X"91", X"8D", X"8D", X"89", X"89", X"83", X"7D", X"7C", X"7E", X"7A", X"73", X"7C", X"7E", X"7F", X"86", X"87", X"81", X"7E", X"7B", X"7A",
X"7B", X"7B", X"78", X"75", X"73", X"72", X"70", X"71", X"73", X"76", X"78", X"79", X"7D", X"84", X"87", X"86", X"85", X"83", X"83", X"82", X"81", X"84", X"82", X"7D", X"80", X"8A", X"8E", X"91", X"97", X"98", X"99", X"9C",
X"9C", X"9A", X"99", X"9C", X"9C", X"9B", X"9B", X"9D", X"9F", X"A0", X"A0", X"A3", X"A3", X"A2", X"A0", X"9E", X"9E", X"9B", X"9B", X"9B", X"9B", X"9C", X"97", X"95", X"95", X"96", X"96", X"96", X"96", X"96", X"96", X"96",
--38
X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"93", X"92", X"92", X"92", X"8A", X"96", X"94", X"93", X"93", X"91", X"93", X"93", X"92", X"91", X"92", X"91", X"91", X"8C", X"8C", X"93", X"92", X"95", X"98", X"9A", X"9B",
X"9B", X"9B", X"9B", X"9A", X"9A", X"99", X"98", X"99", X"95", X"8F", X"8E", X"8C", X"8D", X"8A", X"8B", X"89", X"86", X"80", X"7C", X"7C", X"7D", X"79", X"70", X"7D", X"7E", X"82", X"83", X"84", X"7C", X"7B", X"71", X"78",
X"77", X"77", X"77", X"77", X"74", X"70", X"70", X"71", X"75", X"79", X"7B", X"7C", X"7F", X"87", X"86", X"86", X"85", X"84", X"7F", X"7D", X"84", X"88", X"84", X"80", X"82", X"89", X"8E", X"91", X"98", X"9C", X"9B", X"9B",
X"9A", X"9B", X"9B", X"9B", X"9B", X"9B", X"98", X"9A", X"9D", X"9F", X"A0", X"A3", X"A5", X"A2", X"A1", X"A3", X"A3", X"9D", X"9C", X"99", X"99", X"9B", X"97", X"96", X"92", X"95", X"98", X"97", X"96", X"95", X"96", X"96",
--39
X"93", X"93", X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"91", X"93", X"92", X"94", X"94", X"92", X"93", X"93", X"92", X"92", X"93", X"90", X"8A", X"8A", X"8F", X"93", X"94", X"96", X"98", X"9B", X"9A",
X"9A", X"9B", X"9B", X"9A", X"9A", X"99", X"99", X"99", X"94", X"8C", X"88", X"89", X"89", X"89", X"89", X"89", X"7E", X"78", X"79", X"7C", X"7D", X"75", X"74", X"7D", X"80", X"83", X"81", X"82", X"7A", X"79", X"70", X"75",
X"76", X"76", X"76", X"77", X"75", X"6F", X"6F", X"72", X"78", X"7D", X"81", X"84", X"89", X"89", X"86", X"84", X"83", X"84", X"85", X"84", X"88", X"90", X"89", X"87", X"82", X"87", X"8D", X"91", X"98", X"9C", X"9B", X"9B",
X"9B", X"9B", X"9C", X"9B", X"9C", X"9C", X"99", X"94", X"97", X"9E", X"A0", X"A4", X"A8", X"A6", X"A5", X"A8", X"A5", X"9E", X"9C", X"99", X"99", X"98", X"96", X"93", X"91", X"94", X"96", X"97", X"97", X"96", X"96", X"96",
--40
X"94", X"92", X"93", X"93", X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"93", X"92", X"93", X"95", X"93", X"93", X"93", X"92", X"92", X"93", X"8A", X"84", X"87", X"91", X"92", X"94", X"95", X"98", X"9A", X"99",
X"9A", X"9A", X"9A", X"99", X"98", X"95", X"94", X"90", X"8C", X"87", X"83", X"82", X"84", X"83", X"82", X"80", X"7A", X"73", X"73", X"74", X"75", X"75", X"77", X"7D", X"82", X"82", X"80", X"7B", X"78", X"78", X"76", X"75",
X"75", X"73", X"71", X"73", X"6F", X"73", X"74", X"7B", X"7F", X"83", X"8B", X"8D", X"8C", X"8A", X"86", X"85", X"89", X"89", X"8A", X"88", X"8C", X"93", X"90", X"87", X"85", X"85", X"8D", X"92", X"97", X"9A", X"9A", X"9B",
X"9B", X"9C", X"9C", X"9C", X"9C", X"9D", X"9A", X"95", X"96", X"9E", X"9E", X"A3", X"A7", X"A7", X"A8", X"A8", X"A6", X"9F", X"9D", X"9A", X"98", X"96", X"95", X"95", X"91", X"95", X"97", X"96", X"96", X"96", X"96", X"96",
--41
X"95", X"93", X"93", X"94", X"91", X"92", X"92", X"92", X"92", X"92", X"92", X"94", X"92", X"93", X"94", X"94", X"92", X"93", X"94", X"91", X"91", X"8C", X"86", X"85", X"8C", X"92", X"93", X"92", X"94", X"96", X"98", X"99",
X"99", X"99", X"98", X"97", X"97", X"93", X"90", X"88", X"85", X"84", X"7C", X"77", X"7B", X"79", X"7B", X"79", X"77", X"73", X"74", X"73", X"76", X"78", X"7B", X"82", X"85", X"81", X"7C", X"77", X"79", X"77", X"76", X"75",
X"74", X"73", X"72", X"78", X"6D", X"7D", X"7E", X"86", X"8B", X"8C", X"8E", X"8F", X"89", X"8A", X"85", X"87", X"87", X"8D", X"8E", X"95", X"95", X"93", X"98", X"90", X"8A", X"89", X"8D", X"93", X"96", X"97", X"99", X"9B",
X"9C", X"9C", X"9D", X"9C", X"9B", X"9C", X"9B", X"99", X"9A", X"9D", X"9E", X"A3", X"A8", X"A8", X"A9", X"A8", X"A8", X"A1", X"9F", X"99", X"98", X"96", X"95", X"94", X"92", X"97", X"96", X"96", X"96", X"95", X"96", X"96",
--42
X"95", X"94", X"93", X"94", X"93", X"92", X"92", X"92", X"92", X"92", X"91", X"92", X"92", X"94", X"94", X"93", X"93", X"92", X"93", X"92", X"92", X"84", X"82", X"86", X"8D", X"91", X"93", X"93", X"95", X"97", X"99", X"98",
X"97", X"98", X"97", X"97", X"97", X"91", X"8C", X"85", X"84", X"81", X"76", X"76", X"76", X"76", X"76", X"78", X"76", X"74", X"73", X"73", X"77", X"7C", X"7C", X"82", X"84", X"81", X"79", X"77", X"77", X"76", X"74", X"74",
X"74", X"74", X"73", X"71", X"76", X"84", X"88", X"8C", X"8E", X"8E", X"8F", X"8E", X"86", X"86", X"85", X"89", X"8E", X"90", X"91", X"92", X"94", X"94", X"93", X"92", X"8C", X"89", X"8E", X"92", X"96", X"98", X"99", X"9C",
X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9B", X"9B", X"97", X"9A", X"9E", X"A6", X"A8", X"A7", X"A8", X"A9", X"A9", X"A3", X"A0", X"9B", X"98", X"96", X"94", X"90", X"93", X"95", X"96", X"95", X"96", X"95", X"96", X"96",
--43
X"95", X"94", X"94", X"94", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"96", X"93", X"93", X"91", X"92", X"92", X"91", X"91", X"8B", X"81", X"78", X"7F", X"89", X"8F", X"91", X"93", X"93", X"95", X"96", X"97", X"96",
X"95", X"97", X"94", X"93", X"8F", X"8A", X"85", X"83", X"84", X"7F", X"78", X"76", X"77", X"78", X"78", X"77", X"7A", X"78", X"75", X"72", X"7B", X"7D", X"7D", X"84", X"81", X"7B", X"77", X"77", X"76", X"75", X"71", X"74",
X"74", X"73", X"71", X"74", X"7A", X"86", X"8A", X"8C", X"8F", X"8F", X"8F", X"8B", X"86", X"85", X"84", X"88", X"8C", X"90", X"93", X"94", X"93", X"93", X"93", X"92", X"8E", X"88", X"8B", X"8E", X"95", X"96", X"97", X"9A",
X"9B", X"9C", X"9C", X"9C", X"9C", X"9C", X"9B", X"9A", X"97", X"9A", X"9D", X"A1", X"A5", X"A7", X"A8", X"AA", X"A9", X"A4", X"A3", X"9C", X"98", X"94", X"92", X"92", X"94", X"96", X"96", X"96", X"97", X"96", X"96", X"96",
--44
X"95", X"94", X"94", X"94", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"93", X"92", X"93", X"93", X"92", X"91", X"8F", X"8D", X"88", X"81", X"7F", X"82", X"88", X"8F", X"91", X"93", X"93", X"94", X"95", X"96", X"96",
X"95", X"95", X"91", X"8D", X"8A", X"89", X"80", X"7E", X"7D", X"7D", X"7C", X"79", X"7D", X"7B", X"7C", X"80", X"80", X"7D", X"7B", X"78", X"7C", X"7C", X"7D", X"81", X"7E", X"7A", X"76", X"76", X"76", X"75", X"72", X"71",
X"72", X"71", X"70", X"78", X"7F", X"87", X"89", X"8D", X"8E", X"8E", X"8E", X"87", X"85", X"7C", X"7E", X"83", X"8B", X"92", X"94", X"94", X"93", X"92", X"92", X"91", X"8E", X"89", X"8A", X"8A", X"91", X"92", X"94", X"9A",
X"9A", X"9A", X"9A", X"9B", X"9C", X"9C", X"9B", X"9D", X"9B", X"99", X"9A", X"9D", X"9F", X"A2", X"A5", X"A8", X"A7", X"A5", X"A3", X"9F", X"97", X"95", X"92", X"94", X"95", X"96", X"96", X"96", X"97", X"96", X"96", X"96",
--45
X"95", X"95", X"95", X"92", X"94", X"94", X"94", X"94", X"94", X"94", X"95", X"94", X"92", X"92", X"92", X"92", X"93", X"8F", X"8B", X"87", X"86", X"86", X"85", X"8B", X"8D", X"91", X"91", X"90", X"92", X"93", X"93", X"93",
X"92", X"93", X"8F", X"8B", X"88", X"88", X"80", X"7E", X"7F", X"81", X"80", X"7F", X"7E", X"7A", X"79", X"81", X"83", X"80", X"80", X"7C", X"7C", X"7C", X"7D", X"7D", X"7B", X"77", X"76", X"76", X"75", X"74", X"74", X"70",
X"6F", X"70", X"73", X"7B", X"82", X"8A", X"8B", X"8B", X"8C", X"8C", X"88", X"86", X"81", X"78", X"7B", X"80", X"8C", X"91", X"90", X"91", X"92", X"92", X"92", X"91", X"8D", X"8A", X"8A", X"8D", X"91", X"92", X"93", X"97",
X"98", X"98", X"99", X"9C", X"9D", X"9C", X"9D", X"9D", X"9D", X"9D", X"9B", X"98", X"9D", X"A1", X"A3", X"A7", X"A7", X"A6", X"A7", X"9E", X"98", X"92", X"91", X"93", X"96", X"96", X"96", X"96", X"97", X"97", X"97", X"97",
--46
X"95", X"95", X"95", X"93", X"95", X"94", X"94", X"94", X"94", X"94", X"95", X"94", X"92", X"92", X"92", X"92", X"94", X"86", X"8D", X"8C", X"8C", X"87", X"87", X"8C", X"8F", X"91", X"93", X"92", X"92", X"92", X"92", X"92",
X"90", X"8F", X"8F", X"8B", X"88", X"89", X"85", X"80", X"81", X"81", X"80", X"81", X"7F", X"7F", X"81", X"83", X"89", X"87", X"82", X"7C", X"7D", X"7C", X"7C", X"7B", X"7B", X"80", X"78", X"77", X"76", X"75", X"73", X"71",
X"6F", X"70", X"77", X"7E", X"88", X"8C", X"8C", X"88", X"88", X"87", X"85", X"86", X"80", X"7A", X"7D", X"83", X"8C", X"90", X"91", X"91", X"93", X"94", X"92", X"8F", X"8D", X"89", X"88", X"8F", X"90", X"91", X"93", X"96",
X"96", X"97", X"98", X"9B", X"9D", X"9D", X"9E", X"9E", X"9E", X"9E", X"9E", X"9C", X"94", X"97", X"9E", X"9F", X"A3", X"A4", X"A4", X"9C", X"99", X"8B", X"92", X"92", X"95", X"96", X"96", X"96", X"97", X"97", X"97", X"97",
--47
X"94", X"94", X"92", X"94", X"94", X"94", X"93", X"93", X"93", X"93", X"93", X"93", X"92", X"93", X"93", X"8E", X"89", X"88", X"8E", X"8E", X"8F", X"88", X"89", X"8D", X"90", X"8F", X"91", X"91", X"92", X"91", X"91", X"90",
X"91", X"94", X"8D", X"8B", X"88", X"87", X"83", X"7A", X"81", X"80", X"7F", X"81", X"82", X"83", X"82", X"87", X"89", X"88", X"81", X"77", X"79", X"7C", X"7B", X"7B", X"79", X"7A", X"77", X"76", X"75", X"75", X"72", X"73",
X"6A", X"72", X"78", X"81", X"87", X"8A", X"8C", X"87", X"85", X"84", X"85", X"81", X"80", X"83", X"86", X"89", X"8D", X"8F", X"90", X"91", X"8F", X"92", X"92", X"90", X"8B", X"89", X"8C", X"90", X"90", X"91", X"93", X"95",
X"95", X"96", X"98", X"9B", X"9D", X"9D", X"9F", X"9E", X"9E", X"9E", X"9D", X"9E", X"93", X"94", X"99", X"9E", X"A3", X"A6", X"A3", X"9B", X"97", X"91", X"91", X"94", X"97", X"96", X"96", X"96", X"97", X"97", X"97", X"97",
--48
X"94", X"94", X"95", X"94", X"95", X"94", X"93", X"93", X"93", X"93", X"93", X"93", X"94", X"92", X"8E", X"89", X"89", X"8E", X"8E", X"91", X"8F", X"8E", X"8A", X"8F", X"8D", X"90", X"98", X"92", X"8D", X"8F", X"90", X"90",
X"90", X"91", X"8F", X"8D", X"89", X"88", X"86", X"7F", X"7E", X"7F", X"80", X"82", X"88", X"8B", X"8A", X"8B", X"8B", X"87", X"80", X"77", X"77", X"79", X"7C", X"7B", X"7B", X"7A", X"77", X"77", X"76", X"6F", X"6C", X"6B",
X"6A", X"72", X"7A", X"81", X"87", X"8B", X"8D", X"89", X"86", X"85", X"83", X"7B", X"81", X"88", X"8A", X"8A", X"8C", X"90", X"8F", X"95", X"92", X"91", X"91", X"90", X"8B", X"8B", X"8D", X"90", X"90", X"91", X"93", X"95",
X"95", X"95", X"97", X"9B", X"9C", X"9D", X"9E", X"9E", X"9D", X"9E", X"9E", X"9F", X"97", X"8F", X"91", X"9E", X"A2", X"A0", X"9F", X"99", X"95", X"95", X"93", X"96", X"96", X"96", X"96", X"96", X"97", X"97", X"97", X"97",
--49
X"94", X"94", X"94", X"93", X"95", X"94", X"94", X"93", X"93", X"93", X"93", X"94", X"92", X"90", X"87", X"8B", X"8F", X"8F", X"91", X"93", X"91", X"8F", X"89", X"8D", X"8F", X"8F", X"94", X"93", X"91", X"94", X"91", X"91",
X"91", X"91", X"8F", X"8D", X"89", X"87", X"84", X"7E", X"7D", X"7E", X"82", X"87", X"8C", X"8F", X"90", X"8E", X"8C", X"88", X"83", X"79", X"74", X"77", X"7A", X"78", X"78", X"78", X"75", X"74", X"70", X"6B", X"69", X"68",
X"65", X"73", X"79", X"80", X"87", X"89", X"8B", X"8A", X"86", X"83", X"82", X"7E", X"80", X"87", X"8B", X"8B", X"8D", X"8F", X"8F", X"8F", X"8F", X"8F", X"8F", X"8F", X"8C", X"8B", X"8D", X"8F", X"90", X"90", X"92", X"95",
X"95", X"95", X"96", X"9B", X"9D", X"9E", X"9F", X"9E", X"9E", X"9F", X"9E", X"A0", X"9D", X"92", X"94", X"99", X"A1", X"9C", X"99", X"97", X"94", X"94", X"94", X"96", X"96", X"96", X"96", X"96", X"97", X"97", X"97", X"97",
--50
X"94", X"94", X"94", X"93", X"94", X"95", X"94", X"94", X"93", X"93", X"93", X"93", X"92", X"87", X"8F", X"90", X"91", X"92", X"92", X"92", X"91", X"8F", X"8A", X"8A", X"8F", X"90", X"91", X"93", X"91", X"92", X"91", X"90",
X"90", X"8E", X"8E", X"8C", X"89", X"88", X"85", X"82", X"7D", X"7C", X"83", X"88", X"8D", X"91", X"91", X"90", X"8C", X"8A", X"84", X"7F", X"7C", X"7A", X"7B", X"7A", X"7A", X"79", X"76", X"73", X"6C", X"6B", X"69", X"6A",
X"63", X"71", X"7A", X"7F", X"82", X"86", X"88", X"89", X"84", X"85", X"82", X"82", X"81", X"87", X"8C", X"8C", X"8C", X"8C", X"8D", X"8D", X"90", X"8F", X"8E", X"8A", X"8A", X"8B", X"8B", X"8F", X"8F", X"8F", X"91", X"94",
X"94", X"95", X"97", X"9C", X"9D", X"9E", X"A0", X"A0", X"9F", X"A1", X"A2", X"9F", X"A0", X"99", X"90", X"90", X"A2", X"96", X"92", X"92", X"92", X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"97",
--51
X"94", X"94", X"94", X"93", X"93", X"92", X"92", X"91", X"92", X"92", X"92", X"92", X"90", X"8C", X"93", X"92", X"93", X"94", X"93", X"92", X"92", X"8F", X"8D", X"8A", X"8C", X"91", X"8F", X"90", X"90", X"93", X"8F", X"91",
X"90", X"8E", X"8D", X"8C", X"89", X"87", X"85", X"83", X"7D", X"7B", X"82", X"82", X"8B", X"91", X"92", X"91", X"8E", X"8F", X"89", X"81", X"7E", X"7D", X"7C", X"7B", X"7A", X"78", X"75", X"72", X"6B", X"6E", X"6A", X"68",
X"69", X"75", X"77", X"7E", X"83", X"84", X"87", X"87", X"82", X"84", X"7D", X"81", X"82", X"87", X"8B", X"8A", X"8B", X"8A", X"8C", X"8C", X"90", X"8E", X"8C", X"87", X"85", X"89", X"8B", X"8E", X"8F", X"8F", X"91", X"93",
X"94", X"94", X"97", X"9C", X"9E", X"9F", X"A0", X"A0", X"A0", X"A1", X"A1", X"A1", X"9E", X"99", X"98", X"96", X"95", X"94", X"91", X"8C", X"91", X"96", X"98", X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"97",
--52
X"93", X"93", X"94", X"93", X"93", X"94", X"93", X"93", X"92", X"92", X"92", X"93", X"90", X"93", X"93", X"94", X"94", X"93", X"92", X"93", X"92", X"90", X"8E", X"89", X"8C", X"90", X"8F", X"90", X"90", X"96", X"8F", X"90",
X"90", X"8E", X"8D", X"8B", X"8A", X"87", X"84", X"80", X"77", X"78", X"7B", X"7B", X"85", X"8E", X"92", X"90", X"8D", X"8A", X"86", X"85", X"85", X"81", X"80", X"7E", X"7C", X"7A", X"75", X"74", X"6B", X"6C", X"69", X"68",
X"68", X"78", X"7C", X"81", X"82", X"85", X"87", X"85", X"81", X"80", X"78", X"7C", X"86", X"86", X"89", X"89", X"8A", X"8C", X"90", X"8F", X"8C", X"8C", X"86", X"7F", X"82", X"84", X"8B", X"8E", X"8F", X"8F", X"91", X"93",
X"94", X"95", X"97", X"9B", X"9F", X"9E", X"A0", X"A1", X"A1", X"A2", X"A2", X"A1", X"A0", X"9B", X"97", X"93", X"93", X"94", X"91", X"92", X"93", X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"97",
--53
X"94", X"90", X"94", X"92", X"93", X"93", X"92", X"92", X"92", X"92", X"91", X"92", X"90", X"94", X"94", X"94", X"95", X"94", X"94", X"95", X"93", X"95", X"89", X"8A", X"8E", X"8F", X"90", X"90", X"8F", X"93", X"90", X"8F",
X"8F", X"8D", X"8C", X"8B", X"8A", X"86", X"83", X"7F", X"78", X"77", X"75", X"78", X"7F", X"8C", X"90", X"91", X"8D", X"86", X"86", X"84", X"82", X"81", X"80", X"7F", X"7C", X"79", X"75", X"74", X"6C", X"6C", X"69", X"66",
X"68", X"71", X"7E", X"7F", X"80", X"82", X"85", X"82", X"7F", X"79", X"75", X"7B", X"82", X"85", X"87", X"88", X"8B", X"8C", X"8C", X"8B", X"87", X"89", X"7E", X"74", X"81", X"87", X"8A", X"8D", X"8E", X"8F", X"90", X"93",
X"94", X"95", X"97", X"9B", X"9F", X"9E", X"A0", X"A1", X"A1", X"A2", X"A2", X"A2", X"A0", X"9B", X"98", X"8E", X"85", X"89", X"91", X"95", X"95", X"98", X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"97",
--54
X"93", X"90", X"95", X"93", X"93", X"93", X"94", X"94", X"94", X"94", X"93", X"91", X"92", X"93", X"95", X"95", X"95", X"95", X"95", X"95", X"93", X"8D", X"85", X"88", X"90", X"8F", X"90", X"90", X"90", X"8E", X"8E", X"8F",
X"8F", X"8D", X"8C", X"8B", X"8A", X"85", X"83", X"80", X"77", X"73", X"71", X"71", X"79", X"85", X"8E", X"8D", X"8D", X"86", X"81", X"81", X"81", X"7F", X"7C", X"7F", X"7C", X"7A", X"77", X"75", X"73", X"6E", X"69", X"66",
X"65", X"6D", X"7C", X"7E", X"83", X"83", X"83", X"7E", X"7A", X"6F", X"79", X"74", X"82", X"83", X"84", X"86", X"88", X"8B", X"8B", X"8B", X"87", X"87", X"7F", X"7C", X"81", X"87", X"88", X"8C", X"8E", X"8F", X"90", X"91",
X"94", X"95", X"97", X"9B", X"9F", X"9F", X"A1", X"A0", X"A0", X"A2", X"A1", X"A1", X"A0", X"9B", X"97", X"8B", X"85", X"8F", X"95", X"97", X"98", X"98", X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"97",
--55
X"94", X"93", X"94", X"93", X"95", X"94", X"94", X"94", X"95", X"93", X"91", X"93", X"93", X"94", X"96", X"96", X"96", X"96", X"96", X"94", X"93", X"8B", X"88", X"88", X"8B", X"8F", X"8F", X"90", X"90", X"8F", X"8F", X"8F",
X"8F", X"8E", X"8C", X"8B", X"8A", X"87", X"82", X"7F", X"75", X"72", X"6D", X"74", X"79", X"7D", X"86", X"8C", X"8B", X"86", X"7F", X"7B", X"7B", X"79", X"7A", X"7B", X"7B", X"7B", X"7A", X"76", X"79", X"75", X"68", X"60",
X"5B", X"68", X"76", X"7D", X"83", X"83", X"82", X"7B", X"7A", X"70", X"7B", X"7C", X"82", X"82", X"84", X"85", X"83", X"85", X"86", X"8A", X"83", X"7C", X"7C", X"7B", X"84", X"87", X"89", X"8C", X"8C", X"8E", X"90", X"92",
X"94", X"95", X"98", X"9B", X"A0", X"A0", X"A1", X"A0", X"A1", X"A2", X"A2", X"A1", X"A0", X"9A", X"97", X"92", X"91", X"93", X"98", X"97", X"98", X"98", X"98", X"98", X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"97",
--56
X"93", X"95", X"94", X"94", X"93", X"94", X"94", X"95", X"92", X"94", X"93", X"93", X"93", X"94", X"96", X"95", X"96", X"95", X"96", X"95", X"94", X"8C", X"88", X"7D", X"84", X"8B", X"8F", X"8E", X"8E", X"8E", X"8E", X"8F",
X"8E", X"8D", X"8C", X"8B", X"8A", X"86", X"81", X"7E", X"74", X"6F", X"6A", X"75", X"78", X"7C", X"7D", X"87", X"89", X"82", X"7D", X"7B", X"78", X"78", X"77", X"78", X"78", X"77", X"78", X"77", X"7D", X"7C", X"78", X"59",
X"5C", X"62", X"71", X"7B", X"7E", X"7E", X"7D", X"79", X"70", X"79", X"7A", X"7D", X"81", X"82", X"83", X"84", X"84", X"84", X"84", X"81", X"7C", X"79", X"7B", X"7A", X"83", X"85", X"88", X"8B", X"8B", X"8E", X"90", X"92",
X"94", X"95", X"98", X"9C", X"A1", X"A1", X"A1", X"A1", X"A1", X"A2", X"A2", X"A1", X"A0", X"9B", X"98", X"93", X"94", X"97", X"98", X"97", X"98", X"98", X"98", X"98", X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"97",
--57
X"93", X"94", X"93", X"95", X"94", X"94", X"95", X"95", X"95", X"94", X"92", X"93", X"93", X"94", X"95", X"95", X"95", X"95", X"95", X"95", X"94", X"8F", X"8D", X"87", X"85", X"85", X"8A", X"8D", X"8D", X"8D", X"8D", X"8E",
X"8E", X"8C", X"8B", X"8C", X"89", X"82", X"7E", X"7D", X"76", X"75", X"76", X"79", X"78", X"7C", X"7C", X"80", X"83", X"7D", X"7C", X"7A", X"75", X"70", X"72", X"74", X"76", X"75", X"75", X"76", X"79", X"7E", X"95", X"86",
X"7C", X"72", X"74", X"79", X"7C", X"7B", X"7A", X"7A", X"74", X"77", X"76", X"7C", X"81", X"81", X"82", X"82", X"81", X"83", X"80", X"7A", X"76", X"72", X"72", X"75", X"83", X"87", X"88", X"8B", X"8B", X"8F", X"91", X"92",
X"94", X"95", X"9A", X"9C", X"A1", X"A1", X"A1", X"A2", X"A1", X"A2", X"A2", X"A1", X"A0", X"9B", X"97", X"93", X"95", X"96", X"98", X"98", X"98", X"98", X"98", X"98", X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"97",
--58
X"94", X"94", X"94", X"94", X"94", X"94", X"93", X"96", X"95", X"95", X"92", X"93", X"93", X"94", X"95", X"94", X"94", X"95", X"95", X"95", X"94", X"92", X"8E", X"8A", X"85", X"83", X"85", X"89", X"8C", X"8D", X"8D", X"8E",
X"8E", X"8C", X"8B", X"8B", X"8A", X"81", X"7D", X"7D", X"76", X"76", X"78", X"79", X"7B", X"7B", X"79", X"7A", X"7C", X"78", X"75", X"75", X"72", X"6F", X"6D", X"6E", X"6F", X"6E", X"70", X"72", X"72", X"7A", X"8E", X"8E",
X"92", X"89", X"88", X"83", X"7F", X"7C", X"7D", X"77", X"73", X"74", X"73", X"77", X"7A", X"7D", X"7D", X"7D", X"78", X"75", X"74", X"71", X"71", X"71", X"71", X"75", X"78", X"85", X"87", X"8B", X"8B", X"8E", X"90", X"92",
X"93", X"95", X"9A", X"9E", X"A0", X"A1", X"A3", X"A2", X"A2", X"A2", X"A2", X"A1", X"A0", X"9A", X"99", X"92", X"94", X"95", X"98", X"98", X"98", X"98", X"98", X"98", X"97", X"96", X"96", X"97", X"97", X"97", X"97", X"97",
--59
X"95", X"95", X"95", X"95", X"95", X"95", X"94", X"95", X"94", X"95", X"93", X"93", X"93", X"94", X"95", X"95", X"95", X"95", X"95", X"95", X"94", X"92", X"91", X"8F", X"86", X"83", X"83", X"83", X"89", X"8B", X"8A", X"8B",
X"8B", X"88", X"88", X"85", X"85", X"80", X"7D", X"7A", X"75", X"7B", X"7A", X"7C", X"7A", X"78", X"76", X"74", X"6D", X"6B", X"6B", X"6F", X"71", X"70", X"70", X"6D", X"6A", X"6B", X"6B", X"6C", X"6F", X"74", X"7B", X"88",
X"8B", X"91", X"93", X"8C", X"85", X"7E", X"7B", X"76", X"72", X"74", X"74", X"74", X"75", X"7B", X"7C", X"7A", X"74", X"73", X"73", X"71", X"71", X"72", X"73", X"73", X"77", X"84", X"88", X"8A", X"8B", X"8D", X"8F", X"92",
X"93", X"96", X"9A", X"9E", X"A0", X"A2", X"A3", X"A2", X"A2", X"A2", X"A2", X"A1", X"9F", X"9A", X"95", X"92", X"94", X"96", X"98", X"97", X"98", X"98", X"98", X"98", X"97", X"97", X"97", X"98", X"98", X"98", X"97", X"98",
--60
X"95", X"95", X"95", X"96", X"96", X"96", X"95", X"95", X"95", X"94", X"92", X"92", X"92", X"94", X"95", X"96", X"95", X"95", X"95", X"95", X"94", X"93", X"90", X"8E", X"8A", X"88", X"81", X"7D", X"83", X"86", X"88", X"89",
X"8A", X"89", X"88", X"85", X"80", X"7D", X"7D", X"7C", X"7A", X"7B", X"7B", X"7B", X"7B", X"79", X"76", X"6E", X"69", X"67", X"69", X"6B", X"6A", X"71", X"71", X"6E", X"6A", X"6B", X"6B", X"6D", X"70", X"74", X"73", X"7A",
X"7E", X"7D", X"84", X"88", X"89", X"86", X"7D", X"79", X"74", X"75", X"74", X"72", X"75", X"78", X"75", X"75", X"72", X"72", X"72", X"73", X"72", X"71", X"71", X"71", X"78", X"7E", X"86", X"8A", X"8B", X"8C", X"8F", X"92",
X"93", X"97", X"9B", X"9E", X"A1", X"A2", X"A2", X"A2", X"A2", X"A2", X"A2", X"A1", X"9F", X"97", X"8E", X"93", X"93", X"96", X"97", X"97", X"98", X"98", X"98", X"99", X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"98",
--61
X"95", X"97", X"96", X"96", X"96", X"96", X"95", X"95", X"94", X"94", X"93", X"93", X"94", X"96", X"95", X"95", X"95", X"95", X"95", X"95", X"94", X"92", X"91", X"8F", X"8D", X"8C", X"86", X"7F", X"80", X"80", X"86", X"89",
X"8D", X"8C", X"87", X"82", X"7F", X"7D", X"7B", X"7C", X"7B", X"7B", X"7B", X"7B", X"7C", X"78", X"75", X"6D", X"6A", X"6A", X"5E", X"73", X"6F", X"69", X"72", X"71", X"6D", X"6C", X"6C", X"68", X"73", X"72", X"73", X"77",
X"72", X"73", X"7F", X"83", X"88", X"89", X"84", X"85", X"81", X"81", X"83", X"78", X"78", X"77", X"71", X"73", X"75", X"76", X"78", X"7C", X"78", X"75", X"72", X"74", X"78", X"7D", X"86", X"89", X"8A", X"8D", X"8E", X"93",
X"95", X"99", X"9B", X"9E", X"A1", X"A2", X"A2", X"A2", X"A2", X"A2", X"A2", X"A0", X"9C", X"97", X"8A", X"8C", X"8F", X"96", X"96", X"98", X"97", X"98", X"99", X"98", X"98", X"98", X"98", X"98", X"98", X"99", X"98", X"99",
--62
X"96", X"97", X"96", X"96", X"96", X"96", X"95", X"95", X"96", X"92", X"8F", X"90", X"93", X"95", X"94", X"95", X"95", X"95", X"95", X"95", X"94", X"92", X"91", X"8F", X"8D", X"8E", X"8B", X"85", X"80", X"80", X"84", X"86",
X"86", X"86", X"85", X"81", X"7E", X"79", X"79", X"7C", X"7B", X"7B", X"7B", X"7B", X"77", X"77", X"75", X"6F", X"71", X"6A", X"69", X"79", X"74", X"76", X"74", X"73", X"72", X"6F", X"6F", X"6E", X"6C", X"6D", X"71", X"73",
X"78", X"7D", X"7D", X"83", X"85", X"87", X"7F", X"82", X"88", X"86", X"83", X"80", X"81", X"7E", X"78", X"7D", X"81", X"86", X"88", X"88", X"8A", X"80", X"7B", X"77", X"78", X"7D", X"85", X"8A", X"8B", X"8D", X"8F", X"92",
X"95", X"98", X"9B", X"9E", X"A0", X"A2", X"A2", X"A2", X"A2", X"A2", X"A3", X"9F", X"94", X"8E", X"85", X"80", X"84", X"8E", X"91", X"96", X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"99", X"99", X"99",
--63
X"96", X"96", X"96", X"96", X"96", X"96", X"95", X"95", X"96", X"90", X"8A", X"8C", X"93", X"95", X"94", X"95", X"95", X"95", X"95", X"95", X"94", X"95", X"91", X"8F", X"8F", X"8E", X"8C", X"8B", X"83", X"80", X"80", X"80",
X"81", X"81", X"81", X"82", X"79", X"75", X"7C", X"7D", X"7D", X"7D", X"7D", X"7D", X"7B", X"7B", X"77", X"74", X"72", X"6D", X"6C", X"72", X"77", X"76", X"76", X"75", X"74", X"74", X"75", X"76", X"75", X"73", X"70", X"71",
X"76", X"79", X"7D", X"84", X"86", X"89", X"85", X"89", X"87", X"85", X"84", X"83", X"81", X"83", X"89", X"8D", X"8E", X"91", X"8F", X"8F", X"8F", X"88", X"7B", X"76", X"7A", X"7D", X"85", X"8A", X"8C", X"8D", X"8F", X"91",
X"95", X"98", X"9B", X"9E", X"9F", X"A1", X"A2", X"A1", X"A1", X"A2", X"A2", X"A0", X"93", X"8E", X"86", X"82", X"87", X"8A", X"8D", X"94", X"97", X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"99", X"9A", X"99",
--64
X"96", X"97", X"96", X"96", X"96", X"97", X"95", X"95", X"95", X"91", X"8C", X"8C", X"94", X"95", X"95", X"95", X"95", X"95", X"94", X"95", X"95", X"97", X"92", X"8F", X"8E", X"8E", X"8D", X"8C", X"89", X"84", X"80", X"7B",
X"78", X"78", X"7B", X"78", X"72", X"71", X"7C", X"7E", X"7E", X"7E", X"7E", X"7E", X"7E", X"7F", X"7E", X"7E", X"7B", X"73", X"70", X"74", X"76", X"78", X"76", X"75", X"74", X"75", X"76", X"75", X"76", X"76", X"75", X"76",
X"79", X"7A", X"7C", X"7B", X"81", X"83", X"83", X"83", X"84", X"82", X"83", X"84", X"88", X"85", X"8C", X"90", X"92", X"92", X"91", X"8E", X"8D", X"84", X"79", X"73", X"76", X"7E", X"85", X"8A", X"8D", X"8D", X"8F", X"91",
X"94", X"98", X"9B", X"9E", X"9F", X"A1", X"A2", X"A1", X"A1", X"A2", X"A2", X"A0", X"93", X"8E", X"8A", X"8D", X"8C", X"8C", X"89", X"8E", X"96", X"98", X"99", X"98", X"98", X"98", X"98", X"98", X"98", X"99", X"99", X"99",
--65
X"96", X"97", X"97", X"97", X"97", X"93", X"9B", X"94", X"94", X"90", X"8D", X"8B", X"92", X"93", X"97", X"93", X"94", X"94", X"94", X"93", X"93", X"92", X"8F", X"8E", X"8F", X"8E", X"8C", X"8C", X"88", X"85", X"7F", X"78",
X"74", X"70", X"70", X"70", X"6E", X"72", X"7C", X"7F", X"80", X"80", X"80", X"80", X"82", X"83", X"83", X"82", X"81", X"7C", X"78", X"77", X"78", X"78", X"78", X"76", X"76", X"77", X"78", X"78", X"77", X"78", X"78", X"7B",
X"7B", X"7C", X"7E", X"7F", X"83", X"81", X"7D", X"7A", X"7E", X"78", X"7F", X"85", X"88", X"88", X"8D", X"8F", X"8D", X"8D", X"8B", X"88", X"84", X"7D", X"73", X"75", X"78", X"7D", X"83", X"88", X"8C", X"8D", X"8E", X"92",
X"95", X"98", X"9C", X"9E", X"9F", X"A2", X"A3", X"A2", X"A3", X"A4", X"A2", X"A0", X"99", X"94", X"94", X"95", X"94", X"90", X"8C", X"8D", X"94", X"97", X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"99", X"99",
--66
X"96", X"97", X"97", X"97", X"97", X"96", X"9B", X"95", X"94", X"91", X"8C", X"89", X"8E", X"93", X"97", X"92", X"95", X"94", X"94", X"93", X"93", X"93", X"91", X"92", X"91", X"8F", X"8C", X"8C", X"88", X"85", X"7F", X"79",
X"76", X"72", X"72", X"71", X"69", X"76", X"7F", X"85", X"84", X"84", X"84", X"84", X"84", X"87", X"88", X"8A", X"8E", X"85", X"7D", X"7B", X"7A", X"78", X"79", X"78", X"77", X"79", X"79", X"79", X"78", X"78", X"7B", X"7A",
X"79", X"7D", X"85", X"84", X"82", X"82", X"7D", X"83", X"82", X"84", X"83", X"86", X"8A", X"89", X"8C", X"8B", X"87", X"85", X"85", X"84", X"7D", X"76", X"72", X"71", X"74", X"7F", X"88", X"8A", X"8B", X"8D", X"8E", X"91",
X"95", X"98", X"9C", X"9E", X"9F", X"A3", X"A2", X"A2", X"A3", X"A3", X"A2", X"A0", X"99", X"96", X"97", X"9B", X"9B", X"96", X"90", X"91", X"93", X"94", X"95", X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"99",
--67
X"96", X"97", X"97", X"97", X"97", X"9A", X"98", X"97", X"93", X"90", X"86", X"89", X"8D", X"93", X"92", X"93", X"92", X"93", X"92", X"92", X"92", X"93", X"91", X"91", X"91", X"8F", X"8D", X"8C", X"88", X"85", X"80", X"7B",
X"7A", X"79", X"72", X"70", X"72", X"81", X"87", X"87", X"88", X"87", X"87", X"87", X"87", X"90", X"91", X"92", X"92", X"8A", X"7F", X"7D", X"7A", X"7A", X"79", X"79", X"7A", X"79", X"79", X"79", X"79", X"77", X"7B", X"7A",
X"7B", X"7D", X"81", X"86", X"88", X"86", X"85", X"84", X"84", X"87", X"93", X"8C", X"8C", X"89", X"87", X"86", X"86", X"85", X"84", X"83", X"7D", X"73", X"70", X"6F", X"73", X"7C", X"89", X"89", X"8D", X"8E", X"8E", X"8F",
X"93", X"97", X"9B", X"9E", X"9D", X"9F", X"A3", X"A2", X"A2", X"A2", X"A1", X"A0", X"9C", X"9B", X"9D", X"A1", X"A0", X"97", X"96", X"96", X"97", X"93", X"93", X"97", X"97", X"98", X"98", X"98", X"98", X"98", X"98", X"98",
--68
X"96", X"97", X"97", X"97", X"97", X"97", X"98", X"96", X"94", X"90", X"85", X"89", X"8C", X"94", X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"93", X"91", X"91", X"91", X"8F", X"8D", X"8C", X"88", X"85", X"80", X"7B",
X"7D", X"7B", X"74", X"72", X"73", X"82", X"8A", X"89", X"89", X"89", X"88", X"8A", X"8A", X"8F", X"93", X"94", X"93", X"8B", X"86", X"83", X"7A", X"79", X"7B", X"79", X"7B", X"7A", X"7B", X"7C", X"85", X"7A", X"7B", X"7B",
X"6E", X"74", X"78", X"80", X"85", X"88", X"8D", X"9E", X"8F", X"97", X"98", X"8C", X"89", X"81", X"81", X"81", X"85", X"86", X"86", X"83", X"7D", X"74", X"70", X"70", X"75", X"82", X"89", X"8A", X"8D", X"8E", X"8F", X"90",
X"93", X"97", X"9B", X"9C", X"9D", X"9D", X"9F", X"A5", X"A5", X"A2", X"A1", X"A0", X"9D", X"9D", X"9F", X"A6", X"A5", X"A2", X"9D", X"98", X"98", X"93", X"94", X"96", X"98", X"97", X"99", X"98", X"98", X"98", X"98", X"99",
--69
X"96", X"97", X"97", X"97", X"97", X"97", X"98", X"96", X"94", X"90", X"88", X"87", X"8D", X"93", X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"92", X"91", X"91", X"92", X"8F", X"8D", X"8C", X"88", X"85", X"80", X"7E",
X"7E", X"7B", X"75", X"74", X"77", X"83", X"8C", X"8C", X"8C", X"8D", X"8E", X"8F", X"8F", X"8F", X"91", X"91", X"92", X"90", X"8E", X"85", X"7C", X"79", X"7B", X"7B", X"7C", X"7C", X"7B", X"7B", X"80", X"7D", X"7C", X"7C",
X"76", X"79", X"7C", X"7B", X"81", X"83", X"84", X"82", X"85", X"84", X"82", X"81", X"7F", X"81", X"79", X"75", X"78", X"7E", X"7C", X"7B", X"7B", X"78", X"76", X"72", X"75", X"83", X"89", X"8A", X"8D", X"8D", X"8E", X"90",
X"93", X"98", X"9B", X"9C", X"9D", X"9D", X"9F", X"A4", X"A6", X"A2", X"A2", X"9C", X"9A", X"9C", X"A0", X"A7", X"A9", X"A6", X"9F", X"9B", X"9B", X"97", X"95", X"92", X"95", X"96", X"97", X"97", X"98", X"98", X"98", X"99",
--70
X"96", X"97", X"97", X"97", X"97", X"97", X"98", X"97", X"95", X"8F", X"87", X"87", X"8F", X"93", X"93", X"92", X"92", X"92", X"92", X"92", X"91", X"92", X"91", X"91", X"91", X"8E", X"8C", X"8A", X"88", X"84", X"80", X"7A",
X"7D", X"7C", X"79", X"79", X"7C", X"85", X"8D", X"8C", X"8E", X"8E", X"91", X"91", X"91", X"92", X"92", X"92", X"95", X"92", X"90", X"86", X"81", X"7D", X"79", X"7A", X"7A", X"7A", X"7C", X"7C", X"7E", X"7D", X"7F", X"7C",
X"7C", X"7D", X"7C", X"7E", X"7E", X"7E", X"80", X"7D", X"7E", X"7D", X"7E", X"7D", X"7D", X"7E", X"7A", X"73", X"72", X"76", X"78", X"7A", X"7A", X"7A", X"7A", X"76", X"79", X"82", X"89", X"8A", X"8C", X"8D", X"8D", X"8D",
X"92", X"96", X"99", X"9A", X"9C", X"9C", X"9E", X"A2", X"A4", X"A4", X"A1", X"97", X"98", X"9A", X"A3", X"A6", X"A8", X"A8", X"A4", X"A1", X"9F", X"99", X"96", X"90", X"8F", X"92", X"94", X"96", X"98", X"98", X"98", X"99",
--71
X"96", X"97", X"97", X"97", X"97", X"97", X"98", X"97", X"96", X"8D", X"87", X"87", X"90", X"90", X"90", X"91", X"90", X"91", X"91", X"91", X"91", X"91", X"91", X"91", X"91", X"8E", X"8B", X"8B", X"85", X"84", X"83", X"84",
X"85", X"7C", X"77", X"78", X"7E", X"86", X"8B", X"8F", X"90", X"92", X"92", X"92", X"94", X"96", X"97", X"94", X"95", X"95", X"94", X"8C", X"88", X"7C", X"7A", X"79", X"78", X"7B", X"7C", X"7B", X"7C", X"7B", X"7B", X"7C",
X"79", X"7B", X"7C", X"7E", X"7E", X"7D", X"7F", X"7E", X"7F", X"7E", X"7E", X"7E", X"7E", X"7E", X"7C", X"73", X"71", X"6F", X"74", X"78", X"7A", X"79", X"7A", X"77", X"7C", X"85", X"8B", X"8A", X"8C", X"8C", X"8E", X"8E",
X"92", X"96", X"99", X"9B", X"9C", X"9D", X"9E", X"A1", X"A1", X"A0", X"9D", X"96", X"96", X"9B", X"A2", X"A7", X"A9", X"A7", X"A4", X"A3", X"9F", X"9A", X"95", X"90", X"8B", X"91", X"92", X"95", X"98", X"99", X"98", X"99",
--72
X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"95", X"91", X"8A", X"89", X"91", X"92", X"8F", X"8F", X"8F", X"91", X"90", X"90", X"90", X"91", X"90", X"8F", X"8F", X"8D", X"8B", X"8A", X"84", X"83", X"84", X"85",
X"82", X"82", X"77", X"7D", X"84", X"89", X"8E", X"92", X"93", X"94", X"96", X"96", X"97", X"98", X"98", X"99", X"97", X"97", X"96", X"96", X"8B", X"83", X"7A", X"75", X"74", X"78", X"79", X"79", X"79", X"79", X"79", X"78",
X"77", X"7A", X"7B", X"7B", X"7D", X"7D", X"7D", X"7C", X"7C", X"78", X"7C", X"7C", X"7E", X"7C", X"7A", X"73", X"71", X"71", X"75", X"78", X"7A", X"7A", X"7A", X"72", X"7C", X"84", X"88", X"89", X"8A", X"8A", X"8B", X"8D",
X"91", X"97", X"99", X"9A", X"9A", X"9B", X"9B", X"9D", X"9B", X"9A", X"97", X"8D", X"98", X"9D", X"A3", X"A6", X"A6", X"A6", X"A4", X"A5", X"A1", X"9C", X"95", X"90", X"8E", X"95", X"96", X"97", X"98", X"98", X"98", X"99",
--73
X"97", X"97", X"97", X"97", X"97", X"96", X"97", X"96", X"96", X"93", X"8C", X"89", X"8C", X"91", X"8F", X"8C", X"8D", X"8F", X"90", X"8F", X"8F", X"8F", X"8E", X"8E", X"8D", X"8B", X"89", X"89", X"82", X"82", X"84", X"86",
X"83", X"82", X"83", X"86", X"88", X"8B", X"8E", X"92", X"92", X"94", X"96", X"97", X"98", X"99", X"98", X"99", X"98", X"99", X"97", X"97", X"90", X"88", X"7D", X"76", X"71", X"6F", X"72", X"77", X"78", X"76", X"76", X"77",
X"75", X"79", X"78", X"79", X"79", X"7A", X"7B", X"7C", X"79", X"76", X"7A", X"7B", X"7B", X"7A", X"7A", X"74", X"79", X"7A", X"7F", X"7F", X"7E", X"7B", X"7C", X"79", X"7E", X"83", X"87", X"88", X"88", X"88", X"8A", X"8D",
X"91", X"95", X"97", X"99", X"99", X"99", X"99", X"99", X"9B", X"98", X"90", X"8F", X"9C", X"9D", X"A3", X"A5", X"A4", X"A5", X"A5", X"A3", X"A2", X"9C", X"97", X"93", X"92", X"96", X"98", X"98", X"98", X"99", X"99", X"99",
--74
X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"96", X"95", X"94", X"8C", X"89", X"87", X"8D", X"8D", X"8D", X"8D", X"8E", X"8C", X"8D", X"8C", X"8C", X"8A", X"88", X"88", X"87", X"86", X"85", X"83", X"83", X"82", X"82",
X"83", X"7B", X"85", X"89", X"8C", X"8D", X"90", X"92", X"94", X"94", X"95", X"96", X"97", X"98", X"99", X"99", X"98", X"9B", X"98", X"98", X"96", X"8F", X"84", X"7B", X"72", X"6E", X"6C", X"6E", X"71", X"73", X"6F", X"70",
X"73", X"75", X"74", X"72", X"74", X"76", X"76", X"78", X"77", X"71", X"77", X"79", X"79", X"73", X"73", X"75", X"78", X"81", X"7F", X"80", X"80", X"7D", X"7E", X"80", X"80", X"81", X"83", X"85", X"85", X"86", X"88", X"8A",
X"8F", X"92", X"96", X"98", X"97", X"99", X"97", X"99", X"96", X"8F", X"8F", X"93", X"9B", X"9E", X"A3", X"A5", X"A4", X"A5", X"A2", X"A3", X"A3", X"9E", X"96", X"93", X"94", X"96", X"97", X"99", X"99", X"9A", X"99", X"99",
--75
X"96", X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"95", X"94", X"90", X"8A", X"85", X"8B", X"8D", X"8D", X"8C", X"8D", X"8D", X"8C", X"8C", X"8C", X"89", X"87", X"87", X"85", X"84", X"83", X"83", X"82", X"81", X"81",
X"81", X"7B", X"87", X"8C", X"8E", X"91", X"92", X"93", X"93", X"94", X"95", X"96", X"96", X"99", X"9D", X"9D", X"9A", X"9C", X"97", X"98", X"9A", X"90", X"89", X"7E", X"78", X"70", X"69", X"6A", X"6B", X"6C", X"6B", X"6A",
X"6B", X"6C", X"73", X"6F", X"71", X"74", X"78", X"78", X"74", X"72", X"79", X"78", X"79", X"75", X"6F", X"75", X"78", X"85", X"83", X"82", X"82", X"7F", X"7F", X"7F", X"80", X"82", X"82", X"83", X"84", X"85", X"86", X"87",
X"8D", X"91", X"93", X"98", X"98", X"98", X"97", X"95", X"93", X"8D", X"8C", X"93", X"9A", X"9D", X"A2", X"A6", X"A7", X"A6", X"A3", X"A3", X"A3", X"9E", X"97", X"93", X"94", X"95", X"98", X"99", X"99", X"9A", X"99", X"99",
--76
X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"96", X"95", X"95", X"93", X"90", X"8A", X"85", X"85", X"8A", X"8D", X"8C", X"8C", X"8B", X"8A", X"8A", X"89", X"85", X"84", X"82", X"84", X"83", X"82", X"81", X"81", X"81",
X"80", X"7F", X"86", X"8C", X"8F", X"92", X"92", X"92", X"92", X"94", X"95", X"95", X"95", X"99", X"9C", X"9D", X"99", X"9C", X"9A", X"97", X"99", X"93", X"8C", X"85", X"82", X"79", X"6D", X"69", X"65", X"68", X"66", X"64",
X"6C", X"6C", X"73", X"72", X"78", X"79", X"7D", X"7F", X"7F", X"7C", X"79", X"78", X"79", X"77", X"76", X"77", X"78", X"82", X"81", X"81", X"7E", X"7F", X"7D", X"7D", X"7E", X"80", X"81", X"83", X"83", X"86", X"86", X"86",
X"8A", X"8D", X"8E", X"94", X"9A", X"97", X"93", X"92", X"8D", X"8B", X"8C", X"94", X"99", X"9D", X"A1", X"A2", X"A3", X"A3", X"A1", X"A1", X"A1", X"9D", X"97", X"93", X"95", X"93", X"99", X"99", X"99", X"99", X"99", X"99",
--77
X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"96", X"95", X"94", X"93", X"94", X"90", X"83", X"81", X"88", X"8A", X"8B", X"8A", X"8A", X"8A", X"89", X"88", X"86", X"84", X"83", X"83", X"82", X"82", X"82", X"81", X"82",
X"81", X"81", X"85", X"8C", X"8F", X"91", X"92", X"94", X"95", X"94", X"95", X"95", X"95", X"97", X"99", X"99", X"99", X"9C", X"97", X"99", X"97", X"92", X"8B", X"88", X"85", X"80", X"7A", X"73", X"71", X"6D", X"6C", X"59",
X"6A", X"6C", X"71", X"73", X"77", X"7B", X"7F", X"80", X"80", X"80", X"7D", X"80", X"7F", X"7F", X"78", X"76", X"77", X"7D", X"7C", X"7C", X"77", X"79", X"7B", X"7F", X"7E", X"80", X"82", X"83", X"83", X"85", X"85", X"85",
X"86", X"85", X"89", X"8E", X"93", X"8E", X"8D", X"89", X"87", X"8E", X"93", X"98", X"99", X"9D", X"A1", X"A2", X"A2", X"A3", X"A2", X"A1", X"A0", X"9D", X"97", X"93", X"94", X"93", X"99", X"99", X"99", X"99", X"99", X"9A",
--78
X"98", X"99", X"97", X"97", X"97", X"97", X"96", X"95", X"95", X"94", X"93", X"94", X"91", X"86", X"83", X"7E", X"87", X"8A", X"89", X"88", X"89", X"87", X"86", X"84", X"84", X"83", X"83", X"82", X"82", X"81", X"81", X"81",
X"80", X"81", X"86", X"8C", X"90", X"92", X"92", X"93", X"95", X"95", X"95", X"96", X"96", X"96", X"97", X"97", X"99", X"9B", X"99", X"98", X"96", X"92", X"8C", X"89", X"86", X"83", X"7E", X"7A", X"77", X"77", X"75", X"73",
X"71", X"6D", X"70", X"72", X"75", X"76", X"7B", X"7B", X"7D", X"7B", X"7B", X"80", X"7D", X"81", X"79", X"73", X"77", X"76", X"75", X"75", X"6A", X"70", X"7B", X"7E", X"7F", X"81", X"81", X"82", X"83", X"84", X"85", X"85",
X"84", X"84", X"87", X"8A", X"8C", X"8B", X"8B", X"88", X"8D", X"90", X"95", X"98", X"9A", X"9D", X"A0", X"A1", X"A2", X"A1", X"A1", X"A1", X"A0", X"9C", X"95", X"8F", X"90", X"94", X"99", X"99", X"99", X"99", X"99", X"9A",
--79
X"99", X"99", X"97", X"97", X"97", X"97", X"96", X"94", X"94", X"93", X"92", X"91", X"91", X"8A", X"86", X"82", X"83", X"87", X"88", X"89", X"8A", X"87", X"86", X"84", X"83", X"81", X"81", X"81", X"81", X"80", X"80", X"7E",
X"7D", X"7F", X"86", X"8C", X"8F", X"91", X"91", X"92", X"93", X"95", X"94", X"95", X"96", X"96", X"95", X"95", X"96", X"96", X"96", X"97", X"95", X"92", X"8C", X"88", X"88", X"86", X"81", X"7A", X"77", X"76", X"75", X"74",
X"74", X"71", X"72", X"72", X"72", X"76", X"78", X"75", X"77", X"78", X"78", X"79", X"7B", X"7A", X"7A", X"6C", X"72", X"72", X"6E", X"6E", X"6D", X"72", X"79", X"7F", X"7F", X"80", X"81", X"82", X"82", X"82", X"82", X"83",
X"83", X"82", X"85", X"8A", X"89", X"8A", X"8A", X"8B", X"8E", X"90", X"95", X"98", X"9A", X"9D", X"9F", X"A0", X"A1", X"A1", X"9F", X"9F", X"9E", X"9C", X"91", X"8D", X"8C", X"97", X"98", X"99", X"99", X"99", X"99", X"9A",
--80
X"99", X"99", X"97", X"97", X"97", X"97", X"96", X"93", X"93", X"91", X"90", X"8F", X"8F", X"8B", X"84", X"84", X"83", X"87", X"87", X"86", X"86", X"86", X"86", X"85", X"84", X"81", X"80", X"80", X"81", X"80", X"80", X"7F",
X"7A", X"7E", X"86", X"8B", X"8F", X"90", X"91", X"91", X"92", X"94", X"94", X"95", X"95", X"95", X"95", X"94", X"96", X"94", X"96", X"96", X"95", X"92", X"8C", X"88", X"89", X"87", X"85", X"7B", X"78", X"77", X"77", X"76",
X"76", X"76", X"75", X"74", X"74", X"74", X"71", X"70", X"70", X"76", X"70", X"76", X"73", X"70", X"6F", X"6B", X"6B", X"6B", X"6A", X"6C", X"6F", X"70", X"7D", X"7F", X"7F", X"80", X"80", X"81", X"81", X"82", X"82", X"82",
X"81", X"81", X"7D", X"7A", X"7B", X"87", X"89", X"8A", X"8E", X"90", X"95", X"98", X"9A", X"9C", X"9E", X"9F", X"A0", X"A0", X"9E", X"9E", X"9D", X"97", X"8F", X"8E", X"8D", X"96", X"98", X"99", X"99", X"99", X"99", X"9A",
--81
X"99", X"98", X"97", X"97", X"97", X"97", X"95", X"93", X"91", X"90", X"8F", X"8E", X"8B", X"89", X"85", X"85", X"82", X"85", X"85", X"86", X"86", X"86", X"85", X"84", X"82", X"7E", X"7E", X"7F", X"7F", X"7E", X"7E", X"7E",
X"7D", X"7C", X"80", X"8A", X"8E", X"91", X"90", X"91", X"91", X"93", X"93", X"92", X"93", X"93", X"94", X"94", X"94", X"94", X"94", X"94", X"95", X"92", X"8D", X"89", X"8B", X"88", X"86", X"81", X"7C", X"7D", X"7B", X"7B",
X"7A", X"79", X"78", X"78", X"78", X"76", X"72", X"74", X"76", X"77", X"73", X"74", X"72", X"72", X"71", X"6D", X"69", X"6C", X"6B", X"6E", X"71", X"70", X"7C", X"7F", X"80", X"80", X"80", X"80", X"81", X"81", X"82", X"81",
X"80", X"7B", X"6C", X"7B", X"83", X"88", X"8A", X"8B", X"8D", X"91", X"95", X"98", X"9A", X"9C", X"9D", X"9F", X"A1", X"A1", X"9E", X"9D", X"9C", X"92", X"8C", X"8D", X"8D", X"95", X"99", X"99", X"99", X"99", X"99", X"9A",
--82
X"99", X"98", X"97", X"97", X"97", X"97", X"95", X"93", X"90", X"90", X"8D", X"8C", X"89", X"83", X"86", X"82", X"80", X"7C", X"81", X"83", X"8A", X"89", X"87", X"84", X"81", X"7F", X"7F", X"7F", X"7E", X"7E", X"7E", X"7E",
X"7C", X"78", X"7A", X"83", X"8A", X"8F", X"90", X"91", X"91", X"90", X"92", X"92", X"93", X"93", X"94", X"94", X"94", X"94", X"94", X"94", X"95", X"92", X"8D", X"8D", X"8F", X"89", X"86", X"82", X"80", X"7E", X"7C", X"7B",
X"7A", X"7B", X"7B", X"7B", X"7B", X"79", X"77", X"7B", X"7C", X"7C", X"7A", X"7B", X"7B", X"79", X"77", X"78", X"77", X"75", X"72", X"73", X"75", X"76", X"7D", X"7F", X"81", X"80", X"7F", X"80", X"80", X"7F", X"7C", X"7B",
X"7B", X"7A", X"76", X"85", X"85", X"87", X"8B", X"89", X"8D", X"92", X"95", X"98", X"9A", X"9D", X"9D", X"9F", X"A0", X"9E", X"9D", X"9A", X"95", X"8D", X"8C", X"8C", X"8F", X"96", X"98", X"99", X"9A", X"99", X"99", X"9A",
--83
X"9A", X"9A", X"99", X"98", X"98", X"97", X"95", X"93", X"91", X"90", X"8C", X"8B", X"88", X"83", X"83", X"82", X"7D", X"79", X"7A", X"80", X"83", X"85", X"86", X"83", X"80", X"7E", X"7E", X"7D", X"7B", X"7A", X"7B", X"7B",
X"7A", X"76", X"78", X"7B", X"84", X"8A", X"8D", X"8D", X"8E", X"8F", X"92", X"92", X"92", X"92", X"94", X"94", X"94", X"94", X"94", X"94", X"92", X"8D", X"8B", X"8C", X"93", X"8E", X"8D", X"86", X"82", X"80", X"80", X"7C",
X"7C", X"7C", X"7C", X"7D", X"7D", X"7D", X"7E", X"7D", X"7D", X"7D", X"7E", X"7D", X"7B", X"7D", X"7C", X"7C", X"7C", X"7C", X"7B", X"7B", X"7B", X"7C", X"7E", X"81", X"84", X"82", X"82", X"82", X"80", X"7C", X"7C", X"76",
X"6F", X"75", X"7C", X"86", X"86", X"87", X"8A", X"88", X"8E", X"91", X"95", X"99", X"9B", X"9C", X"9D", X"9E", X"9E", X"9F", X"9F", X"9A", X"91", X"8E", X"8D", X"8B", X"93", X"97", X"99", X"9A", X"9B", X"9B", X"9A", X"9A",
--84
X"9A", X"99", X"9A", X"99", X"96", X"97", X"96", X"93", X"90", X"8F", X"8D", X"8A", X"88", X"83", X"83", X"7F", X"7A", X"75", X"74", X"76", X"7E", X"81", X"7F", X"83", X"80", X"7D", X"7D", X"7B", X"7A", X"79", X"79", X"79",
X"78", X"77", X"76", X"75", X"79", X"7F", X"88", X"8C", X"8F", X"8F", X"91", X"91", X"91", X"93", X"93", X"94", X"93", X"94", X"94", X"93", X"90", X"8C", X"89", X"8E", X"96", X"97", X"95", X"8F", X"86", X"83", X"82", X"7E",
X"7C", X"7E", X"7E", X"7E", X"7E", X"7E", X"80", X"80", X"80", X"7E", X"7E", X"7F", X"7E", X"7D", X"7E", X"7E", X"7E", X"7F", X"7F", X"7E", X"80", X"83", X"85", X"86", X"86", X"84", X"84", X"84", X"7F", X"7C", X"7E", X"84",
X"7C", X"7B", X"7E", X"84", X"86", X"88", X"8A", X"8B", X"8F", X"90", X"95", X"99", X"9D", X"9D", X"9E", X"9F", X"9E", X"9E", X"9E", X"9A", X"92", X"8F", X"8D", X"8C", X"91", X"97", X"97", X"9B", X"9B", X"9B", X"9A", X"9A",
--85
X"9A", X"99", X"98", X"98", X"98", X"97", X"95", X"93", X"90", X"8F", X"8D", X"8A", X"88", X"84", X"80", X"7B", X"76", X"6F", X"70", X"6B", X"71", X"7A", X"7C", X"7D", X"7F", X"7C", X"7A", X"78", X"79", X"78", X"78", X"79",
X"78", X"76", X"72", X"72", X"70", X"78", X"81", X"8C", X"8C", X"8F", X"8F", X"90", X"90", X"91", X"91", X"91", X"91", X"91", X"92", X"92", X"92", X"8D", X"87", X"8E", X"96", X"96", X"99", X"96", X"91", X"8C", X"86", X"81",
X"81", X"81", X"7F", X"80", X"80", X"80", X"7F", X"7F", X"7F", X"7E", X"80", X"80", X"7E", X"80", X"80", X"7F", X"80", X"80", X"80", X"81", X"82", X"84", X"86", X"87", X"87", X"87", X"88", X"87", X"82", X"81", X"82", X"83",
X"85", X"85", X"85", X"87", X"87", X"87", X"89", X"89", X"8D", X"92", X"95", X"99", X"9D", X"9D", X"9E", X"9E", X"9E", X"9E", X"9D", X"99", X"93", X"8E", X"8E", X"8B", X"90", X"95", X"97", X"99", X"99", X"9A", X"9A", X"9A",
--86
X"98", X"99", X"99", X"98", X"98", X"96", X"95", X"92", X"90", X"8F", X"8C", X"89", X"87", X"84", X"7F", X"7C", X"79", X"6E", X"6D", X"6B", X"69", X"6F", X"6E", X"73", X"79", X"7A", X"76", X"76", X"76", X"75", X"75", X"75",
X"74", X"73", X"69", X"6B", X"6B", X"75", X"7F", X"86", X"8B", X"8E", X"8E", X"8F", X"8F", X"90", X"91", X"91", X"91", X"91", X"92", X"91", X"92", X"8A", X"84", X"90", X"96", X"99", X"9C", X"9B", X"98", X"92", X"89", X"86",
X"85", X"85", X"81", X"82", X"82", X"82", X"81", X"81", X"80", X"81", X"80", X"80", X"81", X"80", X"80", X"7F", X"80", X"80", X"82", X"84", X"84", X"85", X"87", X"89", X"8A", X"8A", X"8D", X"8D", X"89", X"8A", X"8B", X"88",
X"8A", X"89", X"89", X"88", X"88", X"88", X"88", X"87", X"8D", X"92", X"95", X"99", X"9D", X"9D", X"9E", X"9E", X"9D", X"9E", X"9D", X"99", X"94", X"8B", X"8C", X"8D", X"91", X"93", X"96", X"98", X"98", X"9B", X"9A", X"9B",
--87
X"99", X"97", X"97", X"97", X"96", X"96", X"95", X"93", X"91", X"8F", X"87", X"89", X"86", X"84", X"7D", X"7A", X"79", X"6F", X"6F", X"6B", X"63", X"6C", X"68", X"68", X"6C", X"70", X"6F", X"70", X"6A", X"6A", X"69", X"69",
X"67", X"66", X"64", X"66", X"65", X"68", X"75", X"82", X"8C", X"8C", X"8D", X"8E", X"8F", X"90", X"91", X"91", X"90", X"91", X"92", X"90", X"91", X"88", X"87", X"88", X"90", X"98", X"9B", X"9B", X"97", X"94", X"8C", X"8A",
X"8A", X"89", X"85", X"85", X"84", X"85", X"85", X"85", X"84", X"82", X"81", X"82", X"80", X"81", X"80", X"7F", X"80", X"80", X"83", X"86", X"85", X"86", X"88", X"8A", X"8B", X"8C", X"8E", X"91", X"8E", X"8A", X"8B", X"89",
X"8A", X"89", X"8A", X"89", X"89", X"85", X"82", X"81", X"8C", X"92", X"95", X"99", X"9C", X"9D", X"9D", X"9D", X"9D", X"9E", X"9D", X"9A", X"93", X"89", X"89", X"8E", X"92", X"91", X"94", X"95", X"96", X"9A", X"9A", X"9B",
--88
X"99", X"99", X"99", X"98", X"97", X"97", X"96", X"94", X"93", X"91", X"88", X"8A", X"87", X"85", X"7D", X"78", X"78", X"70", X"6E", X"6D", X"66", X"66", X"67", X"67", X"66", X"6A", X"6A", X"6C", X"67", X"67", X"68", X"68",
X"66", X"65", X"65", X"69", X"65", X"66", X"6B", X"7A", X"88", X"8B", X"8D", X"8F", X"8F", X"90", X"91", X"91", X"91", X"91", X"91", X"91", X"91", X"88", X"84", X"82", X"8A", X"98", X"9B", X"9A", X"99", X"98", X"92", X"92",
X"90", X"8C", X"8A", X"8A", X"89", X"88", X"86", X"87", X"86", X"84", X"83", X"83", X"83", X"83", X"83", X"84", X"84", X"83", X"85", X"85", X"88", X"88", X"8A", X"8C", X"8E", X"90", X"90", X"92", X"90", X"8F", X"8D", X"89",
X"89", X"89", X"89", X"89", X"88", X"81", X"80", X"81", X"8C", X"91", X"95", X"98", X"9C", X"9D", X"9E", X"9E", X"9E", X"9D", X"9C", X"9A", X"90", X"89", X"8A", X"8D", X"8F", X"91", X"94", X"94", X"97", X"9A", X"9A", X"9B",
--89
X"99", X"99", X"99", X"99", X"97", X"97", X"96", X"96", X"94", X"92", X"90", X"8A", X"8A", X"84", X"7C", X"78", X"76", X"71", X"6E", X"70", X"6D", X"6A", X"66", X"68", X"69", X"6B", X"6B", X"6B", X"68", X"68", X"68", X"66",
X"66", X"64", X"66", X"65", X"63", X"66", X"68", X"70", X"81", X"89", X"8D", X"8F", X"8F", X"90", X"91", X"90", X"90", X"91", X"91", X"91", X"90", X"8A", X"87", X"83", X"86", X"8E", X"9A", X"99", X"9A", X"97", X"94", X"92",
X"8F", X"8F", X"8F", X"8D", X"8C", X"8B", X"8C", X"8C", X"8B", X"89", X"87", X"86", X"86", X"86", X"86", X"84", X"85", X"86", X"88", X"89", X"8E", X"8F", X"8E", X"90", X"91", X"93", X"95", X"96", X"94", X"92", X"8F", X"8B",
X"8B", X"8B", X"8B", X"8B", X"89", X"83", X"81", X"81", X"8C", X"91", X"95", X"98", X"9B", X"9B", X"9C", X"9C", X"9C", X"9B", X"9B", X"97", X"8C", X"85", X"87", X"8C", X"8D", X"91", X"94", X"95", X"97", X"9A", X"9A", X"9B",
--90
X"98", X"99", X"99", X"99", X"98", X"98", X"97", X"97", X"95", X"95", X"90", X"90", X"8D", X"85", X"83", X"80", X"7B", X"70", X"71", X"70", X"6E", X"6B", X"67", X"68", X"6C", X"6D", X"6D", X"6B", X"6D", X"6E", X"6B", X"66",
X"6B", X"68", X"67", X"66", X"65", X"66", X"68", X"6B", X"79", X"87", X"8E", X"8E", X"8F", X"90", X"90", X"8F", X"8F", X"90", X"91", X"91", X"91", X"8E", X"8A", X"82", X"83", X"84", X"8F", X"96", X"98", X"99", X"99", X"94",
X"94", X"94", X"91", X"8F", X"8F", X"8F", X"8F", X"8E", X"8D", X"8D", X"8D", X"8B", X"8B", X"8A", X"88", X"89", X"8A", X"8B", X"8C", X"8B", X"8F", X"8E", X"8D", X"90", X"93", X"95", X"97", X"99", X"98", X"95", X"8E", X"8D",
X"8A", X"8B", X"8B", X"8B", X"8B", X"84", X"82", X"81", X"8C", X"91", X"94", X"97", X"99", X"99", X"9A", X"9A", X"9A", X"99", X"97", X"90", X"87", X"81", X"81", X"86", X"8A", X"92", X"94", X"95", X"97", X"9A", X"9A", X"9B",
--91
X"98", X"98", X"98", X"98", X"98", X"97", X"97", X"96", X"97", X"96", X"94", X"92", X"91", X"8F", X"8E", X"8B", X"88", X"83", X"7C", X"78", X"7D", X"7D", X"70", X"76", X"77", X"75", X"75", X"76", X"77", X"77", X"74", X"75",
X"73", X"71", X"6F", X"70", X"6D", X"6C", X"68", X"69", X"71", X"7B", X"84", X"8D", X"8E", X"90", X"90", X"90", X"90", X"90", X"90", X"90", X"90", X"8F", X"8B", X"7E", X"83", X"82", X"88", X"90", X"98", X"97", X"99", X"95",
X"94", X"92", X"92", X"92", X"91", X"91", X"92", X"90", X"8F", X"8F", X"8F", X"8D", X"8D", X"8C", X"8C", X"8C", X"8B", X"8C", X"8D", X"8C", X"90", X"8F", X"8E", X"91", X"94", X"97", X"97", X"98", X"9A", X"97", X"92", X"8D",
X"8C", X"8B", X"8B", X"8B", X"8B", X"88", X"83", X"87", X"8C", X"92", X"94", X"96", X"96", X"96", X"96", X"9A", X"9A", X"94", X"90", X"84", X"7F", X"7F", X"7D", X"80", X"84", X"92", X"95", X"96", X"98", X"9A", X"9A", X"9B",
--92
X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"97", X"98", X"98", X"95", X"92", X"91", X"92", X"94", X"92", X"8B", X"88", X"83", X"8B", X"8D", X"86", X"84", X"84", X"84", X"81", X"81", X"80",
X"7F", X"7D", X"7A", X"79", X"75", X"72", X"6D", X"6D", X"6E", X"71", X"7E", X"89", X"8E", X"8E", X"8F", X"90", X"90", X"90", X"90", X"90", X"90", X"91", X"8C", X"87", X"82", X"81", X"82", X"8C", X"96", X"98", X"97", X"96",
X"98", X"95", X"94", X"92", X"91", X"91", X"91", X"90", X"90", X"8F", X"90", X"8D", X"8E", X"8E", X"8E", X"8E", X"8E", X"8E", X"8F", X"8D", X"8F", X"8F", X"90", X"91", X"92", X"95", X"95", X"97", X"98", X"96", X"96", X"90",
X"8F", X"8C", X"8C", X"8B", X"8B", X"8A", X"88", X"89", X"8C", X"92", X"93", X"95", X"95", X"95", X"95", X"97", X"94", X"8B", X"81", X"7F", X"7B", X"76", X"7C", X"84", X"86", X"8F", X"95", X"96", X"98", X"9A", X"9A", X"9B",
--93
X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"99", X"99", X"99", X"98", X"98", X"98", X"97", X"97", X"96", X"97", X"91", X"95", X"96", X"8F", X"94", X"93", X"94", X"90", X"91", X"90", X"8D", X"8A", X"87", X"85",
X"83", X"7F", X"7D", X"77", X"76", X"74", X"71", X"6F", X"73", X"76", X"7B", X"83", X"87", X"8A", X"8E", X"8F", X"8F", X"8F", X"8F", X"90", X"90", X"92", X"8E", X"84", X"85", X"80", X"81", X"8B", X"92", X"96", X"96", X"96",
X"95", X"92", X"93", X"92", X"91", X"91", X"91", X"90", X"90", X"8F", X"90", X"8E", X"8F", X"8F", X"8F", X"8F", X"8F", X"8E", X"8E", X"8E", X"8E", X"8E", X"8F", X"91", X"91", X"92", X"92", X"94", X"95", X"94", X"95", X"90",
X"8F", X"8C", X"8B", X"8B", X"8B", X"8A", X"89", X"89", X"8C", X"91", X"91", X"94", X"95", X"97", X"96", X"92", X"8A", X"82", X"7B", X"78", X"77", X"7D", X"80", X"82", X"87", X"90", X"94", X"96", X"98", X"9A", X"9A", X"9B",
--94
X"98", X"98", X"98", X"98", X"98", X"98", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"9A", X"99", X"98", X"98", X"98", X"98", X"97", X"97", X"94", X"95", X"94", X"94", X"94", X"93", X"92", X"91", X"8F", X"8B", X"86",
X"85", X"80", X"7B", X"78", X"76", X"73", X"73", X"71", X"76", X"75", X"7C", X"7D", X"80", X"83", X"89", X"8D", X"8C", X"8E", X"8D", X"8D", X"8F", X"90", X"90", X"89", X"83", X"7E", X"80", X"85", X"8B", X"90", X"93", X"97",
X"93", X"92", X"92", X"92", X"91", X"91", X"92", X"91", X"91", X"8E", X"91", X"8F", X"8F", X"8F", X"8F", X"8F", X"8F", X"8E", X"8E", X"8E", X"8E", X"8F", X"8F", X"90", X"90", X"90", X"91", X"91", X"93", X"95", X"94", X"91",
X"8F", X"8B", X"8C", X"89", X"8A", X"8A", X"89", X"89", X"8E", X"90", X"91", X"93", X"94", X"92", X"8C", X"82", X"7D", X"76", X"72", X"76", X"79", X"79", X"7C", X"7D", X"8C", X"92", X"95", X"96", X"98", X"9C", X"9B", X"9C",
--95
X"98", X"98", X"98", X"98", X"98", X"98", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"9A", X"9A", X"99", X"99", X"99", X"99", X"98", X"98", X"94", X"99", X"98", X"97", X"98", X"97", X"95", X"94", X"90", X"8D", X"88",
X"85", X"80", X"7C", X"77", X"76", X"6D", X"6C", X"6D", X"74", X"76", X"78", X"7B", X"77", X"7C", X"7C", X"80", X"83", X"84", X"89", X"89", X"8A", X"8B", X"8F", X"89", X"85", X"81", X"7E", X"7E", X"84", X"8C", X"90", X"94",
X"92", X"92", X"92", X"91", X"91", X"91", X"91", X"91", X"91", X"90", X"91", X"8E", X"8E", X"8E", X"8E", X"8E", X"8F", X"8E", X"8E", X"8E", X"8E", X"8E", X"8F", X"90", X"90", X"90", X"91", X"91", X"92", X"95", X"94", X"91",
X"8F", X"8C", X"8A", X"89", X"8A", X"8A", X"89", X"89", X"8E", X"8E", X"8C", X"8C", X"85", X"80", X"7B", X"7A", X"7B", X"74", X"6F", X"77", X"7B", X"7B", X"7E", X"8B", X"92", X"93", X"95", X"98", X"9B", X"9C", X"9B", X"9C",
--96
X"98", X"98", X"98", X"98", X"98", X"99", X"99", X"99", X"99", X"99", X"99", X"98", X"99", X"9A", X"9A", X"99", X"99", X"99", X"99", X"99", X"99", X"9A", X"98", X"98", X"98", X"97", X"96", X"97", X"96", X"91", X"93", X"8D",
X"87", X"81", X"7A", X"77", X"73", X"6C", X"68", X"66", X"66", X"6D", X"79", X"7F", X"83", X"80", X"7E", X"7B", X"7B", X"7A", X"75", X"71", X"79", X"7E", X"80", X"83", X"7F", X"80", X"7D", X"7D", X"7F", X"83", X"86", X"8C",
X"8F", X"91", X"91", X"91", X"90", X"91", X"92", X"91", X"91", X"90", X"90", X"8E", X"8D", X"8E", X"8E", X"8E", X"8E", X"8D", X"8D", X"8D", X"8D", X"8E", X"8E", X"8F", X"90", X"90", X"90", X"91", X"93", X"94", X"93", X"91",
X"8F", X"8C", X"88", X"89", X"88", X"87", X"86", X"86", X"86", X"85", X"82", X"7E", X"77", X"75", X"73", X"73", X"76", X"73", X"72", X"77", X"7A", X"7D", X"81", X"8E", X"91", X"95", X"96", X"9A", X"9C", X"9C", X"9C", X"9C",
--97
X"98", X"98", X"98", X"98", X"99", X"99", X"99", X"98", X"99", X"99", X"99", X"99", X"99", X"9A", X"9A", X"98", X"9A", X"9A", X"99", X"99", X"99", X"99", X"99", X"98", X"99", X"96", X"97", X"94", X"97", X"95", X"95", X"90",
X"87", X"81", X"7D", X"76", X"6E", X"6C", X"66", X"62", X"62", X"63", X"6F", X"7E", X"84", X"82", X"80", X"7C", X"7C", X"7B", X"7C", X"75", X"7A", X"7A", X"7C", X"7E", X"7C", X"7D", X"7C", X"7C", X"7C", X"7E", X"82", X"86",
X"8E", X"91", X"90", X"90", X"90", X"8F", X"91", X"90", X"90", X"90", X"90", X"8F", X"8F", X"8E", X"8E", X"8E", X"8E", X"8D", X"8D", X"8D", X"8D", X"8E", X"8E", X"8F", X"90", X"90", X"90", X"91", X"91", X"92", X"92", X"91",
X"91", X"8B", X"86", X"88", X"86", X"86", X"84", X"85", X"86", X"81", X"78", X"77", X"74", X"74", X"72", X"75", X"79", X"78", X"76", X"7B", X"80", X"84", X"87", X"92", X"92", X"96", X"99", X"9A", X"9B", X"9C", X"9C", X"9C",
--98
X"98", X"99", X"98", X"98", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"9A", X"9A", X"98", X"9A", X"99", X"99", X"99", X"99", X"99", X"99", X"98", X"99", X"97", X"97", X"96", X"96", X"96", X"95", X"92",
X"8D", X"86", X"7A", X"77", X"77", X"64", X"63", X"62", X"60", X"60", X"68", X"78", X"80", X"82", X"88", X"7A", X"7C", X"7F", X"7B", X"7A", X"7B", X"78", X"79", X"76", X"76", X"78", X"79", X"77", X"74", X"74", X"7B", X"80",
X"8A", X"8B", X"8D", X"8F", X"8F", X"91", X"90", X"90", X"90", X"91", X"90", X"8E", X"8E", X"8E", X"8E", X"8E", X"8E", X"8E", X"8D", X"8D", X"8D", X"8D", X"8E", X"8F", X"8F", X"8F", X"8F", X"90", X"90", X"8F", X"90", X"8F",
X"8B", X"88", X"85", X"85", X"85", X"85", X"82", X"82", X"7D", X"76", X"75", X"76", X"74", X"72", X"72", X"78", X"7B", X"7C", X"7E", X"84", X"88", X"8D", X"91", X"97", X"98", X"99", X"99", X"9A", X"9B", X"9C", X"9C", X"9C",
--99
X"9A", X"9A", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"9A", X"9B", X"9A", X"98", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"98", X"97", X"99", X"96", X"96", X"96", X"92",
X"92", X"90", X"86", X"7E", X"7A", X"6C", X"66", X"64", X"67", X"62", X"62", X"6A", X"75", X"7D", X"87", X"85", X"80", X"7F", X"7C", X"7B", X"7A", X"7A", X"79", X"78", X"77", X"77", X"77", X"76", X"76", X"75", X"78", X"7B",
X"7F", X"86", X"8C", X"8E", X"8F", X"8E", X"8D", X"8F", X"90", X"90", X"8F", X"8C", X"8D", X"8D", X"8D", X"8D", X"8C", X"8C", X"8C", X"8C", X"8C", X"8D", X"8E", X"8F", X"8F", X"8E", X"8F", X"8F", X"8E", X"8F", X"8D", X"8C",
X"8A", X"84", X"84", X"84", X"85", X"82", X"78", X"74", X"72", X"70", X"71", X"74", X"74", X"76", X"74", X"78", X"7C", X"80", X"84", X"89", X"8E", X"92", X"96", X"9A", X"9B", X"9B", X"9B", X"9C", X"9C", X"9C", X"9C", X"9C",
--100
X"9B", X"9B", X"9A", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"9A", X"9B", X"9A", X"99", X"99", X"99", X"99", X"99", X"98", X"99", X"99", X"99", X"99", X"99", X"97", X"9A", X"97", X"97", X"96", X"96",
X"95", X"94", X"92", X"8C", X"7E", X"72", X"6C", X"6C", X"69", X"65", X"65", X"65", X"69", X"75", X"80", X"84", X"81", X"7F", X"7B", X"7B", X"7B", X"79", X"7A", X"77", X"77", X"77", X"77", X"76", X"77", X"77", X"79", X"79",
X"79", X"7F", X"7F", X"82", X"86", X"88", X"8B", X"8D", X"8E", X"90", X"8F", X"8C", X"8C", X"8B", X"8B", X"8B", X"8B", X"8B", X"8B", X"8B", X"8C", X"8C", X"8C", X"8D", X"8C", X"8B", X"8B", X"8A", X"8A", X"88", X"85", X"81",
X"7E", X"7E", X"82", X"81", X"80", X"7A", X"74", X"70", X"6F", X"70", X"73", X"75", X"77", X"79", X"7A", X"7F", X"81", X"88", X"90", X"93", X"95", X"96", X"98", X"99", X"9A", X"9B", X"9C", X"9C", X"9C", X"9C", X"9C", X"9B",
--101
X"98", X"99", X"99", X"99", X"98", X"99", X"98", X"99", X"9A", X"99", X"99", X"99", X"99", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9D", X"99", X"99", X"99", X"99", X"98", X"98", X"98", X"98", X"97", X"98", X"97", X"96",
X"95", X"95", X"94", X"93", X"8D", X"7E", X"79", X"6D", X"6C", X"69", X"68", X"66", X"67", X"69", X"70", X"7A", X"7E", X"7D", X"7A", X"79", X"7A", X"7B", X"7B", X"78", X"77", X"77", X"77", X"77", X"77", X"77", X"79", X"7A",
X"7B", X"7D", X"7D", X"7D", X"7E", X"7F", X"83", X"84", X"84", X"88", X"8A", X"89", X"8B", X"8B", X"8A", X"8A", X"8A", X"8A", X"8A", X"8A", X"8A", X"8A", X"8C", X"8A", X"85", X"80", X"78", X"73", X"79", X"79", X"78", X"76",
X"78", X"78", X"79", X"78", X"74", X"71", X"71", X"70", X"71", X"71", X"75", X"77", X"7A", X"7C", X"83", X"89", X"8B", X"8E", X"93", X"95", X"96", X"98", X"9A", X"9A", X"9A", X"9B", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D",
--102
X"98", X"98", X"97", X"97", X"97", X"97", X"98", X"9A", X"99", X"99", X"99", X"98", X"99", X"9A", X"99", X"9A", X"9A", X"9A", X"99", X"9A", X"99", X"99", X"99", X"99", X"98", X"98", X"98", X"97", X"99", X"99", X"98", X"97",
X"97", X"96", X"95", X"94", X"92", X"93", X"89", X"7D", X"72", X"6C", X"6A", X"67", X"68", X"68", X"6A", X"6D", X"71", X"76", X"79", X"7B", X"79", X"7B", X"7B", X"7B", X"78", X"77", X"77", X"77", X"78", X"77", X"79", X"7A",
X"7A", X"7C", X"7B", X"7B", X"7C", X"7B", X"7B", X"7A", X"7A", X"78", X"7A", X"7F", X"87", X"87", X"89", X"88", X"89", X"89", X"8A", X"88", X"89", X"88", X"84", X"7B", X"76", X"73", X"6C", X"67", X"63", X"6D", X"6E", X"70",
X"67", X"69", X"6C", X"71", X"6E", X"70", X"70", X"71", X"76", X"77", X"7D", X"80", X"81", X"83", X"88", X"8D", X"8E", X"92", X"96", X"97", X"98", X"99", X"9B", X"9B", X"9B", X"9B", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C",
--103
X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"97", X"97", X"97", X"98", X"97", X"98", X"99", X"99", X"9A", X"9A", X"9A", X"99", X"9B", X"99", X"99", X"99", X"99", X"99", X"98", X"97", X"98", X"98", X"98", X"98", X"96",
X"98", X"97", X"97", X"95", X"95", X"94", X"91", X"8D", X"86", X"7A", X"75", X"6C", X"6A", X"6B", X"6B", X"6D", X"6B", X"6E", X"71", X"6D", X"6A", X"77", X"78", X"78", X"77", X"77", X"77", X"77", X"77", X"76", X"77", X"78",
X"7A", X"7B", X"7A", X"7B", X"7A", X"79", X"78", X"77", X"72", X"6A", X"6B", X"6E", X"72", X"79", X"80", X"84", X"85", X"85", X"86", X"85", X"82", X"7E", X"78", X"76", X"71", X"71", X"6D", X"73", X"70", X"70", X"70", X"74",
X"73", X"72", X"70", X"78", X"77", X"79", X"7B", X"81", X"83", X"85", X"86", X"87", X"88", X"8A", X"8E", X"90", X"90", X"95", X"98", X"98", X"9B", X"9B", X"9B", X"9B", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D",
--104
X"98", X"97", X"98", X"97", X"96", X"98", X"98", X"98", X"98", X"98", X"98", X"9A", X"97", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"99", X"99", X"99", X"99", X"97", X"98", X"98", X"98", X"98", X"98", X"97",
X"97", X"96", X"96", X"96", X"95", X"96", X"94", X"91", X"8F", X"8A", X"81", X"75", X"6F", X"6E", X"6D", X"6E", X"6C", X"6D", X"72", X"6F", X"70", X"71", X"69", X"69", X"68", X"75", X"73", X"75", X"72", X"72", X"73", X"71",
X"72", X"73", X"72", X"75", X"79", X"79", X"71", X"6F", X"69", X"65", X"67", X"67", X"67", X"6A", X"71", X"74", X"75", X"76", X"78", X"79", X"74", X"75", X"75", X"73", X"72", X"73", X"72", X"75", X"77", X"76", X"76", X"76",
X"7A", X"7B", X"7E", X"7F", X"81", X"85", X"87", X"86", X"87", X"88", X"88", X"89", X"8A", X"8A", X"8F", X"91", X"94", X"96", X"97", X"9A", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D",
--105
X"98", X"95", X"99", X"97", X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"97", X"98", X"9B", X"94", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"99", X"9A", X"9A", X"9A", X"98", X"98", X"98", X"98", X"98", X"98", X"98",
X"97", X"97", X"97", X"96", X"97", X"96", X"95", X"93", X"93", X"92", X"90", X"8C", X"8A", X"86", X"7F", X"7E", X"7F", X"7C", X"78", X"77", X"7A", X"7A", X"77", X"75", X"69", X"6C", X"6A", X"6D", X"69", X"6F", X"6E", X"6E",
X"6B", X"6C", X"6E", X"6F", X"70", X"6D", X"6B", X"6B", X"69", X"66", X"65", X"66", X"67", X"6B", X"70", X"70", X"71", X"73", X"73", X"72", X"73", X"74", X"75", X"76", X"75", X"77", X"78", X"7C", X"7F", X"7E", X"7F", X"8B",
X"8B", X"8C", X"8C", X"8B", X"8A", X"8B", X"8B", X"8A", X"8B", X"8B", X"8B", X"8C", X"8E", X"90", X"93", X"94", X"96", X"97", X"98", X"9A", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D",
--106
X"98", X"97", X"9A", X"99", X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"9A", X"97", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9B", X"9B", X"98", X"98", X"98", X"98", X"98", X"98", X"97",
X"96", X"97", X"97", X"97", X"97", X"97", X"97", X"97", X"95", X"96", X"95", X"95", X"94", X"92", X"8C", X"92", X"8C", X"8A", X"8E", X"8A", X"89", X"89", X"88", X"84", X"85", X"81", X"7A", X"71", X"6E", X"6C", X"69", X"68",
X"66", X"69", X"6B", X"6C", X"69", X"6A", X"6B", X"6B", X"6A", X"6A", X"6C", X"6C", X"6D", X"6E", X"6F", X"70", X"72", X"70", X"71", X"76", X"78", X"77", X"7A", X"7D", X"82", X"85", X"8A", X"8D", X"8E", X"92", X"93", X"94",
X"94", X"94", X"95", X"95", X"93", X"93", X"90", X"90", X"91", X"91", X"91", X"91", X"92", X"93", X"93", X"96", X"99", X"99", X"9B", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D",
--107
X"98", X"99", X"98", X"98", X"99", X"98", X"99", X"98", X"98", X"98", X"98", X"98", X"98", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"98", X"9A", X"9B", X"9C", X"98", X"98", X"98", X"97", X"98", X"98", X"98",
X"97", X"98", X"98", X"98", X"98", X"97", X"97", X"96", X"97", X"95", X"95", X"96", X"95", X"96", X"95", X"96", X"94", X"94", X"97", X"93", X"94", X"95", X"94", X"94", X"94", X"94", X"91", X"8C", X"89", X"7D", X"78", X"72",
X"71", X"6F", X"6F", X"71", X"69", X"6B", X"6D", X"6D", X"6E", X"6E", X"70", X"73", X"70", X"71", X"71", X"76", X"78", X"79", X"7C", X"87", X"86", X"88", X"8B", X"8E", X"8F", X"94", X"95", X"97", X"99", X"9B", X"9B", X"9B",
X"9C", X"9A", X"9C", X"99", X"99", X"98", X"97", X"96", X"97", X"98", X"97", X"98", X"98", X"98", X"98", X"9A", X"9B", X"9B", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E",
--108
X"98", X"98", X"98", X"97", X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"99", X"99", X"99", X"99", X"99", X"98", X"9A", X"94", X"99", X"98", X"98", X"99", X"98", X"99", X"98", X"98", X"98", X"98", X"98",
X"98", X"98", X"98", X"98", X"98", X"96", X"98", X"98", X"97", X"96", X"96", X"96", X"97", X"97", X"97", X"96", X"97", X"97", X"97", X"96", X"96", X"96", X"96", X"96", X"96", X"94", X"94", X"95", X"94", X"93", X"93", X"91",
X"8E", X"88", X"82", X"84", X"80", X"7D", X"7E", X"80", X"7E", X"7C", X"7E", X"7F", X"85", X"89", X"8D", X"8D", X"8F", X"91", X"91", X"94", X"93", X"94", X"95", X"97", X"98", X"9A", X"9C", X"9B", X"9C", X"9D", X"9D", X"9D",
X"9D", X"9C", X"9D", X"9C", X"9C", X"9C", X"9B", X"9B", X"9B", X"9C", X"9B", X"9B", X"9C", X"9C", X"9C", X"9D", X"9E", X"9D", X"9E", X"9E", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E",
--109
X"98", X"98", X"97", X"97", X"97", X"97", X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"97", X"9A", X"99", X"99", X"99", X"97", X"97", X"96", X"98", X"98", X"98", X"98",
X"98", X"99", X"98", X"98", X"98", X"97", X"98", X"98", X"98", X"98", X"98", X"98", X"98", X"96", X"99", X"99", X"96", X"98", X"99", X"98", X"98", X"99", X"99", X"99", X"98", X"97", X"97", X"97", X"98", X"96", X"95", X"98",
X"97", X"96", X"97", X"93", X"92", X"92", X"94", X"94", X"93", X"93", X"96", X"95", X"96", X"97", X"97", X"99", X"98", X"99", X"9A", X"9B", X"9B", X"9B", X"9B", X"9B", X"9B", X"9E", X"9D", X"9C", X"9D", X"9D", X"9D", X"9D",
X"9D", X"9D", X"9B", X"9C", X"9C", X"9C", X"9B", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9F", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E",
--110
X"98", X"98", X"98", X"97", X"97", X"98", X"98", X"98", X"97", X"98", X"98", X"97", X"98", X"99", X"9A", X"98", X"99", X"9A", X"99", X"9B", X"9C", X"9B", X"9B", X"9B", X"9B", X"9A", X"99", X"98", X"99", X"99", X"99", X"99",
X"99", X"99", X"98", X"98", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"98", X"97", X"99", X"99", X"98", X"98", X"97", X"98", X"98", X"98", X"98", X"98", X"98", X"97", X"98", X"98", X"98", X"99", X"99", X"98",
X"99", X"99", X"99", X"98", X"98", X"96", X"98", X"98", X"97", X"97", X"98", X"99", X"99", X"99", X"99", X"9A", X"99", X"9A", X"9B", X"9B", X"9C", X"9B", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D",
X"9E", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E",
--111
X"99", X"99", X"98", X"98", X"99", X"98", X"99", X"99", X"99", X"98", X"99", X"99", X"98", X"99", X"9A", X"98", X"99", X"99", X"97", X"9C", X"9B", X"9B", X"9B", X"9B", X"9B", X"9B", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A",
X"99", X"99", X"99", X"99", X"9A", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"9A", X"99", X"99", X"99", X"99", X"99", X"98", X"97", X"97", X"97", X"97", X"97", X"98", X"99", X"99", X"99", X"99",
X"99", X"99", X"99", X"99", X"99", X"98", X"99", X"99", X"99", X"98", X"98", X"99", X"99", X"9B", X"9B", X"9B", X"9C", X"9C", X"9C", X"9B", X"9D", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D",
X"9E", X"9D", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9C", X"9D", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D",
--112
X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"97", X"9A", X"98", X"99", X"99", X"99", X"99", X"9A", X"99", X"9A", X"A0", X"9B", X"9B", X"9D", X"9B", X"9B", X"9B", X"9B", X"9B", X"9B", X"9B", X"9B", X"9B", X"9B", X"9A",
X"9A", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"99", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"99", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A",
X"9A", X"9A", X"9B", X"9B", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9B", X"9B", X"9B", X"9D", X"9D", X"9C", X"9C", X"9E", X"9D", X"9E", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D",
X"9E", X"9E", X"9B", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D",
--113
X"99", X"9A", X"99", X"99", X"9A", X"9A", X"9C", X"9A", X"9A", X"98", X"99", X"99", X"99", X"99", X"99", X"9A", X"9A", X"A0", X"9A", X"9B", X"9D", X"9B", X"9B", X"9B", X"9B", X"9B", X"9B", X"9B", X"9B", X"9B", X"9B", X"9A",
X"9A", X"99", X"9A", X"9A", X"9A", X"99", X"99", X"99", X"99", X"99", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A",
X"9A", X"9B", X"9C", X"9B", X"9B", X"9B", X"9B", X"9B", X"9B", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9C", X"9D", X"9D", X"9C", X"9E", X"9E", X"9F", X"9F", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D",
X"9C", X"9D", X"9A", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D",
--114
X"99", X"99", X"99", X"99", X"99", X"9A", X"9A", X"9A", X"9A", X"9B", X"9B", X"99", X"9A", X"99", X"99", X"99", X"9A", X"9D", X"9C", X"9B", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9B", X"9A", X"9B", X"9B", X"9A", X"9B",
X"9B", X"9A", X"9B", X"9A", X"9A", X"9A", X"9A", X"9A", X"98", X"99", X"99", X"99", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"99", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A", X"9A",
X"98", X"9C", X"9C", X"9C", X"9C", X"9B", X"9B", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9F", X"9D", X"9B", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9F", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D",
X"9D", X"9D", X"9C", X"9C", X"9C", X"9C", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9E", X"9E", X"9D", X"9E", X"9E", X"9E", X"9E", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9C", X"9D", X"9D", X"9D",
--115
X"9A", X"9A", X"9A", X"9B", X"9B", X"9A", X"9A", X"9A", X"9B", X"9A", X"9A", X"9A", X"9A", X"9A", X"99", X"99", X"9A", X"9D", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D", X"9C", X"9C", X"9B", X"9B",
X"9B", X"9B", X"9B", X"9B", X"9B", X"9B", X"9C", X"9B", X"9B", X"9B", X"9B", X"9B", X"9B", X"9B", X"9B", X"9B", X"9B", X"9B", X"9B", X"9B", X"9A", X"9A", X"9A", X"9A", X"9B", X"9C", X"9C", X"9C", X"9D", X"9C", X"9C", X"9C",
X"9C", X"9C", X"9B", X"9C", X"9C", X"9B", X"9B", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9F", X"9E", X"9E", X"9E", X"9E", X"9E", X"9D", X"9D", X"9D",
X"9D", X"9D", X"9C", X"9C", X"9C", X"9C", X"9D", X"9E", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9D", X"9D", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D",
--116
X"9A", X"9B", X"9B", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9B", X"9A", X"9B", X"9A", X"9A", X"9A", X"9B", X"9D", X"9D", X"9C", X"9C", X"9F", X"9E", X"9D", X"9D", X"9D", X"9C", X"9B", X"9C", X"9C", X"9C", X"9B",
X"9B", X"9C", X"9B", X"9B", X"9B", X"9B", X"9B", X"9C", X"9B", X"9A", X"9B", X"9B", X"9B", X"9B", X"9B", X"9C", X"9C", X"9B", X"9B", X"9B", X"9A", X"9A", X"9A", X"9A", X"9B", X"9C", X"9C", X"9C", X"9D", X"9D", X"9C", X"9C",
X"9D", X"9B", X"9C", X"9D", X"9D", X"9B", X"9B", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E", X"9E", X"9F", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D",
X"9D", X"9D", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E", X"9E", X"9E", X"9F", X"9E", X"9E", X"9E", X"9E", X"9D", X"9E", X"9E", X"9D", X"9D", X"9E", X"9D", X"9D", X"9D",
--117
X"9C", X"99", X"9E", X"9C", X"9B", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E", X"9D", X"9E", X"9F", X"9D", X"9D", X"9D", X"9C", X"9C", X"9C",
X"9C", X"9C", X"9B", X"9B", X"9B", X"9B", X"9B", X"9C", X"9C", X"9B", X"9D", X"9D", X"9D", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9E", X"96", X"9C", X"9C", X"9C", X"9D", X"9D", X"9C", X"9C",
X"9C", X"9C", X"9C", X"9C", X"9C", X"9B", X"9A", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E", X"9E", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D",
X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9D", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E", X"9D", X"9D",
--118
X"9C", X"99", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E", X"9E", X"9D", X"9F", X"9E", X"9F", X"A0", X"9D", X"9D", X"9D", X"9D", X"9C", X"9C",
X"9C", X"9C", X"9B", X"9B", X"9B", X"9B", X"9B", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9C", X"9C", X"9D", X"9C", X"9A", X"9C", X"9C", X"9C", X"9D", X"9D", X"9C", X"9C",
X"9D", X"9D", X"9C", X"9C", X"9C", X"9B", X"9B", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E", X"9E", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D",
X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E", X"9E", X"9D", X"9D", X"9D", X"9E", X"9D", X"9D", X"9C", X"9D", X"9D", X"9D", X"9F", X"9B", X"9C", X"9C", X"9C",
--119
X"9C", X"9D", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9C", X"9D", X"9D", X"9D", X"9D", X"9C", X"9E", X"9A", X"9E", X"9E", X"9F", X"9E", X"A0", X"9F", X"A0", X"A0", X"9D", X"9D", X"9E", X"9E", X"9D", X"9D",
X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E", X"9D", X"9D", X"9D", X"9E", X"9D", X"9B", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D",
X"9E", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D", X"9E", X"9E", X"9D", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D",
X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9E", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9C", X"9A", X"9B", X"9C", X"9C",
--120
X"9C", X"9C", X"9B", X"9B", X"9F", X"9D", X"9D", X"9D", X"9D", X"9E", X"9C", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"A1", X"A0", X"9F", X"9F", X"9F", X"A0", X"9F", X"9E", X"9D", X"9E", X"9E", X"9E", X"9C",
X"9D", X"9A", X"9B", X"9C", X"9C", X"9B", X"9B", X"9B", X"9B", X"9D", X"9D", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D",
X"9D", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9B", X"9C", X"9E", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D",
X"9D", X"9C", X"9B", X"9B", X"9B", X"9C", X"9D", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E", X"9E", X"9C", X"9C", X"9E", X"9E", X"9D", X"9C", X"9D", X"9E", X"9E", X"9E", X"9E", X"9D", X"9D", X"97", X"9C", X"9C",
--121
X"9D", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9C", X"9C", X"9D", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9D", X"9F", X"9F", X"9F", X"9F", X"9F", X"9F", X"9F", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E",
X"9D", X"9D", X"9C", X"9B", X"9A", X"9B", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9E", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D",
X"9D", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9E", X"99", X"9C", X"9B", X"9C", X"9B", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D",
X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9C", X"9C", X"9D", X"9D", X"9D", X"9C", X"9B", X"9C", X"9C", X"9C", X"9C", X"9B", X"9C", X"9D", X"9C", X"9B",
--122
X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9B", X"9D", X"9D", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9F", X"9F", X"9F", X"9F", X"9F", X"9F", X"9F", X"9F", X"9F", X"9E", X"9E", X"9D", X"9E",
X"9D", X"9D", X"9D", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9C", X"9E", X"9E", X"9D", X"9E", X"9E", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D",
X"9D", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9B", X"9D", X"9B", X"9C", X"9B", X"9A", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D",
X"9D", X"9D", X"9D", X"9D", X"9C", X"9C", X"9C", X"9D", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9C", X"9B", X"9C", X"9C", X"9C", X"9C", X"9D", X"9C", X"9C", X"9C", X"9B",
--123
X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9C", X"9B", X"9C", X"9D", X"9E", X"9E", X"9E", X"9E", X"9E", X"9F", X"9F", X"9F", X"9F", X"9F", X"9F", X"9F", X"9F", X"9F", X"9F", X"9E", X"9E", X"9D", X"9F",
X"9B", X"9F", X"9E", X"9E", X"9E", X"9E", X"9E", X"9D", X"9E", X"9D", X"9E", X"9D", X"9E", X"9E", X"9F", X"9F", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D",
X"9D", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9A", X"9C", X"9C", X"9C", X"9B", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D",
X"9D", X"9D", X"9D", X"9E", X"9D", X"9C", X"9C", X"9C", X"9E", X"9F", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E", X"9E", X"9C", X"9C", X"9C", X"9B", X"9B", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9B", X"9D", X"9C", X"9B",
--124
X"9C", X"9C", X"9D", X"9D", X"9D", X"9D", X"9C", X"9D", X"9D", X"9C", X"9C", X"9C", X"9C", X"9E", X"9F", X"9F", X"9F", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E",
X"9E", X"9E", X"9F", X"9E", X"9E", X"9F", X"9F", X"9D", X"9E", X"9E", X"9D", X"9F", X"A0", X"9D", X"9E", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9C", X"9C", X"9E", X"9D", X"9D", X"9D",
X"9E", X"9E", X"9D", X"9D", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9B", X"9E", X"9E", X"9B", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D",
X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9B", X"9B", X"9B",
--125
X"9D", X"9C", X"9C", X"9C", X"9C", X"9D", X"9B", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9F", X"9D", X"9D", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E",
X"9E", X"9E", X"9E", X"9E", X"9E", X"9F", X"9F", X"9F", X"9E", X"9E", X"9E", X"9E", X"9B", X"9E", X"9E", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E", X"9D", X"9D", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D",
X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9E",
X"9D", X"9D", X"9E", X"9D", X"9D", X"9D", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9B", X"9B", X"9B",
--126
X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9B", X"9C", X"9C", X"9C", X"97", X"9C", X"9F", X"9C", X"9F", X"9F", X"96", X"9E", X"9D", X"9D", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E",
X"9E", X"9E", X"9E", X"9E", X"9E", X"9F", X"9D", X"9E", X"9D", X"9F", X"9D", X"A1", X"9F", X"9E", X"9E", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E", X"9D", X"9C", X"9C", X"9C", X"9D", X"9F", X"9F", X"9C",
X"9D", X"9D", X"9C", X"9D", X"9D", X"9C", X"9C", X"9C", X"9C", X"9D", X"9C", X"9B", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9E", X"9D", X"9B", X"9C", X"9D", X"9E", X"9D", X"9D", X"9E",
X"9E", X"9C", X"9D", X"9F", X"9D", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9B", X"9B", X"9B",
--127
X"9C", X"9C", X"9C", X"9C", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9C", X"9F", X"9D", X"9C", X"9E", X"9E", X"9D", X"9E", X"9E", X"9E", X"9F", X"9E", X"9E", X"9E", X"9E",
X"9E", X"9F", X"9E", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9D", X"9C", X"9D", X"9C", X"9C", X"9D", X"9D", X"9D", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D",
X"9D", X"9D", X"9D", X"9D", X"9D", X"9C", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9F", X"9E", X"9D", X"9D", X"9D", X"9C", X"9C", X"9C", X"9C", X"9D", X"9C", X"9D", X"9D",
X"9E", X"9B", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9C", X"9B", X"9B", X"9C", X"9C", X"9C", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9B", X"9C", X"9B",
--128
X"9C", X"9C", X"9A", X"9F", X"9A", X"9C", X"9B", X"9B", X"9C", X"9C", X"9C", X"9C", X"9B", X"9C", X"9C", X"9C", X"9C", X"9D", X"9F", X"9F", X"9C", X"9C", X"9D", X"9C", X"9D", X"9D", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E",
X"9E", X"9E", X"9E", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9E", X"9D", X"9D", X"9D", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D",
X"9D", X"9D", X"9D", X"9D", X"9D", X"9C", X"9B", X"9D", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9C", X"9C", X"9B", X"9B", X"9C", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D",
X"9D", X"9D", X"9D", X"9D", X"9C", X"9C", X"9C", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9D", X"9E", X"9C", X"9C", X"9C", X"9C", X"9C", X"9C", X"9B", X"9B", X"9B", X"9C", X"9C", X"9B", X"9B", X"9A"
type ram_type is array (16383 downto 0) of std_logic_vector(7 downto 0);
signal RAM : ram_type;
signal c_rw,clk9 : std_logic:='0';
signal A,P,S,addr : std_logic_vector(13 downto 0); -- 2^8 = 256
signal pixelin,stored_pixel : std_logic_vector(7 downto 0);
signal count,hcnt,vcnt,frame,lcnt,pcnt : integer:=0;
begin
-------------frame count---------------------------------------
framecount: process(rst,vsync)
begin
if (rst='1') then
frame<=0;
elsif (vsync'event and vsync='1') then
if (frame = 7) then
frame <= 0;
else
frame <= frame + 1;
end if;
end if;
end process framecount;
linecount: process(rst,href)
begin
if (rst='1') then
lcnt<=0;
elsif (href'event and href='1') then
if (lcnt = 144) then
lcnt <= 0;
else
lcnt <= lcnt + 1;
end if;
end if;
end process linecount;
store:process (rst,pclk,c_rw,c_yi,vsync,href) -- process for storing pixels in RAM
begin
if (rst = '1') then
A <= (others => '0');
c_rw <= '0';
pcnt<=0;
elsif (pclk'event and pclk = '1') then
if (frame=1 and href='1') then
if (pcnt= 176) then
pcnt<= 0;
else
pcnt <= pcnt + 1;
end if;
end if;
if (lcnt>8 and lcnt <= 136 and pcnt >24 and pcnt<=152) then
if (c_rw = '0') then
if (A = "11111111111111") then
c_rw <= '1';
else
RAM(conv_integer(A)) <= c_yi;
A <= A + "00000000000001";
end if;
end if;
end if;
end if;
end process store;
comp:process (rst,pclk,c_yi,c_rw) -- process for comparing pixels
begin
if (rst = '1') then
P <= (others => '0');
S <= (others => '0');
match <= (others => '0');
lcd_en <= '1';
if (c_rw='1') then
if (S = "11111111111111") then
match <= P;
lcd_en <= '0';
step_en <= '0';
else
stored_pixel <= ROM (conv_integer(S));
pixelin <= RAM (conv_integer(S));
S <= S + "00000000000001";
if (pixelin(7 downto 3) = stored_pixel(7 downto 3)) then -----precision of 8 as only 5-bits compared lower 3-bits are left
P <= P + "00000000000001"; -- matched pixels
end if;
end if;
end if;
end if;
end process comp;
clk_9MHz:process(clk,rst) ------ 9 MHz clk from 100 Mhz clock i.e. 110ns from 10 ns
begin
if (rst='1') then
count <= 0;
clk9 <= '0';
elsif(clk'event and clk='1') then
if (count = 4) then
count <= 0;
clk9 <= not clk9;
else
count <= count + 1;
end if;
end if;
end process clk_9MHz;
lcd:process (rst,clk9,hcnt,vcnt) -- process for storing pixels in RAM
begin
if (rst='1') then
vcnt<=0;
addr<= (others=>'0');
elsif (clk9'event and clk9='1') then
if (hcnt = 525) then
hcnt <= 0;
if (vcnt= 288) then
vcnt<= 0;
else
vcnt <= vcnt + 1;
end if;
else
hcnt <= hcnt + 1;
end if;
if (hcnt>180 and hcnt<=308 and vcnt>80 and vcnt<=208) then ---- 128*128 window
s_yo <= rom(conv_integer(addr));
c_yo <= ram(conv_integer(addr));
addr <= addr + "00000000000001";
if (addr ="11111111111111") then
addr <= (others=>'0');
end if;
end if;
end if;
end process lcd;
end compare2;
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity tft is
Port ( RST,CLK : in std_logic;
TP_PENIRQ : in STD_LOGIC;
TFT_CLK : out STD_LOGIC;
TFT_DISP : out STD_LOGIC;
TFT_DE : out STD_LOGIC;
TFT_EN : out STD_LOGIC;
LED_EN : out STD_LOGIC; ------- 100 Hz to 50 KHz
TFT_CY,TFT_SY : in STD_LOGIC_VECTOR (7 downto 0);
TFT_R : out STD_LOGIC_VECTOR (7 downto 0);
TFT_G : out STD_LOGIC_VECTOR (7 downto 0);
TFT_B : out STD_LOGIC_VECTOR (7 downto 0));
end tft;
architecture tft2 of tft is
type state_type is (idle,pwr_up_t1,pwr_up_t2,pwr_up_t3,pwr_dw_t1,pwr_dw_t2,pwr_dw_t3,pwr_dw_t4,transmit,stop);
signal state: state_type;
signal clk9,clk_50,clk_de: std_logic;
signal hcnt,vcnt,led_cnt,count: integer;
begin
begin
if (rst='1') then
count <= 0;
clk9 <= '0';
if (count = 4) then
count <= 0;
clk9 <= not clk9;
else
count <= count + 1;
end if;
end if;
clk_50KHz:process(clk,rst) ------ 50 KHz clk from 100 Mhz clock i.e. 20 us from 10 ns
begin
if (rst='1') then
led_cnt <= 0;
clk_50 <= '0';
if (led_cnt = 999) then
led_cnt <= 0;
clk_50 <= not clk_50;
else
led_cnt <= led_cnt + 1;
end if;
end if;
end process clk_50KHz;
clk_tv:process(clk9,rst,hcnt,vcnt) ------ DE SIGNAL
begin
if (rst='1') then
hcnt <= 0;
vcnt <= 0;
clk_de <= '0';
hcnt <= 0;
if (vcnt= 288) then
vcnt<= 0;
else
vcnt <= vcnt + 1;
end if;
else
hcnt <= hcnt + 1;
end if;
if (vcnt >16 and vcnt<=288) then
if (hcnt>45 and hcnt <= 525) then
clk_de <= '1';
else
clk_de <= '0';
end if;
end if;
if (TP_PENIRQ ='1') then
tft_r <= tft_cy;
tft_g <= tft_cy;
tft_b <= tft_cy;
else
tft_r <= "00000000";
tft_g <= "00000000";
tft_b <= "00000000";
end if;
else
tft_r <= tft_sy;
tft_g <= tft_sy;
tft_b <= tft_sy;
else
end if;
end if;
end if;
end process clk_tv;
pwrup:process(rst,clk9,state)
begin
if (rst='1') then
tft_en <= '0';
tft_disp <= '1';
state <= idle;
elsif (clk9'event and clk9 = '1') then
if (state = idle) then
tft_en <= '0';
tft_disp <= '0';
state <= pwr_up_t1;
elsif (state = pwr_up_t1) then
tft_en <= '1';
tft_disp <= '0';
state <= pwr_up_t2 after 100 ms; ----- t1= 0.05ms to 100ms
elsif (state = pwr_up_t2) then
tft_en <= '1';
tft_disp <= '0';
state <= pwr_up_t3 after 200 ms; ----- t2= 0ms to 200ms
elsif (state = pwr_up_t3) then
tft_en <= '1';
tft_disp <= '1';
state <= transmit after 160 ms; ----- t3= 160ms
elsif (state = transmit) then
tft_en <= '1';
tft_disp <= '1';
end if;
end if;
end process pwrup;
de:process (rst,clk_de,clk9,state)
begin
if (rst='1') then
tft_de <= '0';
tft_clk <= '0';
tft_de <= clk_de;
tft_clk <= clk9;
tft_de <= clk_de;
tft_clk <= clk9;
tft_de <= clk_de;
tft_clk <= clk9;
elsif (state = pwr_dw_t3) then
tft_de <= clk_de;
tft_clk <= clk9;
elsif (state = pwr_dw_t2) then
tft_de <= clk_de;
tft_clk <= clk9;
else
tft_de <= '0';
tft_clk <= '0';
end if;
end process de;
en:process (rst,state,clk_50)
begin
if (rst='1') then
led_en <= '0';
led_en <= not clk_50;
else
led_en <= '0';
end if;
end process en;
end tft2;
library IEEE;
use IEEE.STD_LOGIC_ARITH.ALL;
entity lcd is
port(lcden,clk : in std_logic;
din : in std_logic_vector (13 downto 0);
rs: out std_logic;
rw : out std_logic;
d: out std_logic_vector (7 downto 0);
e: out std_logic);
end lcd;
architecture lcd2 of lcd is
signal clock,k : std_logic:='0';
signal p,q,r,s : std_logic_vector (3 downto 0);
procedure ASCII (in1: in std_logic_vector(3 downto 0); out1: out std_logic_vector(7 downto 0)) is
begin
if (in1 = "0000") then out1 := "00110000";
elsif (in1 = "0001") then out1 := "00110001";
elsif (in1 = "0010") then out1 := "00110010";
elsif (in1 = "0011") then out1 := "00110011";
elsif (in1 = "0100") then out1 := "00110100";
elsif (in1 = "0101") then out1 := "00110101";
elsif (in1 = "0110") then out1 := "00110110";
elsif (in1 = "0111") then out1 := "00110111";
elsif (in1 = "1000") then out1 := "00111000";
elsif (in1 = "1001") then out1 := "00111001";
elsif (in1 = "1010") then out1 := "01000001";
elsif (in1 = "1011") then out1 := "01000010";
elsif (in1 = "1100") then out1 := "01000011";
elsif (in1 = "1101") then out1 := "01000100";
elsif (in1 = "1110") then out1 := "01000101";
elsif (in1 = "1111") then out1 := "01000110";
end if;
end procedure;
begin
p <="00" & din (13 downto 12);
q <= din (11 downto 8);
r <= din (7 downto 4);
s <= din (3 downto 0);
process(lcden,clk)
variable x : integer range 0 to 40000000;
begin
if (lcden='1') then
e<='0';
elsif (clk'event and clk='1') then
x:=x+1;
rw<='0';
if x=40000000 then
clock<= not clock;
x:=0;
end if;
e<=clock;
end if;
end process;
process(lcden,clock)
variable n : integer range 0 to 10;
variable z : std_logic_vector (7 downto 0):="00000000";
begin
if (lcden='1') then
n:=0;
d<="00000000";
elsif (clock'event and clock ='1') then
n:=n+1;
if n=1 then
rs<='0';
d<="00011000";
elsif n=2 then
rs<='0';
d<="00000110";
elsif n=3 then
rs<='0';
d<="00001110";
elsif n=4 then
rs<='0';
d<="11000000";
elsif n=5 then
rs<='0';
d<="00000001";
elsif n=6 then
rs<='1';
ASCII(p,z);
d <= z;
elsif n=7 then
rs<='1';
ASCII(q,z);
d <= z;
elsif n=8 then
rs<='1';
ASCII(r,z);
d <= z;
elsif n=9 then
rs<='1';
ASCII(s,z);
d <= z;
elsif n>9 then
rs<='0';
d<="00011100";
end if;
end if;
end process;
end lcd2;
library IEEE;
entity stepper is
port (sen: in std_logic;
clk: in std_logic;
step: out std_logic_vector(3 downto 0));
end stepper;
architecture stepper2 of stepper is
signal cnt : integer := 0;
signal clkd: std_logic:='0';
begin
divider:process (sen,clk)
begin
if (sen='1') then
cnt <= 0;
clkd <= '0';
if (cnt = 24999999) then
cnt <= 0;
clkd <= not clkd;
else
cnt <= cnt + 1;
end if;
end if;
end process divider;
steps:process (sen,clkd)
variable s: std_logic_vector(3 downto 0):="1100";
begin
if (sen='1') then
step <= "0000";
s := "1100";
elsif (clkd'event and clkd='1') then
s := s (2 downto 0) & s(3);
step <= s;
end if;
end process steps;
end stepper2;
