how to call packag and component in xilinx
gyrajput
Junior Member level 1
hello all,
i tried to add packge and component in and function
my top code is :
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity top is
Port ( a : in STD_LOGIC;
b : in STD_LOGIC;
c : in STD_LOGIC;
d : out STD_LOGIC);
end top;
architecture Structural of top is
component and_gate IS
PORT ( a, b: in std_logic;
c: out std_logic);
end component;
Signal temp1, temp2: std_logic;
begin
and1: and_gate
PORT MAP(a, b, temp1);
and2: and_gate
PORT MAP(a, c, temp2);
and3: and_gate
PORT MAP(temp1, temp2, d);
end Structural;
then i write a new vhdl module
entity and_gate is
b : in STD_LOGIC;
c : out STD_LOGIC);
end and_gate;
architecture Structural of and_gate is
begin
c <= a AND b;
end Structural;
my check syntex is ok
but code is not synthesize
error is as followes:-
ERROR: The Top module has not been specified. This can happen if no sources have been added to the project,
please tell me how to call package and component in xilinx.....
hello all,
my top code is :
library IEEE;
entity top is
b : in STD_LOGIC;
c : in STD_LOGIC;
d : out STD_LOGIC);
end top;
c: out std_logic);
end component;
begin
and1: and_gate
and2: and_gate
and3: and_gate
end Structural;
entity and_gate is
b : in STD_LOGIC;
c : out STD_LOGIC);
end and_gate;
begin
c <= a AND b;
end Structural;
first you should put a CODE header and VHDL sytax to your code.
then go read https://www.xilinx.com/support/documentation/sw_manuals/xilinx11/ise_c_setting_custom_compile_order.htm
good luck.
thanks arui.....
it's works.............
but when i created test bench then i have to put three values as input a<='1'; b<='1'; C<='1'; then i got the o/p
i wann to give i/p just as a and b only,
please correct me where i made a mistake.
ok.....
so my code and port maping is "correct "
thanks tricky for reply,
